Question about Agri-Fab Agri - Fab Snow Blower - 42"
I have a MTD 2 stage snowblower. How to I adjust the Auger cable? Also, just finished snowblowing and the engine lost its power. It stays running until I try to snow blow and soon as it takes in the snow it does not have enough power to shoot then it stails out. What do you think?
  • zajacd Feb 02, 2009
    Thank you Jerr. I replace spark plug and so far so good. I will do the rest as well and will test in tonights storm. It was great to finally find a place like this for help!
    Take care
    Top Expert:
  • Agri-Fab Master
  • 2,446 Answers
I think you should contact your nearest authorized service center for assistance, or you can download operators and service manuals at the link included:
Downloadable Manuals
I trust this information proves beneficial.
Posted on Feb 14, 2018
  • 2468 Answers
SOURCE: I have a 5/22 2 stage MTD snowthrower and from
your shear pin(s) are broken on that side they will look o.k. but are snapped off inside drive them out with a large nail or center-punch,don't use a regular bolt to replace the shear pin as they will fit,because if it gets plugged again the gearbox will be your next expensive shear pin to replace
Posted on Feb 24, 2010
vincob
  • 718 Answers
SOURCE: I have a older snowblower
You are not getting fuel to the carb take it off and give it a good cleaning, paying attention to the small orifices. Many times on older units the float bowl screw on the carb has an orifice that is always the culprit give it a try . Good Luck
Posted on Aug 30, 2010
aquaman987
  • 927 Answers
SOURCE: i bought a used dynamark 3/20" snowblower, when i
1. Is there gas in the tank?
2. Is there a fuel line valve, either as part of the carburetor or between the fuel tank and the carb?
Posted on Dec 22, 2010
  • 10865 Answers
SOURCE: I have a 26" craftsman
Hello Tal.... when it just stops working, check the belt or belts. Many snow blowers have two belt. Go to searspartsdirect.com
Enter your model number and you will get diagrams of this machine along with parts numbers. Be sure to use a craftsman belt for the repair. Joe
Thanks for choosing Fixya!
Posted on Jan 17, 2011
  • 148 Answers
SOURCE: model 826 snowblower will start and run about 20
It sounds like its not getting enough fuel. Check for restriction in fuel line, clogged fuel filter or malfunctioning carburetor. Your choke could also be out of adjustment
Posted on Feb 02, 2011
The auger wont disengage on a mtD 8 HP 26 INCH SNOWBLOWER THE HANDLE STAYS DOWN
follow the cable to the auger either snapped or came loose
Dec 22, 2016 | Mtd Garden
I have an MTD single-stage snow blower that I replace the other the cable and the belt and under a load it's still not throwing snow
There should be 2 holes on the handle that engages the auger belt, use the top hole as it will increase the belt tension.
Check the condition of the rubber auger's rubber paddles as they are subject to wear and should be replaced if any signs of excessive
wear is present.
Jan 31, 2016 | Craftsman 21" 179cc* Single Stage...
Auger on snowblower doesn't engage
how do I find good anime movie on Netflix help me fam
Feb 11, 2015 | Mtd Garden
I have a MTD snowblower yard machine.how to adjust
There should be metal shoes on the side of the snowblower. They have adjustment bolts that allow the auger housing to move up and down. loosen them and adjust to how close you want it to the ground. It also depends on the model. This process only applies to large self propelled models which are a two stage snowthrower. if its a small single stage there is usually no adjustment.
Oct 19, 2014 | Garden
Mtd 31c won't stay running?
You probably have to take the carburetor apart and clean it using a spray type carburetor cleaner spraying the jets and small holes in it.
Mar 16, 2014 | MTD Genuine Factory Parts Auger Belt for...
Who do I remove the auger
take the little nuts and bolts out , most you can adjust a little drill new holes after you adjust it about 1/4 in or so do not go buy new ones when this can be done to save money
Feb 17, 2014 | MTD Genuine Factory Parts Auger Drive Belt...
MTD Snowblower starts good but runs very rough
Carb adjustment. There is usually a HIGH and LOW fuel mixture adjustment on the carb. Sounds like the LOW needs to be adjusted. Do a search on the Internet for a service manual for your particular model/make. Simple job IF you have the manual there for guidance.
Good Luck
Jan 26, 2010 | Mtd Products Yard Machines 158CC Tiller
How can I keep my 2 stage snowblower in high?
I will assume you are referring to the 2 stages in the front of the machine. The spiral auger rakes are the first stage, they are designed to collect the snow and feed it to the impeller. The impeller is the 2nd stage and is to throw the snow up the chute. The lower rakes in the front do nopt throw snow only collect it.
Jan 09, 2010 | Mtd Garden
Auger stopprd working on an MTD snowblower.
The manual has a step by step procedure for adjusting the cables for the auger, speed selector and drivewheels. One socket wrench and about 10 min should do it.
My Yardworks is an MTD product and it's manual should be similar to yours. If you lost it, you can download it from MTD's site.
Dec 23, 2008 | Craftsman Garden
Agri-Fab Agri - Fab Snow Blower - 42" Logo
161 people viewed this question
Top Agri-Fab Garden Experts
Roland W VanLue
Roland W VanLue
Paul Sikkema
Paul Sikkema
Joseph Mueller
Joseph Mueller
Are you an Agri-Fab Garden Expert? Answer questions, earn points and help others
