Yes there is. DO NOT but a universal remote. Factory OEM replacements are available as well as Facsimile Remotes which are an exact copy and need no programming.
Main board fault. Check and replace damaged component/s at it horizontal output stage circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. http://electronicshelponline.blogspot.com/
If only one function on the Remote works it probably needs repair of some sort. Remotes are delicate things which can easily be damaged or broken by dropping them, or by spilling fluids such as soft drinks over the keypad. Old batteries can cause internal corrosion of metal parts. I have repaired some remotes successfully but many were beyond repair. The best solution in event of failure is to purchase a replacement of the original (new or second hand)or a multifunction remote which may have the code for your Tv or other apparatus in its memory,
Tries this website for a new remote 1-800-Remotes Factory original for new remote or tries the manual controls on the tv for functions to ajust the screeen sizes.
Unless the set has front panel menu buttons and the on-screen menu allows you to select the source, the answer is "no, you can't switch without the remote". If the original remote is really broken, you may be able to use an RCA-brand universal replacement that has an "input" or "source" button. Unless the original is physically damaged, before you toss it check the battery contacts inside. They sometimes get loose from handling the remote a lot and don't make good connections. Also make sure the new batteries are fresh and facing the right way.
I need a remote for the TV/vcr combo. where can i get one?
