Question about Sony PlayStation Portable (PSP) Console
Hi , I have a Sony Psp2000 model. It worked 100%. It had a lot of scratches so i replaced it with a brand new cover.(front and back). Now the laser doesn't turn. There is a spring with a plastic cover that i think i didnt fit correctly just on top of the laser. Any help would be much appreciate. Andre varkie_2003@yahoo.com
  • varkie_2003 Feb 02, 2009
    i found the problem. the spring with the plastic connector just on top of the laser wasn't installed correctly. the spring should be in the cover on the right hand side and the left hand side the plastic cover must be on top of it( not inserted)
    My psp working now with brand new full covers
I dont get how the laser cant turn on a guess you have to take that thing off to make it work again!!!
Posted on Feb 01, 2009
I have put in a brand new drum and it still states drum life at end. What do I need to do?
With the front cover open, press clear/back., press 1 and when the LCD shows accepted, close the front cover and you should be all set.
I hope this helps you..
Aug 03, 2010 | Brother MFC-8440 All-In-One Laser Printer
I replaced the drum with a brand new one, but still get the drum end soon message
To reset the drum count follow these steps.
1. open the front cover (leave open).
2. Press clear/back.
3. Then confirm the new drum install by pressing 1.
4. The display will indicate accepted.
5. Then close the front cover
Jun 18, 2010 | Brother MFC-7440N Laser Printer
Screen problem
hi..... this is the only way with the touch screens
  • If the touch pad is scratch or cracked , you can replace the touch screen(touch pad/Digitizer) only.
  • The touch screen have the protect film on it,please remove the protect film before you use the touch screen .
  • Before you buy this item please check your touch screen model and make sure it's same as the photo.
  • 100% brand new.
Jul 15, 2009 | O2 Xda Atom
Psp laser doesn't turn
you should not tamper with those dude. better bring it back to where you had your covers changed, they might have missed on some things in reinstalling the covers.
Feb 01, 2009 | Sony PlayStation Portable (PSP) Slim...
To change opc drum in konica minolta
To Change OPC DRUM UNIT in KONICA MINOLTA 2300 w
Switch Printer Off
Open Front Door Cover
Remove Waste Toner Box
Lift Transfer Belts Blue Knob until it's placed at 11 o'clock. (it's directly behind the waste toner box)
The OPC DRUM UNIT is directly under the BLUE KNOB
SQUEEZE HANDLE and PULL OUT the OPC UNIT
Be VERY CAREFUL NOT TO SCRATCH THE GREEN COLOURED ROLLER on the OPC DRUM UNIT.
Replace new OPC DRUM and turn BLUE KNOB of TRANSFER BELT back to 7 o'clock position
Replace Waste Toner Box, Close Front Cover and Switch On.
Status Display will show OPC Drum at 100%
(You can also replace the fuse in the OPC DRUM UNIT and save yourself HUNDREDS on a new one)
I posted this on another solve problem previously, worth looking at.
Jan 06, 2009 | Minolta magicolor 2300W Laser Printer
Taking lot of time to load and hang while loading.
ensure the underside of the disks are clean, and scratch free.
Use a CD lens cleaner, to remove any dust/debris from the laser head.
If still fails, laser-head is weak or in need of re-calibration.
Mike @ Compurepair.
Jul 25, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 v13 disc error(not the usual fault though)new laser fitted and adjusted
Actually make sure you got a Brand new lens.On e bay or different place like that a lot people are selling lens for Brand New but they are not.
Have the antistatic point on the lens most of the time it doesn`t mean is new.I know a lot of laser are faulty because repaired or refurbished and can be one(of the most common) problem.
If you have any chance send back that laser for replacement.
Tweeeking the laser also is not a easy step.You need to know the exact value in Ohm about the laser and use a Multimeter to find out when the laser is in range.Tweeking to much will increase voltage on the laser and will burn it.
Try a different laser because motherboard error for only 1 format is not a common issue
Jun 05, 2008 | Sony PlayStation 2 Slimline Console
Toner life end message after drum unit replaced
I spoke with Brother and one of the options was to open the cover, push options, push start, and then 1, then 1 again. If accept comes up, select. Then close cover and try again.
Feb 06, 2008 | Brother IntelliFax-2820 Laser Fax
Ps2 cannot read any disc?
You might want to send it back to Sony for a replacement usually when the disc can't be read it's because the optical scanner is damaged and needs to be replaced.
Jan 09, 2008 | Sony PlayStation 2 (PS2) Console
Sony PlayStation Portable (PSP) Console Logo
20 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
