Question about Nintendo Wii Console
I think that my little brother put something inside wii console
Hello, What should I do if I can't insert my disk, when I try to do it I hear a noise and the disk doesn't go in. I assume that there must be something stuck inside.
  • wadefel Feb 23, 2009
    The disc won't go in and it rattles sometimes when you shake it.We think our 3 yr old put the sd memory card in it.The company will fix it for 60.00 plus shipping.
  • 3 Answers
The mechanism that accepts disk is faulty probably due to something being forced into slot. Have fixed many problems the same as this. If you need me to have a look let me know lindop@hotmail.com. NO FIX, NO FEE returned free of charge
Posted on Feb 02, 2009
Can not insert disk into imac
Assuming of course the iMac is otherwise running and functioning normally, this would indicate that the drive has gone bad. Usually, when you first turn on the computer, you'll hear the drive make a sound. If this is not happening, either there is a disk stuck in it or the drive is defunct. visit this page for some tips on ejecting a stuck disk. If that does not work, you will need to replace the drive.
Apr 18, 2013 | Apple iMac Computers & Internet
Everytime i try to boot it comes up with boot failure insert system disk,this is accompanied with clicking noises, i can hear it trying to boot but not succeeding. i do not have a system disk.
Hi, Helen.
I hope this helps you out in knowing what is going on.
When the computer tries to boot up, you said you hear clicking noises, well, this is the drive trying to access the boot sector of the drive.
If it just keeps clicking, and doesn't boot, then you most likely have had a hard drive failure.
Unfortunately, there is no easy fix for this, other than get a new drive for your machine.
At least drives nowadays aren't as expensive as they used to be, not even close.
A new drive only costs around $50 for a 500GB sata drive, that's pretty cheap considering that just 3 years ago the same drive was well over $200.
Most major retail outlets carries drives nowadays, even WalMart carries them.
You will have to reinstall everything on to the new drive though, unless you take the old drive to BestBuy, Fry's, Staples, or CompUSA.
They are the major electronics stores that have actual trained staff for data recovery services.
They can do their best to get all your old info off of the bad drive for you.
I hope this help you out on knowing what's going on, and good luck to you.
May 14, 2011 | HP Hewlett Packard Pavilion Slimline...
Disk boot failure please insert disk and press enter
either hard drive is junk usually hear noises before death or you need your copy of windows or your system restore disk sometimes included with the purchase or you could ask the manufacturer of the computer for one usually available through the support department
Dec 04, 2010 | Computers & Internet
My cd/dvd burner stop working it won't read
Try cleaning the laser lens with alcohol and a Q-tip. If this does not work then the burner is tired.
Aug 11, 2009 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
Ps3 is not reading my discs
Hi my name is Juan and the problem you got is with the bluray laser lens they have stopped reading games you can check this out put a cd on your ps3 and at the same time place your ear on top cover and will heard 3 clicking noises of the laser but make no noise because this clicking noise is so fine that you need to make no noise it goes click click click you will hear it but make sure you put your ear on top cover at the same time you insert the disk it takes about 3 -4 seconds for the clinking noise after you have insert the cd some lasers they do try to read and they make the disk to spin off and on some they do make the disk to spin normally but nothing happen and the solution is to replace the laser lens I am a ebay trusted power seller and I can get you one if you want to
Mar 27, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 Blu Ray drive not working
Hi my name is Juan and the problem you got is with the bluray laser lens they have stopped reading games you can check this out put a cd on your ps3 and at the same time place your ear on top cover and will heard 3 clicking noises of the laser but make no noise because this clicking noise is so fine that you need to make no noise i goes click click click you will hear it but make sure you put your ear on top cover at the same time you insert the disk it takes about 3 -4 seconds for the clinking noise after you have insert the cd some lasers they do try to read and they make the disk to spin off and on some they do make the disk to spin normally but nothing happen and the solution is to replace the laser lens I am a ebay trusted power seller and I can get you one if you want to
Mar 16, 2009 | Sony PlayStation 3 40GB System
Player shows '' No Disc'' even when inserted with a disk
When player says no disk, even if the disk inside, and you hear a whirring and clicking noise when you insert a disk, that means that the CD lens is dirty or defective, and the CD drive cannot read the initial CD track, and returns no disk.
Try first using a CD cleaner disk, if that does not work, then you will need to take the apart the unit to clean lens with isopropyil alcohol and cotton sticks.
See also the following websites on how to clean the lens, use a cleaner disk first:
Gizmo Highway DIY - Clean your CD player lens
Lens Cleaning CDR CD-RW (how?)
DVD Not Working
Mar 04, 2009 | Sony Televison & Video
Does not read the disk
If when you insert the disk you hear a whirring and clicking noise, CD spins, and does not read, then that is a problem with the DVD lens.
The DVD lens try to focus on the DVD track, by moving lens pickup and spinning the disk, but cannot read the tracks because the lens is dirty or defective.
Try first cleaning the lens with a DVD cleaner disk. And also if you can see the lens from the outside try blowing some canned air on it.
If this still does not help, then the lens pickup may be faulty, in this case you often replace the whole DVD drive unit inside the DVD player.
Jan 07, 2008 | JVC RX-DV3SL DVD Player
Nintendo Wii Console Logo
633 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
