Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
Loud rattling grinding noise when pump is running, no water enters the machine.
  • jdemarinis Feb 08, 2009
    during the washing and rinsing cycles a loud rattling noise occurs-- the sounds seems to getting louder-- any solutions?
  • 38 Answers
Make sure the water is turned on to the machine, if it is then it sounds like a faulty water fill valve, just replace the fill valve, they can sometimes be cleaned but I would never trust one, they can always stick in the on position later and flood your house. Check to see if the valve is geting 120v ac before replaceing the valve, if it's getting voltage and no water is flowing then the valve is bad. You will need to borrow or buy a multi-meter for this test.
Posted on Feb 23, 2009
Grinds beans OK and goes through the cycle but no coffee comes out even on expresso and not sounding right. Anyone know why?
If the machine is making a loud rattling noise it may be that the pump is sucking air and not water at start up. Clean out the machine, reassemble, install water tank and tilt the machine over backwards at approx 45Deg, and start the rinse cycle again. This normally clears the air lock. Good Luck.
Sep 16, 2015 | DeLonghi EAM3500 Espresso Machine/Coffee...
What is causing rattling grinding noise at idle especially in my 89 4.5 DeVille?
The technique I always used to identify where such a noise was coming from was to use a very long screwdriver (2 feet long), while the engine is running. CAREFULLY touch the screwdriver end to each pulley or other object under the hood, and put your ear to the handle. The device making the noise will become very clear.
It could be AC pump/clutch, alternator, water pump, power steering pump, etc.
May 20, 2015 | Cadillac DeVille Cars & Trucks
Loud drilling noise when coffee switch is turned on - rather than the usual purring noise - and no coffee delivery either
How old is your machine ? and what maintenance have you done over time such as replacing the shower curtain located at the pourring end of the hot water ? I had too very loud noise coming occasionnally from the stainless steel rack holding the cup while coffee is delivered. If your ground coffee is too fine it will stop flow during making a shot. Is water coming out when no coffee is placed in the portafilter.The water pump on this machine is a cheap pump that has to be replaced over time. Mine is 7 years old and has delivered four cups of expresso everyday of the year, and still working.3841c994-fb4b-459f-8d1f-710e0aafc3c0.jpg 2ead4f70-37c6-4236-a9c2-992dba149c4c.jpg
May 29, 2014 | Rancilio Silvia Espresso Machine
Just changed timing belt on 2001 nissan xterra. I can hear a noise coming from intake cam and slight rubbing or grinding noise for distributor cap. Does this mean timing is off or belt is too loose /t
some of those distributors were pretty loud as far as rattle noise. could be distributor it self, but would not worry about it much until it actually completely dies. could run like this for long time.
Aug 20, 2017 | 2001 Nissan Xterra
Mitsubishi mighty max 3.0 v8 loud noise coming from the fan area
If the fan is attached to the water pump tahe hold of a blade and try back and forward towards the motor. If there is movement there it will be either a fan hub failing or a water pump bearing. Second check remove the fan belt and check for noise.( idle engine for short period of time) If it is gone confirm pump by spinning any adjuster pulleys and check for noise or rough movement
Jan 12, 2013 | 1994 Mitsubishi Mighty Max
Water leaking and loud noise and rattling on final spin cycle
Turn the drum by hand and if you hear any noises it is the rear bearing. If there is no noise then remove the front bottom panel and take out the coin trap on the pump and check those hoses.
Eric
Aug 27, 2009 | Whirlpool GHW9150 Front Load Washer
Admiral aav-1 makes loud grinding will not spin or drain
Hi, the drain pump impeller is damaged. you will need to replace the entire pump(drain) in this case.
You will hear this noise when the impeller become separated from the actual drive stud or, shaft.
Jul 13, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Maytag performa washer grinding noise
Sounds like the water pump is going out on it. The part runs about $80 and should only take about 45 minutes to install.
Jun 25, 2009 | Maytag Performa PAV3200
I have a kenmore 70 series washer,the machine won't spin. I hear the clutch but it's not engaging. The pump to remove the water seems to be operating but the tub just won't spin and makes a loud noise.
The loud noise (sounds like rattling or grinding) is the motor coupler. It's between the motor and the transmission. This part takes the place of the belt, and costs about $20.00.
Mar 31, 2008 | Washing Machines
Loud noise -- water pump??
Yes you definately need a new pump assembly part number 21001906 $59.95. That is a maytag part number and it is a very common repair. The new pump is a revised design and will look different but will mount the same. Axcess through front panel.
Nov 25, 2007 | Maytag MAV7200 Top Load Washer
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
521 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
