Question about Sony PlayStation Portable (PSP) Slim (PSP-2000) Console
Psp laser doesn't turn
My psp2000 worked 100%. I replaced the front and back cover, now the laser doesn't turn.there is a spring with a plastic cover just on top of the laser that a think its not installed coreectly
any help would be much appreciate
varkie_2003@yahoo.com
  • varkie_2003 Feb 11, 2009
    Thx anyway, i found the problem long ago. It was the spring that was not fitted correctly.
    Problem Solver:
  • 4 Answers
You should not tamper with those dude. better bring it back to where you had your covers changed, they might have missed on some things in reinstalling the covers.
Posted on Feb 09, 2009
Im missing the cover for my battery on my psp.can I get a replacement?
Hi there, yes you can indeed get a replacement cover, there is a difference between the slim and fat models though so make sure you get the right one. Have a look on amazon and ebay and you will find them on there. To tell if your PSP is fat or slim, take a look at the white label on the side of it with a model number. If it says PSP1000 it is a fat, if it says PSP2000 or PSP3000 it is a slim.
Hope this helps
Jul 14, 2011 | Video Game Consoles & Games
My psp suddenly stopped working and will not charge wont turn on at all
Hi Rneal_99,
If your PSP suddenly stopped, check if the battery cover is fitted snugly because if it is loose even by just a bit, you will have charging issues and you will not be able to turn it on because the battery should be seated properly inside the battery slot. I had the same problem because my battery cover had a small crack which made it a bit loose. I was supposed to get a new battery cover but I was able to resolve the issue by using a piece of paper as a padding for the battery just to get a snug fit. It worked for me, I hope it works for you too.
Other things to check :
1. Is the battery dead (does not have charging capabilities anymore)? You can isolate this problem by using a different battery module. You can ask your friends to lend you their PSP2000 battery just for testing purposes. Inversely, ask them to use your battery with their PSP2000. See if they will have the same problem.
2. Is the Charging Adapter broken ? Same trick here as with the battery, use your friends Charging adapter and vice-versa. Checking on these three things should isolate the cause of the problem.
If the battery is busted and does not have any charging capabilities anymore, you need to replace it. If the Charging Adapter is the culprit, you should go to a professional to have it fixed. But, if both your battery and your Charger are working properly, chances are the problem lies internally. Specifically the Power switch, the Power Socket Connection module and maybe even the PSP's power supply module. You should seek professional help in these cases because these problems are quite challenging to fix even with the proper tools and the proper skill set. However, if the unit is still under warranty, Sony should cover this. You can call them at 800-345-7669. I hope I was able to help. All the best to you.
Dec 07, 2010 | Sony PlayStation Portable (PSP) Console
How to fix psp to charge it agian?
Hi Ynnaalbasin,
If your PSP is not charging at all, you initially have to check on three things :
1. Is the battery seated properly in the battery slot? Also check if the battery cover is fitted snugly because if it is loose even by just a bit, you will have charging issues.
2. Is the battery dead (does not have charging capabilities anymore)? You can isolate this problem by using a different battery module. You can ask your friends to lend you their PSP2000 battery just for testing purposes. Inversely, ask them to use your battery with their PSP2000. See if they will have the same problem.
3. Is the Charging Adapter broken ? Same trick here as with the battery, use your friends Charging adapter and vice-versa. Checking on these three things should isolate the cause of the problem. If the battery is busted and does not have any charging capabilities anymore, you need to replace it. If the Charging Adapter is the culprit, you should go to a professional to have it fixed. But, if both your battery and your Charger is working properly, there is a possibility that the problem lies internally. Specifically the Power Socket Connection module and maybe even the PSP's power supply module. You should seek professional help in these cases because the power supply module is quite challenging to fix even with the proper tools and the proper skill set. However, if the unit is still under warranty, Sony should cover this. You can call them at 800-345-7669 I hope I was able to help. All the best to you.
Dec 04, 2010 | Sony PlayStation Portable (PSP) Slim...
My psp2000 slim has an error 80020321. When start the game it deos not starts it shows (The game could not be started)(80020321).I tried to fix but i could not.It could show the setting of memory stick by...
there could be 2 problems
  1. your game might not be downloaded properly ..or completely
  2. Go to the recovery console on yr psp2000 (turn off psp press on R button & turn on your psp while pressing on the button) & change the driver to D33 driver.
Sep 02, 2010 | Sony PlayStation Portable (PSP) Slim...
Brothers DCP 7020 Laser printer. Paper feeds into the printer and stops with a back cover open message. Clear the paper, the printer re-sets. Paper clearing is by removing the drum / toner module and...
Eject sensor actuator is too short or the main board is defective
Recommendation: Either the eject sensor actuator is not properly actuating the back cover
sensor, which is mounted on the rear side of the main board, or the
main board is defective.
open the back cover and look to see if the sensor is moving easily, if it is, you have a bad main board, if its not, the sensor is out of position.
Jun 12, 2009 | Brother DCP-7020 All-In-One Laser Printer
PSP2000 SONY GAME
no you cant... the t.v screen cant support the games of psp.
Mar 11, 2009 | Sony PSP (Piano Black)
Upgraded to version 5.03 on my psp2000 and cannot play games now
You need to use pandora to put CUSTOM firmware back on your psp, downloaded games dont work with official firmware.
Feb 19, 2009 | Sony PlayStation Portable (PSP) Console
Toner life end message after drum unit replaced
I spoke with Brother and one of the options was to open the cover, push options, push start, and then 1, then 1 again. If accept comes up, select. Then close cover and try again.
Feb 06, 2008 | Brother IntelliFax-2820 Laser Fax
Sony PlayStation Portable (PSP) Slim (PSP-2000) Console Logo
42 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
