Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
How do i unglog a paper jan
Paper was down to 3 sheets. while printing 1 sheet it sucked in all 3 sheets. Paper was torn off from the bottom & top but behind the barrel sort of speak the paper is still stuck. please help ! Any suggestions will be very appreciated, also any comments. Should I just toss this gadget or is there a solution ?
  • mkrsklaw Feb 27, 2009
    After resolving a paper jam by removing the paper from where you install the ink, the printer went OFF and won't turn back on! HELP.....is it done?? Time for a new one?? It's only 4 months old.
You need to open the top (the way like put your ink in) in the right corner you'll see paper. pull on it, whether when the top is open, or where the paper comes in!!!
goo luck!
Posted on Feb 01, 2009
Feel like an idiot...does the paper load with the print facing downward or upward?
You didn't say what brand and model printer you have so I can't look up a manual and check it for you. But if you don't want to waste a sheet of good stationery or a valuable form (like checks), make a test sheet. Take a plain sheet of paper and mark it along the top edge. Or use a photocopy of the form as a test sheet. Put the test sheet into the printer and print something on it. From the result you'll know how to feed the sheets in the future.
Mar 31, 2011 | Office Equipment & Supplies
The paper keeps jamming, I cant see anything in the way. any help is appreciated.
If paper doesn't feed correctly when printing, remove it and fan the edges of the paper to separate the sheets. Reload the paper against the right side and slide the edge guide against it. Do not load too many sheets at once.
If paper has jammed: 1. Press x Start to eject the jammed paper. 2. If paper is still jammed, gently pull it out from the output tray or sheet feeder. If paper is stuck inside, press the P On button to turn off the printer. Then lift the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the printer back on.
If documents don't feed correctly in the Automatic Document Feeder, make sure the corners of the paper are not bent, folded, or curled up. Do not load more than 10 sheets of legal-size paper at a time. If documents have jammed: 1. Open the ADF cover and pull any paper out to the left. Caution: Do not try to remove the paper without opening the ADF cover first, or you could damage the mechanism. 2. Select Yes or press OK to clear any messages on the display screen. 3. Reload the paper.
Feb 28, 2011 | Epson WorkForce 600 All-In-One InkJet...
How to install paper in oki microline 320 turbo printer
Paper Loading
Rear Feed, Continuous Forms
Use the rear-feed path for printing on single-thickness,
continuous-form paper.
Use the single-sheet path (top feed) for graphics or charts.
! If you have paper in the paper path, be sure to remove it
before installing rear-feed paper.
1 Lock Lever
2 Upper Tractor Cover
3 Pins
4 Lower Tractor Cover
32T-26.eps
1 Move the paper lever to the position marked "REAR."
32T-11.eps
2 Grasp the tabs lift off the paper separator.
3 Pull up on the lock levers and open the tractor covers.
Then, move the right tractor to fit the width of the paper.
32T-27.eps
4 Place the first two holes in the paper over the tractor pins
on either side. Close the tractor covers.
32T-29.eps
5 Move the left tractor to align the edge of the paper with
the appropriate reference mark (1). Then, push back the
lock lever.
32T-29A.eps
6 Adjust the position of the right tractor to center the holes
in the paper on the pins. Then, push back the right lock
lever.
32T-29.eps
7 Install the paper separator. Place the wire guide (1) on the
pull-up roller assembly (2).
32T-31.eps
8 Press FF/LOAD. The paper feeds into the printer.
! The factory default setting for the Top of Form (where
the printing should begin) is one inch down from the top
of the page. To change the setting, see "Using Your
Printer, Top of Form (TOF)."
Top Feed (Single Sheets)
Use the single-sheet path for letterhead stationery, memos,
and individual envelopes.
! If you have continuous-form paper in the path, press
PARK to remove it before loading single sheets.
1 Make sure the printer is on and deselected (SEL light off).
2 Place the paper lever in the position marked "TOP."
32T-12.eps
3 Open the carriage cover. Raise the paper separator to the
single-sheet position.
4 Make sure the wire feed guide (1) is secured in the sheet
guide.
5 Adjust the paper feed guides (1) for the width of the paper.
Place a sheet of paper in the separator. The paper will feed
into the printer.
32T-15.eps
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Jan 04, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
Hp LaserJet 4100 printer says its out of paper which is not the case, could someone assist me and figure what may be causes this problem? Thanks in Advance
Paper jams can occur in the following areas
1 Top cover and toner cartridge area
2 Optional envelope feeder
3 Input tray areas
4 Optional duplexer
5 Output areas (top and rear)
6 Fuser area
Solving repeated paper jams
* Check all the paper jam locations. A piece of paper might be stuck somewhere in the printer. Even a small torn piece of paper in the printer path can cause repeated jams.
* If using a duplexer, check all areas (including under the duplexer).
* Check that paper is correctly loaded in the trays, that all three adjustments have been made, and that the trays are not overfilled. Make sure paper is under the front and back tabs.
* Check that all trays and paper handling accessories are completely inserted into the printer. (If a tray is opened during a print job, this might cause a paper jam.)
* Check that all covers and doors are closed. (If a cover or door is opened during a print job, this might cause a paper jam.)
* Try printing to a different output bin.
* The sheets might be sticking together. Try bending the stack to separate each sheet. Do not fan the stack.
* If you are printing from tray 1, try reducing the size of the stack.
* If printing from the envelope feeder, make sure it is loaded correctly, pushing the bottom envelopes in slightly farther than the top envelopes.
* If you are printing small sizes, feed paper short edge first.
* Turn over the stack of paper in the tray. Also try rotating the paper 180°.
* Check the characteristics of the media you are using. Use only paper that meets HP specifications (see the online user guide for paper specifications). Try using different paper to see if the problem goes away. Do not use curled, deformed, damaged, or
irregular paper.
