Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Roller Belt Keeps Slipping Off
I have a Hoover WindTunnel Bagless Canister Cleaner with Powered Nozzle. The belt that spins the Brush keeps slipping off. I've replaced the belt, knowing it may have stretched, and it keep slipping off. Upon further inspection, it appears a "tab" on the Brush Roll Cover that is supposed to prevent the belt from sliding off the spindle, has broken off. I can't find a replacement "Brush Roll Cover". Has anyone else experienced this problem or does anyone have a replacement part # or availability for the Brush Roll Cover?
  • Anonymous Feb 28, 2009
    It's Model S3765, Serial 090700070806
    Would really appreciate any light you can shed on this problem!
    "Hollywood"
  • Robert Pagliaroli May 11, 2010
    I have heard of the powernozzle's missing a metal tab that is a guide preventing this issue. However, If you can provide your model number and serial number I may be able to look it up.
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
You could try contacting Hoover for parts availability. If it's and older WindTunnel and Hoover no longer has the part, try eBay.
Posted on May 14, 2017
3 Suggested Answers
  • 126 Answers
SOURCE: Hoover WindTunnel Canister: Roller brush motor not turning
These motors have a fuse incorporated in the field winding and it sounds like that blew. These motors sometimes overheat at the front bearing and the bearing will melt into the plastic housing. This will cause the fuse to blow. It sounds like that's your problem. You can remove the motor by removing the three screws on the bottom of the powerhead and then check the front bearing for any bubbling or blistering in the plastic housing. The shaft of the motor should turn easily.
Posted on Jan 27, 2008
ThinkVacuums
  • 144 Answers
SOURCE: need help with Hoover S3765-040 WindTunnel
The belt could be stretched and that could be causing the slip. Or you could have the wrong belt if you've replaced it recently
Posted on Sep 04, 2009
Drive belt on Hoover U6434 keeps slipping off. Even new ones.
Check the motor shaft for residue from a previously burned belt. Also the brush roller may be defective.
Jun 08, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover windtunnel t series belt is loose- roller brush doesnt turn. Its brand new belt is slipping. we bough new belts and putthem on same problem. Can not find solutio in manual. Is the belt supposed to...
I also have a loose belt and have bought additional belts but have the same problem. I put the it around the metal rotor and around the brush roller a shown by he Hoover video, and it is loose.
Nov 28, 2010 | Hoover S3765-040 WindTunnel Bagless...
Hoover bagless cannister 3765 - belt on power head slips off spindle. bought new belts - same problem. is this a design problem or can it be fixed? I don't want to take it to a repair shop 100 miles...
I would not recommend a smaller belt. You will only wear the motor. This model series power nozzle needs to have a metal clip installed near the belt on the brush roller housing. I know that most of them left the factory without it. Remove the cover to see if one is ther. if not have your dealer send you a clip or a housing with one on it.
Apr 03, 2010 | Hoover S3765-040 WindTunnel Bagless...
HI, my motorized brush barely turns.It makes a hot rubber smell. I took apart and noticed the spindle the belt turns on discolored from heat. Cleaned it, but still no turning of the brush.The vac is a...
That means that the belt is stretched and it is slipping on the motor shaft, that is why it is hot and smells like burning rubber. You need to replace the belt. Here is the correct belt you need:
Hoover Windtunnel Canister Belt
Dec 24, 2009 | Hoover S3765-040 WindTunnel Bagless...
My daughter's S3765 bagless canister has good
That means that you need to replace the belt. Here is the belt you need for your model.
Dec 20, 2009 | Hoover S3765-040 WindTunnel Bagless...
Need help with Hoover S3765-040 WindTunnel Electronic Bagless Canister Vacuum. The belt that rotates the brush keeps slipping off. what to do?
Sep 03, 2009 | Vacuums
The belt on my hoover will not stay on. It falls
Okay. I would suggest that you have a problem with your roller brush. If the roller becomes clogged with hair/debris, the bearings will sieze, and sometimes even melt the plastic. the roller then has a difficult time turning and will break the belt. If the belt is slipping off, I would suggest that you either have a worn belt, the wrong belt, Or, your "windtunnel" (the half cylindrical insert the roller sets in) is missing. this insert has a "belt guide" that keeps your belt aligned. hope this helps!!!
Jul 18, 2009 | Hoover U5753-900 WindTunnel Bagless...
The belt keeps on slipping off causing the brushes to stop
Over time the belt stretches and gets to big to stay put all of the time. Get a new Hoover belt and install it. That will solve your problem
Jun 16, 2009 | Hoover S3755 WindTunnel Bagless Canister...
Belt will not stay on hoover windtunnel s3765
The Hoover Windtunnel™ Self-Propelled models have two belts, a flat belt and the V-Belt. This V-Belt is the one that drives the Brush Roller. After about three months, most belts stretch out causing them to slip. This means the brushroll turns slower or not at all and the self-propelled becomes increasingly harder to push. It is recommended that both belts should be changed at the same time.
May 23, 2009 | Hoover S3765-040 WindTunnel Bagless...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
194 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
