Question about Whirlpool GR465LXLS Electric Kitchen Range
What is the correct procedure for setting temp
I have a whirlpool electric range that is not reaching desired temp. when i set it for 475 it is only reaching 200. i have checked the sensor and it is working properly. please help me with instruction on setting the temp.
  • mary_crocker Feb 01, 2009
    it is getting hot but will not reach desired temp. also this is not a self cleaning oven
  • Mark Egan May 11, 2010
    Does the lower element get hot?
    President:
  • 1,214 Answers
You should still have a lower element. If the lower element doesn't get hot when the controller is set for 350 degrees, that's the problem.
Let me know
Posted on Feb 01, 2009
Why is a Kenmore elec range model 665.92004102 have oven temp lower by 100 deg at settings of 400, 450, 475 and 495; while off 150 at 350 deg setting?
There is a problem with the oven probe sensor or EOC. To ensure this problem is fixed both parts would need to be replaced. This could cost more then $300 to have repaired.
Apr 23, 2014 | Kenmore 95822 / 95824 / 95829 Electric...
Is there any way to turn off the beeps- starting oven, when it reachs set temp, changing temp
Hello g harrison - Unfortunately the range does not have an adjustable volume level or cannot be turned off. It is designed to advise you of when the oven is starting or reach desire temperature.
Nov 29, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
The temperature in my oven is not accurate.... If I set it for 350, it pre-heats and then buzzes [to let me know it's reached temp]....but the temperature is NOT 350; rather, it is at 275 [I have a...
Your oven's manual should tell you how to adjust this. The manual should also have a trubleshooting chart. Also remember, your temperature sensor may be going bad and will need to be replaced. For now, you can set the temperature 75 degrees higher to get the correct temperature you need.
Sep 15, 2011 | Whirlpool Electric Range
Doesn't get to correct temp set.
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 05, 2010 | Whirlpool Accubake SF362LXTS Kitchen Range
Mer5755 Oven losses temp. Start at 400 loses temp later
The problem is usually the ignitor not reaching the correct amp draw .When the ignitor does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The ignitor are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the correct procedure for performing this test. You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available.
Apr 02, 2010 | Maytag MER5755Q CleanDesign Electric...
My oven heats up, but then does not maintain the temp.
If it has a pilot then I would say the thermal couple is bad. If it has a glow type ignitor then the ignitor is bad.
Sep 02, 2009 | Whirlpool GS460 Gas Kitchen Range
Oven temp indication
it could be your oven control unit
Dec 10, 2007 | Whirlpool RF367 Electric Kitchen Range
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Whirlpool GR465LXLS Electric Kitchen Range Logo
116 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
