Question about DXG Technology DSC 568 Digital Camera
How do i get my digital camera it.works dsc-568s
To be used as a webcam without using a CD rom ?
and how do i unstall the camera from my laptop?
Connecting Sony Cyber shot DSC-T10 to computer and using it as webcam with USB
The webcam and the Sony Cyber-shot are two completely different designs. The webcam takes live moving pictures without limitation, the Cyber-shot can not deal with that kind of use it has limited capability which prevents it from being used in that kind of fashion.
Apr 22, 2012 | Sony Cyber-shot DSC-T10 Digital Camera
HOW DO I SET DSC 220 CAMERA TO LAPTOP SO THAT I CAN USE IT AS WEBCAM?
You can't use a digital camera as a webcam without finding third party software that you will probably have to buy.
Thomas
Jul 31, 2011 | Sony Cyber-Shot DSC-W220/B Digital Camera
The spring load for the film card in my Sony DSC-W80 doesn't work anymore. Please help!!
If the card won't click in/out try and use a paperclip - slightly open and put over the card - pinch a little and pull out without any force.
The spring loading is deep inside the camera only a technician will want to open up and replace.
The only way to clean (and be very carful) is to use a cotton bud m put 1 drop of CD/ROM cleaner on the very tip (just one drop) and rub slowly along the base where the card slots in.
Some shops often sell a card holder (like a Nokia card) puller these will also have enough grip to insert or withdraw a card. - Ray
Feb 03, 2011 | Sony Cyber-shot DSC-W80 Digital Camera
Can you use Cyber-shot DSC-W300 Digital Camera as a webcam?
DSC-W300 Sony digital still Camera is not supported for use as a Webcam. For video conference, use a dedicated Webcam or video camera that supports this function. You can use the MHS-PM1 AND MHS-CM1 Webbie HD MP4 Camera supports video conferencing.
Thanks for using FixYa.
Jan 27, 2011 | Sony Cyber-shot DSC-W300 Digital Camera
Use s930 as webcam
Dear friend,
1. 1st install Your camera CD.
2. plug in your cam with your pc or laptop via usb.
3. wait for detecting cam and installing.
4. restart.
5. if your in msn then you see u r msn connected with cam, if your in yahoo then login in yahoo messenger, then clock preferrence , then webcam, then select your cam then press ok and use it.
Thx
Jan 29, 2010 | Sony DSC-S930 Digital Camera
I need a driver for a dlink DSC 350 camera and wb cam for windows xp
i cant use dsc 350f as a webcam please help me thanks alot
Sep 03, 2009 | D-Link DSC-350 Digital Camera
A4tech PK-635M Camera installer
Just copy the drivers from your cd to some USB storage media, hope the USB is working fine on your laptop, then you can install the drivers and use the webcam.
Jun 23, 2009 | A4tech PK-635 Webcam
Need Items
The model of the product usually has every accessory available! Try that first before looking elsewhere!
Feb 07, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Digital cam as webcam
step 1 Check the manual of your digital camera to see if it can be used as a webcam. Many digital cameras have this functionality and even come with webcam software. If your camera didn't come with webcam software, use a third party web cam application such as SarmSoft WebCam. Find SarmSoft WebCam at ShareUp.com.
Step 2 Plug your digital camera's power adapter into the camera. Some won't function as a webcam unless they are plugged into A/C power. Even if your digital camera functions as a webcam while on batteries, A/C power saves your batteries and prevents your camera from shutting off in the middle of a broadcast.
Step 3 Connect a video cable into your digital camera's video "out" port. Your camera likely came with a cable made for connecting it to a to a video source. Plug the other end of the video cable into your video card's video "in" port.
Step 4 Set up your camera as close to your monitor as possible. This allows better face to face communication.
Step 5 Position yourself about 2 to 3 feet away from your digital camera. Most digital camera's focus best at this distance when used as a webcam.
Step 6 Use a separate microphone if your digital camera doesn't transmit sound when used as a webcam. Plug the microphone into the microphone jack of your sound card
Oct 21, 2007 | Sony Cyber-shot DSC-W80 Digital Camera
DXG Technology DSC 568 Digital Camera Logo
Top DXG Technology Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a DXG Technology Camera Expert? Answer questions, earn points and help others
