Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
2005 Fat Boy will not start
The bike was idiling and it just died. When I went to re start I got nothing. When I turn the ignition on nothing happens, the fuel pump/injector does not even kick on nor do the headlights. The battery has been tested and is good and full of juice. It does not even try to turn over. When you hit the start button nothing happens.
Please help.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 221 Answers
If your battery is good and you have check the maxi-fuse and its good then you have a bad ground so check that, harley's complete circuits using ground
Posted on Dec 29, 2009
Have not rode in 2-3 weeks.Never have had a gas smell issue period.Went in garage today and smelled gas.Yesterday no smell, today a strong smell.Was27 degrees last night.Any ideas on what happened ?
Hi, Vinny it's called a bike f*rt, forget about it, seriously I don't have a clue your bike is designed to function properly in sub-freezing temperatures get out a flashlight turn on the ignition wait for the pump to prime and look for leaks for more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
http://www.carlsalter.com/pdfs/Harley%20Davidson%20Softail%20Service%20Manual%202007.pdf
http://partsfinder.onlinemicrofiche.com/stcharlesharleydavidson/showmodel.asp?make=hdmc
https://serviceinfo.harley-davidson.com/sip/vehicle/lookupForm
How 6ya Works 6ya A must have !!! Totally "FREE"
Dec 21, 2016 | 2008 Harley Davidson FLSTF Softail Fat Boy
2004 Harley Davidson FLSTF Fat Boy installed a new battery the engine turns over but will not start
Hi, Brandon before replacing a new battery make sure your battery cables are clean, "CORROSION" free and "TIGHT" you may find your bike starts ok and you don't need a new battery. When removing an old battery always disconnect or remove the main 40 amp fuse or circuit breaker first then disconnect the negative cable, depending on accessories, reconnecting a new battery that is not fully charged or in the wrong sequence sometimes gives Mr. Electron a free pass to wreak havoc with your electrical system. Never put a brand new battery in a bike without charging it to 100% full capacity first. With the ignition and kill switch in the off position connect the positive battery cable first, then check your negative ground cable where it attaches to the frame or engine for a clean tight connection anything substandard will cause excessive amperage that can overwhelm delicate microprocessing circuits and fuses in the system when the negative ground cable is connected to the battery post, end result from your bike, it declines your invitation to come out and play. That being said the usual suspects are:
1. Security system needs a reset.
2. Improper sequence procedure for alarm override.
3. Key fob out of sync with the alarm system.
4. Key fob battery low or dead.
5. Key fob battery installed backward.
6. Fuel tuner needs to be reprogrammed.
7. Faulty run/off switch
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
Replaced Battery will crank but won start HELP Please Harley Davidson...
Harley Davidson Softail Workshop Service Repair Manual2004$10
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://mybikemanuals.com/harley-davidson/2005-harley-davidson-owners-manuals
Instant Tech Relief To speak to me personally absolutely "FREE"
Nov 02, 2017 | 2004 Harley Davidson FLSTF - FLSTFI Fat...
Which fuse is the main fuse for a 2003 harley fatboy
Hi Anonymous, on a Softail remove seat and directly behind the battery is a black plastic box. The cover slides up and off revealing the starter relay and the system/fuel pump relay for you injected folks and the various assorted circuit fuses. Good luck and have nice day.
Apr 10, 2013 | 2003 Harley Davidson FLSTFI Fat Boy
2003 Fatboy Electrical Issues
Hi Dee, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections check negative cable at BOTH ends. (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to on.
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
7. Security alarm not disarming
For a prime suspect please visit website below and good Luck.
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Apr 10, 2013 | 2003 Harley Davidson FLSTF Fat boy
Hard to start then misses sputters and dies at a stop
Is this a "nose cone" harley?19 70s to 90s? Check centrifical advance unit,located behind breaker plate where points or ignition module are mounted.when they sit for awhile it can rust and stick,resulting in retarded timing.
Jan 22, 2013 | 2004 Harley Davidson FLSTF - FLSTFI Fat...
How do I check my ignition switch on my 2005 fat boy
Hi Larry, with a test light for continuity. Have nice day.
Oct 04, 2012 | 2005 Harley Davidson FLSTF - FLSTFI Fat...
08 fat boy will not turn over. The battery is good. But nothing after the fuel pumps up.
Hi Michael, and the usual suspects are:
3.Discharged battery, loose or corroded connections check negative cable at "BOTH" ends. (solenoid chatters).
For a prime suspect please visit website below. Good luck and have nice day.
Jan 28, 2012 | 2008 Harley Davidson FLSTF Softail Fat Boy
Harley won't start ... starter not working custom softail ... 80 ci v twin engine... nothing happens when I push the starter button.... battery is fine and all lights work... clicking sound under seat...
That clicking sound you are hearing may be a circuit breaker tripping indicating a short circuit somewhere. I think the starter circuit is powered by the ignition circuit. If you have a short circuit in your ignition system the breaker will trip killing power to your ignition, thus the engine dying, and preventing power for the starter circuit preventing the bike from being restarted.
On your bike, I believe there is a chrome coil cover over the coil on the left side of the bike. Check and see if this cover has come loose. I've seen them come loose and fall down on the coil connector on top of the coil shorting it out. If that ain't it, just keep looking, there's a short somewhere. Good Luck
Mar 30, 2010 | 2005 Harley Davidson FLSTF - FLSTFI Fat...
Lands Phones Logo
138 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
