Question about Whirlpool LGQ9858PG Gas Dryer
No heat whirlpool dryer lgb6460kq1 i get no heat the ignitor does not glow. what can it be? how do the coils on the gas valve work? please help..
  • tengage80 Apr 17, 2009
    no heat, replaced ignitor, still wont glow. now what could it be?
  • 640 Answers
Check your thermal fuse first..onthejob
Posted on Feb 01, 2009
I have a gas dryer. the glow plug works but wont stay on
You are likely in need of new coils to make your dryer heat again. If the ignitor glows, the thermal fuses and thermostats are good. The coils sit directly on top of the gas valve, are easily replaced and inexpensive. CLICK HERE for the coil kit to get your dryer heating again. Using coupon code 1050 will save you some money!
Jan 12, 2011 | Whirlpool LGB6300 Gas Dryer
Whirlpool dryer(LGQ9557HQ0), ignitor ignites but flame does not light
mounted on top of the gas vavlve is black electrical coils when energized it opens the gas valve,if one of the coils are defective it wont open and let the gas thru,its hard to test the coils so most repairmen just replace them all
Jul 07, 2008 | Whirlpool Dryers
Drum turns but does not heat the air. I replaced the ignitor, but no help there. Whirlpool gas dryer model 63003W0
If the ignitor glows but does not light the burner you need to replace the gas valve coils.
If there is no glow you must check all the thermostat safeties and thermal cutout fuses for continuity with a ohm meter. No continuity is a bad component. Remove at least one wire from each component before testing.
Unplug the dryer before any test.
Feb 17, 2010 | Whirlpool Dryers
Have a Whirlpool Gas Dryer - model # lgr7646a spins but no heat
Thre is no pilot light. This dryer uses an ignitor (glow bar or coil).
Open the lower front "door" (small access door) and turn on dryer.
If the ignitor does not glow (bright orange), then the ignitor needs to be replaced ($60).
If it does glow, then the gas valve needs replacement ($60).
If it isd the valve, the internal spring is stuck. Do not try to repair it, you must replace it.
Sep 25, 2009 | Whirlpool Dryers
Whirlpool 110.76722690 gas clothes dryer spins but no heat
First, check that the ignitor is working properly. If it is working properly, it should glow an orange color when activated. If the ignitor is defective, it will need replaced. If the ignitor is working properly, the problem is most likely the gas valve coils. These small black coils are situated directly above the gas valves. These solenoids, when energized, open the gas valves and permit the burner to light. If any are defective, the valves cannot open and the burner cannot light. Due to the difficulty in testing these solenoids, it is best to replace both (all) of them at once if they are suspected of being faulty. Hope this helped and best wishes.
Aug 06, 2009 | Kenmore 659 Electric Dryer
My dryr tumbles but does not dry
Gas dryer? First thing to check is the ignitor underneath the drum. (You have to open the panel to see it)  It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off.  If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced.  If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Electric dryer? Temperature sensor has failed or heating element has burned out.
May 30, 2009 | Whirlpool Dryers
There is no heat being produced
HI, Remove the front lower panel. Start the dryer and see if the ignitor glows. If it glows but the gas valve does not open, Change the coils on top of the gas valve.
If the ignitor does not glow, test the ignitor for 120V. If there is voltage to the ignitor but no glow, change the ignitor.
If there is no viltage to the ignitor, check continuity on the thermostats and the fuse that are located on the blower housing. Also test the sensor located on the burner.
I hope this helps. Please let me know if I can assist you further.
Vic
May 24, 2009 | Dryers
GE gas dryer, no heat, new ignitor
Hi!! make sure that you have 120 volts going to the glow ignitor.the gas valve will not turn on the gas if the ignitoe wont glow..if it glows the check yout coil boosters they are round and are located by the gas valve.then if not you have a bad timer.they are usually round and are black..good luck..
Jan 03, 2009 | Dryers
Whirlpool gas dryer won't ignite -no heat
Try replacing the ignitor. The ignitor has to glow red and draw enough current to open the gas valve. When the gas valve opens then the ignitor lights the burner. Replace ignitor.
Nov 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryer lights, heats up some but wont relite
Replace the coil packs on the gas valve this fixes 90% of gas dryers lighting intermittently. The bracket comes off and they are sold seperately from any appliance parts retailer.
This worked for my dryer.
Feb 06, 2008 | Whirlpool LGR5634L Gas Dryer
Whirlpool LGQ9858PG Gas Dryer Logo
70 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
