Only fans work on split system model ls-k2463hl earth breaker trips when compresor tries to start I own a Panasonic Heat pump model A18CKP6G with the same problem. The compressor was replaced last June and the breaker has been tripping eversince when it's raining or when it's humid outside. My repairman can't figure out the problem and my electrician confirmed it's not the breaker!
  • Ninjazx12r_r Feb 04, 2009
    Unfortunately, I can't access the outdoor unit; my condo is on the third floor and I don't have a ladder... I have to rely on the repairmen expertise... The company sent 2 different guys so far and neither one of them found anything wrong with the heat pump. The unit worked perfectly for 3 years and the problem started when the compressor was replaced last June... The breaker is a GFI
    President:
  • 1,214 Answers
Sounds like a wiring problem between the outdoor unit and the house. You would be surprised what I have come across in 30+ years of A/C work.
But it could also be the compressor.
I will need to know answers to the following -
Does the compressor have a soft start (2 wire capacitor looking device that attaches to the run capacitor), hard start (relay and capacitor), or just the run capacitor?
Were the run capacitors and start components replaced when the compressor was replaced?
Is the breaker a GFI breaker, or just a standard breaker?
Rain or humidity is not usually a factor, but it may be something.
Reply back what you find.
Posted on Feb 01, 2009
  • Mark Egan Feb 04, 2009
    Well,
    Being on GFI is an issue. I am not aware of any code that requires the outdoor unit to be on GFI, although local codes may require it.
    So, if it has to be on GFI, then the techs that are coming out need to understand how a GFI works. Otherwise, they won't know what to look for. Wiring terminations is much more critical, to the point that all wire nut like connections need to be taped and waterproofed.
    All electrical panels need to be properly in place and screws tight, using the correct screws.
    All conduit based wiring needs to be properly routed through bushings and fittings, with no bare wire exposed to any chassis ground.
    Too bad you can't get up there to see for yourself. Sometimes tech's can't see the forest for the trees, and their desire to repair isn't as great as yours. They can go to a nice warm home everynight.
    Let me know what you find.
I have a tcl split system air con when you turn it on it runs for a while then when the compressor and fan come on it blows the circuit breaker at the meter box.
in most cases like this (circuit breaker tripping at compressor switch On ) compressor is burnt out ! A Meg ohms test Leakage to earth would confirm this
Nov 02, 2017 | Heating & Cooling
Hi my home Elec furnace - heat pump.my hpump tripping breaker .i do replace new motor fan, defrost board and relay,new breaker .but it still tripping when furnace call heat on. So what the problems ?
You did not post the make and model number! You said you replaced the fan? The compressor and motor for the fan both use a start capacitor.
Feb 22, 2017 | Heating & Cooling
I have a panasonic model nn-sd277 microwave. I changed the fuse and now it has power again. The fan and light all work. It trips my breaker and sometimes blows the fuse when you try to heat anything.
time to take it to an appliance repair shop for a quote
it is blowing fuses and tripping breakers because it has a serious short in the electrics
Jan 03, 2016 | Panasonic Microwave Ovens
GW708U Fisher and Paykel Washing machine Power Controller board trips earth leakage breaker
Hi your pump may be leaking the earth to trip breaker.
Check or replace the pump.
Feb 04, 2013 | Fisher and Paykel Washing Machines
Ac unit wont come on the breaker was tripped, reset the breaker, checked the unit for 220 volts has the correct voltage. The unit is a split system heat on one side ac on the other. The blower motor wont...
hello
maybe you have over current .compressor act over loud.
you wait was cooled compressor .than start again and check current and over loud and condenser fan.
Sep 06, 2011 | Friedrich WallMaster WS07A10D Air...
Heat pump fan not blowing
If this is a split system heat-pump with the indoor unit on the wall, and you have the outdoor unit, is it the outdoor fan you are talking about?? If so, more then likely if you have power to the unit, the motor is faulty or you could have a bad, shorted, or leaking run capacitor.Make sure the outdoor unit didn't trip a breaker. Find out where the breaker box is and it should be a double pole breaker. It will be in the halfway position if tripped. Shut it off hard and back on hard. This should start it up. If its not the breaker, you can pull the panel off the unit if you are mechanically inclined and look for the run capacitor. Depending on the age, it may be round and made of a shining steel, or gray plastic with 2 to 3 wires coming out of the top. Make sure the breaker is off and even if it is off they still can shock you if you touch the wires. Look it over to see if it is bulging, swelled up, or you see oil anywhere on it. This will be the problem. Check all of these things I have asked of you and get back to me. Let me know what you have found and hopefully it is just a breaker. We will go from there.
Sincerely,
Shastalaker7
Feb 21, 2010 | Heating & Cooling
Fujitsu split system not working
Hi, I know its a split as you have noted, and I am sure it would be a ductless heat pump system. Unless you are having a problem programming the t-stat, the manual would be of little help on these units.I wish you would have given more on the symptoms, like does it blow cold air or either unit will not work? You say it will not heat. On a H.P., it could be many things.Lets say its blowing cold air. Check the outdoor unit to make sure it comes on in the heat mode also, and the fan is on.Make sure you turn the heat up far enough to bring on the outdoor unit 1st. If it doesn't come on, then find the breaker to see if it is tripped. If yes, turn off hard and on again hard. if it stays on, great. If not, then It gets more complicated as compressor may have shorted out. Please check these things for me, please so we can solve this for you. On a heat pump, if you loose a compressor lets say, you have electric heat strips in the indoor unit that should come on if you have a switch on the T-stat that will say emergency heat. Try and use this setting to see if you can get some heat. I am trying to offer a solution to get you some temp. heat until we locate the main problem. If the indoor or outdoor units are not running at all, check for power at all breakers, and, check program on t-stat to make sure you set on heat, fan to auto, and temp to where you are comfortable.From here after checking all of these solutions, let me know what the status is and if it did not work, to tell me more of the original symptoms so I can go from there. Best of Luck,
Sincerely,
Shastalaker7
Nov 21, 2009 | Heating & Cooling
Model ls-k2463hl runs as soon as power is turned on at circuit breaker fan speed goes up and down
you possibly have a motor that the windings are bad. These windings swell when power flows through them and in turn the swelling presses onto the shaft causing the problem. Also, I would replace the capacitor first in the event it is bad If the motor runs properly then that capacitor is the only problem. If it doesn't cure the fan problem then the motor is going out. If you change the motor the capacitor will also need to be changed anyway so try changing capacitor first. Good Luck hope I helped you some
Dave
Sep 07, 2009 | Heating & Cooling
My GE ductless system is not heating properly and trips breaker
Call them yourself. Let them know your compressor is tripping your breakers. Also, ask how to obtain parts for your system. It's rediculous an hvac tech cannot get advise from ge.
Dec 05, 2008 | GE Quiet-Aire Ductless Split System Air...
Does the compressor try to start and the shuts off or is the breaker slamming off as soon as it is turned on. If it takes a few seconds the comp could be locked up and trying to start, high amps and tripping breaker. Tripping breaker right now would indicate a shorted or grounded compressor. Really would need to be ohmed out with a meter to check for ground. Not good either way.
Apr 25, 2008 | Heating & Cooling
Heating & Cooling Logo
123 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