* Avoid using paper that has already been used in a printer or copier.
* Do not print on both sides of envelopes or transparencies.
* Print only on full sheets of labels and do not print on both sides of label sheets.
* Check that the power supplied to the printer is steady and meets printer specifications (see the online user guide for printer specifications).
* Clean the printer (see the online user guide procedures).
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 09, 2009 | HP LaserJet 4100 Printer
Paper won't feed
Inside of the machine is dirty.
If the inside of the machine is dirty, the printed paper may be smudged.
Follow the steps described below to clean the inside of the machine.
1. Ensure that the machine is turned on and there is no paper loaded in the Auto Sheet Feeder.
2. Place A4/Letter-sized plain paper in landscape orientation, horizontally fold it in half.
3. Unfold the paper, and load the paper in the Auto Sheet Feeder with the inverted-V edge down.
4. Select <Bottom plate cleaning> from <Maintenance>.
5. Select <Yes> on the Bottom plate cleaning confirmation screen and then press [OK].
Paper will be ejected.
If protrusions inside the machine are stained, wipe ink off the protrusions using a swab or such like.
* Important
Before cleaning, be sure to turn OFF the machine.
Paper feed roller is dirty.
Follow the steps described below to clean the paper feed rollers.
1. Ensure that the machine is turned ON and there is no paper loaded in the machine.
2. Select <Roller cleaning> from <Maintenance>.
3. Select <Yes> on the Roller cleaning confirmation screen and then press [OK].
The paper feed roller will rotate as it cleans.
4. Repeat this operation twice.
5. Load three or more sheets of A4/Letter-sized plain paper lengthways in the Auto Sheet Feeder.
6. Select <Roller cleaning> from <Maintenance>.
7. Select <Yes> on the Roller cleaning confirmation screen and then press [OK].
The paper that is loaded in the machine will feed through the machine and be ejected.
8. Repeat Steps 5 to 7 three times.
Inappropriate paper type is used.
Check to see if the paper you are printing on is too thick. See Paper Types You Cannot Use.
Note that smudging may occur at the top and bottom edges of the paper when using Borderless Printing. Ensure that the paper you are using is compatible with Borderless Printing.
Thick paper is used.
When printing on thick paper, set the Paper Thickness Lever to the right.
This widens the gap between the FINE Cartridge and the paper. Try this maneuver if the printed surface is scratched.
Media is curled.
If all four corners or the printing surface of the paper is curled, the paper may become dirty or may not feed properly. Use the paper after correcting paper curl as follows.
1. Place the printing surface face up (A), and cover it with a sheet of non-printing regular paper to avoid damaging the surface.
2. Roll up the paper in the direction opposite to the paper curl as per the figure below.
3. Check the printing paper to confirm if the paper curl is eliminated to within approximately 2 to 5mm / 0.08 to 0.2 in (B).
It is recommended to print on curl-corrected paper one sheet at a time.
The media type is not selected correctly in the printer driver.
On the [Main] tab of the printer driver, ensure that the [Media Type] selected matches the paper loaded.
In the [Print] dialog box of the printer driver, select [Quality & Media] from the pop-up menu, and then ensure that the [Media Type] selected matches the paper loaded.
Paper is loaded incorrectly.
Load in the portrait orientation regardless of the print direction of the Auto Sheet Feeder.
Ensure that paper is loaded correctly. Slide the paper guides against the paper stack.
Oct 18, 2009 | Canon Pixma MP500 All-In-One InkJet...
The printer is feeding a blank sheet of paper between printed sheets. How do I rectify this?
This causes the printable area on the page to be that much less (10 3/4 or 10 1/2 on an 11 inch page). The software thinks the paper is 11 inches long and keeps track, down to the micro inch, where it is on the paper. When it reaches the 10 1/2 inches, your printer calls the page done and ejects it. However, the software thinks there is still another 1/2 inch to print (usually the footer area). Now when you insert a new sheet of paper, the software finishes printing the rest of the page (normally a blank footer) and form feeds to the next sheet. To correct what the software thinks the paper size is, you need to run the Preferences application and change the default settings. Select the Printer button. In the next window, select the 'Change Defaults....' button. Change both the Document size and the Paper size to a height of 10.875 and click OK. Try a new document to see if the paper size is correct. You may need to go back and change the height a few times until it is correct (the height changes in .125 increments). Usually either 10.875 (for 1/4 inch forced top margin printers) or 10.75 ( for 1/2 inch forced top margin printers) will work.
Oct 13, 2009 | HP Photosmart C6180 All-In-One InkJet...
Duplex mode, paper retracted and DISAPPEARED!
For duplex the paper feeds into the bottom paper tray, you need to make sure that paper is not stuck in the bottom area.
Jul 22, 2009 | Canon PIXMA MP530 All-In-One InkJet...
PAPER JAM AND ERROR MESSAGE
20 pound is the right paper, if you can't reach the paper scrap with tweezers or anything, you should take it to a Canon shop since you have a one year warranty. 1-800-OK Canon can tell you where the nearest shop is...
Jul 03, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Paper jam
The print roller can be turned by hand but do not move the print head by head to the left or right -just make the roller turn either way. Try line feeds first. Steve Medley
Oct 27, 2008 | Epson Stylus Photo 950 InkJet Printer
Paper Jam on
most printers are pretty cheap now so replacement is always an option....on the other hand, I will spend countless hours trying to figure out what is wrong first. Remove all paper first, open printer and check for pieces of torn paper or debris, if you have a can of air you can blow out the insides to clean. Put 3 or 4 sheets of paper in, print a test page and watch carefully how paper advances...is it straight or crooked when being loaded? Is printer trying to pull more than 1 sheet at a time? Good luck
May 14, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
