Question about Kenmore Elite 45986 Front Load Washer
Kenmore HE5t F11 error, find part.
Hi, a Sears tech came to my hose an said I have a bad motor board,they said it would be U$800,00 to fix it. Could you help me to find the part so I can fix it by myself?
model # 11047086600
thech left a ticket saying part 26 110 cc 8183196 1 U$ 537,70
Thank you,
Rodrigo Silva
  • 1 more comment
  • farofino10 Feb 05, 2009
    Thank you for helping me saving money.
    I already have the part, now I need help finding how to repair it by my own.Do you think you can help me with any video or instructions?
    Thank You again
    Rodrigo
  • Anonymous Feb 15, 2009
    model kenmore HE4T ,not draining,
  • llbuckie Apr 06, 2009
    I have Model Number 110.47089600 (Kenmore HE5T) would the mcu for my model number also be part number 8183196?
  • 5,911 Answers
If the problem is, indeed, the Motor Control Unit, you can find this part at appliancepartspros.com for about $243. Still a bit expensive, but far less than the $800 repair quote you got. Go to the website and search by part number. Use part number 8183196. I hope this helps you. If you require further assistance, please let me know.
Posted on Feb 02, 2009
  • Jeff Rockwell
    Jeff Rockwell Feb 05, 2009
    This should be a very simple process of repair. All you have to do is UNPLUG the washer and remove the back panel. The Motor Control Unit (MCU) is located on either the right or left hand side (depending on model) of the bottom of the washer. Simply disconnect all electrical connectors and loosen the mounting screws that hold the MCU in place. The entire board should slide out at that point. Install the new MCU using the same procedures in reverse order. NOTE: Avoid handling the circuit board. Hold the edges of the board when installing to avoid Electrostatic Discharge (ESD) - which is caused by static electricity in your body. This can potentially damage circuit cards.
    If you have questions, please let me know. I hope this helps you.
For Kenmore 7903019400 wall oven error code F 11, the touchpad/keyboard is the replacement part called the clock/timer? as clock/timer or range control panel are only parts listed? so which part is it
F11 means a shorted button on the button board. This could actually be a shorted button, or it could be a bad connection to the embedded microprocessor. There is literally no way to tell without actually testing the unit. If the EOC module (electronic operator control) comes with a button pad, change them both out if you can't test them separately. Kenmore has other manufacturers make their equipment for them (frigidaire, whirlpool, electrolux, etc), so the generic equivalent board may be cheaper to buy somewhere else than sears. Your local appliance service center will know what parts fit what sears models. The model number you provided is useless to me. 25321842-21syibu3fgwpdxocjnkpw0ib-3-0.jpg
Dec 14, 2014 | Kenmore Kitchen Ranges
We have a Kenmore Elite Quiet Pak 4 Washer that we have had for 5 years. It has been flashing F11 and DL back and forth for months. We had a tech come out (not sure he knew what he was talking about) and...
The symptoms are pretty specific for the F11 code on the Whirlpool Duet front loaders and clones (Kenmore Elite and KitchenAid):
If the washer starts to fill but the drum NEVER moves, your MCU is bad
If the washer runs through most of a cycle and then gives the F11 before (or during) a rinse or spin cycle, then you have the CCU relay problem.
If you are interested in having me repair your CCU for you, I offer that service on eBay (website coming soon). My username there is "jhagner"
Thanks
Aug 19, 2011 | Kenmore Front Load Washer
Hi After a year of using my Kenmore Elite HE5T washing machine, Model #110 47789701, serial #CSW2733428 I am getting an error F35 and Sub. Could you please let me know how to fix it? Thanks Barb
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Jun 15, 2011 | Kenmore Elite HE5t Washer
When starting washer i get a code F11
In general for Kenmore (Whirlpool) washers 'F11' means 'communication error (control unit)' which sounds bad BUT can often be cured relatively easily. It can be caused by poor connections between the control unit, cables/plugs/sockets and other parts in the washer. The cure is to unplug and re-plug the cables/plugs/sockets such that the connections are cleaned by the act of doing it.
The down side is that it will probably require an engineer's visit, sorry ;-0(
Good luck,
John C
Apr 06, 2011 | Kenmore Elite HE5t Washer
I have Kenmore HE5T Error code F71 Pls advise handling. Thanks.
F71 points at a connection error between button pad and control board.
Please read the indications in this article: F70 and F71 are two logic board error codes...
Regards.
Nov 07, 2010 | Kenmore Elite HE5t Washer
I have a Kenmore HE 3t front loading machine. It's 5 years old and I'm getting an F11 error and I can't complete the cycle.
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancell, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech
Aug 18, 2010 | Kenmore Washing Machines
Code F11
Hi, F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancel, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the pre-wash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech.
Take care
Jun 03, 2010 | Kenmore Elite 45986 Front Load Washer
F11 error code
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancell, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech.
Good Luck!!
Thanks
Jun 28, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE5t Washer Error Code F11
Jan 03, 2009 | Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
642 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
