Question about Emerson Smartset Clock Radio
Emerson clock radio cks 3516 military time
My emerson clock radio (cks 3516) changed to military time and I can't get it to change back. I have unpluged it and it still came on with military time.
    President:
  • 814 Answers
You will need to try some combination of the set button and time button to change the time back to normal time. Try hold both the time and set button for a period of 5-10 seconds and see if this will cycle the time to normal. If not try hold the set button alone for 5-10 seconds and see if this works. If not try holding the time time button for 5-10 seconds and see if that works. If none of the fixes work. Call Emerson customer support at this telephone number 1-800-898-9020 between the hours of 9am-5pm CT. Tell them the make and model number of your Clock/Radio and ask them for assistance with your problem of resetting the time back to normal from military time. They will be able to help you. I hope this information helps you solve your problem.
Posted on Jun 13, 2009
How do i get my clock off military time
Nov 06, 2016 | Audio Players & Recorders
How do I get an onn fm alarm clock radio off military time?
Most clocks that have Military time on them will change to regular after going thru the Military mode.
Jun 01, 2014 | Bose Wave Radio
Change clock from 24hr mode to 12hr
Press and hold the Time button on your clock to toggle the time from 24-hour (military) to 12-hour time. This should be the middle button on the right hand side of the top of the CKD9902. Manuals Online has the manual for the CKD9902 here: http://portablemedia.manualsonline.com/manuals/mfg/emerson/ckd9902.html . Click on the Get This Manual button. The manual has a good picture of the buttons on the clock (it is a PDF).
I hope this helps.
Dec 28, 2011 | Emerson CKD9902 Clock Radio
My emerson cks1850 still stuck to the old daylight savings time and I need to fix it as i rely on it for work and frequat power outages we have were i am and the auto reset is why i like it but now it...
unplug the clock radio from the power, take out the back up battery ( if it has one). let it set for 60 seconds or so, plug it back in, It should now be flashing 12:00 over and over. now reset the clock to the correct time and date.
Mar 14, 2011 | Emerson SmartSet CKS1850 Clock Radio
Emerson Clock Radio Model CKS 1855
Try Googling (emerson)(CKS 1855)(manual) without parens for instructions.
Sep 01, 2017 | Emerson Smartset Clock Radio
Doesn't maintain current date and year
[http://www.emersonradio.com/owners/SmartSet%20Series/CKS3095_041707.pdf] copy this web link and paste it into the address bar of your browser. This will take you to Emerson's customer support where you will find a pdf copy of the owners manual for you model Clock/Radio. On pages 28-31 you find the procedure for changing the internal lithium battery (CR2430) . This is what you must do to get you Clock/Radio to function correctly again. The internal battery has failed and you have lost all memory functions in the Clock/Radio. If after performing the battery change, you are still having problem with the Clock/Radio. Call the Emerson customer support at this telephone 1-800-898-9020 between the hours of 7am-5pm CT. Give them the make and model number of your Clock/Radio and ask them for assistance. I hope this information help you with your Clock/Radio problem.
Feb 17, 2009 | Emerson Smartset Clock Radio
SmartSEt Clock Radio went to military time
You can reset the time from military to regular time by holding down the time button and let it cycle to the normal time. I hope this information help you with your problem.
Feb 01, 2009 | Emerson Smartset Clock Radio
Getting the clock off military time
This is controlled by hardwired switch (12/24) OR digitally during menu setup sequence.
Sep 17, 2017 | Audio Players & Recorders
Smart set radio cks 1851. It will not keep the time and now blacks out. New battery installed. Folled plan of reset. lasted approx 10 minutes and blacked back out. Was plugged into electric at the...
Sorry it took so long to get back to you with a solution to your problem. You must try to reset the microprocessor in the Clock/Radio. To do this you must unplug the Clock/Radio from the A/C power source.Then remove the Internal battery(CR2430). Let the Clock/Radio set without a power source for about 3 hours. This will discharge the microprocessor and reset it. After you have discharged the microprocessor,you can reinstall the internal battery. Connect the Clock/Radio to the A/C power source. The Clock/Radio's Functions should have returned to normal function. If the Clock/Radio did not return to normal function, you must replace the internal battery and again let the microprocessor discharge. After the microprocessor has discharged,put in the new internal battery and reconnect the Clock/Radio to the A/C power source. The Clock/Radio should have returned to normal function. If you are still having problem with the functions of the Clock/Radio, You will have to call Emerson Customer Support. The telephone number for the Emerson customer support is 1-800-909-1240. you can call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance. I hope this information help you with your problems with the Clock/Radio. Thank you for using FixYa and have a nice day!
Jul 19, 2008 | Emerson Smartset Clock Radio
Emerson Smartset Clock Radio Logo
827 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
