Question about Canon Rebel XT / EOS 350D Digital Camera
Connection to PC Problem
Hi
I have a Canon 350D and recently experience a problemn with downloading photos. When I plug in to USB port Camera window pops up and says:
"The camera is busy and cannot respond If LCD monitor is pon turn it off, click retrty or cancel to disconnect camera"
Thing is, the LCD monitor isnt on and I've never had this problem before, its with both XP and Vista ?!?!
Bit stuck !!! Please help me :)
  • Anonymous Feb 04, 2009
    Hi
    Thanks for that, checked USB's and they appear to be fine, the strange thing is that the camera worked on both computers before ?!?!
    bit confused :)
  • 72 Answers
Hi this techcrazy ..
The main problem can be due to the operating windows u have in the system.please do uninstall either xp or vista . their may be problem due to the overlapping of two operating windows.. (or)
please do check out for the usb port.there may be some loose contacts which is denying proper access to system
Posted on Feb 01, 2009
Recent;y bought a mew laptop with Windows 2007 as the operating system. I loaded the CD that originally came with my Canon EOS Digital Rebel XT (EOS Digital Solution Disk v 10.0), then downloaded the...
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Canon ZoomBrowser or any other photo cataloging program.
Nov 20, 2010 | Canon Rebel XT / EOS 350D Digital Camera
I cannnot download my photos from my Canon EOS Rebel IT camera onto my computer.
Try to disconnect the camera from the computer, then connect it to a different USB port if your computer is a desktop connect the camera to the back USB port then restart the computer and check it again.
Jun 02, 2010 | Canon Rebel XT / EOS 350D Digital Camera
I have problems downloading pictures from a Canon eos 350d to my new computer (which uses Windows 7).
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Windows Photo Gallery or any other photo cataloging program.
May 20, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS 350D Driver Windows 7
You need to change the camera's USB connection mode from "PC" to "Print/PTP" in camera setting menu. After that it should be recognized by Windows 7 without drivers.
May 24, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Recently unable to download photos from my eos 350d to pc. When I hook up through USB the camera flashes busy for up to 5 min. Then the usual EOS utility box appears. The only option available is ''...
Do you have a memory card reader or a memory card slot on your laptop or Desktop PC? If so, remove the memory card on your camera and then hook it to the slot on your computer.
It should be detected and then you can copy your files from the card to the computer.
If you still have problems, please post back.
Aug 21, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon 450D is not being recognised by my computer (I run xp 32-bit). When I turn on the camera, windows comes up with a "install new hardware" option. I have installed the EOS utility etc. but still the...
Both the Canon XT 350D and the XTi 400D are recognized by any PC with XP windows operative system. It seems you have to check your USB port or USB cable used to connect your cameras to the PC. Sometimes, the PC does not recognize a specific device connected to an USB port. Yopu can get into the System -device manager screen, and uninstall the USB port, and run the utility to recognize changes in the device manager. This will install the USB port driver again, and if it is a software issue the reason of the problem, then it will be fixed.
Also, you can check your cameras and USB cable in a different PC so you can confirm if they both work has should be.
Regards,
Mar 26, 2009 | Canon EOS 450D Digital Camera
How do I download pics from camera to computer
Two options: -
1. Install the software from the Canon CD and use the USB cable that came with the camera.
2. Take the CF card from the camera and plug it into any USB card reader with a CF/Microdrive slot.
Feb 16, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Can't get camera to communicate with pc
Look here...
http://www.fixya.com/support/t290758-xt_will_not_connect_vista
Either download the drivers found on the Canon website, or use the PTP (Picture Transfer Protocol) embedded in Windows Vsta.
Cheers!
Sep 02, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Can't import photos using windows photo gallery
Buy a card reader from an electronics store. AU$35 - $45 Solved my problem of Office XP Windows ignoring my 350D.
Dec 20, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
134 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
