It does not do this for normal printing, only envelopes.
SOURCE: Cannot print odd-sized envelope with 4250 LJ
We are using standard size envelopes and the default used to be drawer one. Now if we have envelopes in the manual feed it wants to pull from there no matter what we select.
SOURCE: printing envelopes on a hp laser jet p215dn
Please load envelops from tray 1.
When printing from application, just Ctrl + P and OK.
- Nikhil
SOURCE: How do I print envelopes on a hp p1006 laser printer?
to print envoleps u must first change the printing settings
in the settings u can see the envelop print choose tat
then u can print it
SOURCE: envelope jam HP Officejet 8500
Try to print envelope through Microsoft Word
Steps:-
1) Click Tools
, click Letters and Mailings and then click Envelopes and Labels
2) Type the Delivery and Return address information.
3) Click Options
4) On the Envelope Options
tab, set the following options:-
5) Select the Printing Options
tab and verify that the following settings are selected:
6) Click OK
and then click Print
As envelop can not feed correctly every time, it depends on the weight, flap design, paper type and other factors & cause jam, To prevent those you can do.
Have a nice day...don't forget to rate the solution.
SOURCE: HP Laserjet 4200 with optional
Use a damp lint free cloth and clean the feeder rollers.
Print out a configuration page to make sure that the printer recognizes that the feeder is installed.
Usually the envelope feeder problems stem from age and/or dirty rollers.
Make sure that your software app sees that the feeder is attached.
