I have a westinghouse monitor flat screen, yesterday it starting looking real faded out and now it is going white......i can turn it off and back on and it will be there and then just fade to white again
    Scholar:
  • 164 Answers
Unplug it for 20 minutes.
do you have another monitor to see if it is the computer?
Posted on Feb 19, 2009
I got the westinghouse LCD monitor model L2140NM several years ago. Yesterday the monitor got hit on the screen and it does not work. How much would it cost to repair? the screen is cracked and needed to...
hi, i'm actually looking for a broken westinghouse l2410nm monitor to fix mine. if you're interested in selling yours shoot me an email at mymaries1806@gmail.com. parts are hard to find for this monitor especially the screen itself. thanks for you consideration.
Sep 04, 2010 | Westinghouse L2410NM 24 in. LCD TV
No image on monitor model LCM- 19v7
Look for bad capacitors (bulging top/seal) in the power supply first, post back what you see inside so we can guide you further, see example of failed Westinghouse monitors due to bad caps; http://s807.photobucket.com/home/budm/allalbums
Mar 13, 2010 | Westinghouse 19" Widescreen Flat Panel LCD...
Westinghouse SK26H240S - Sound works but no picture?
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 27, 2009 | Westinghouse SK-26H240S Television
Monitor stays white, cannot get picture
U might have problem with ur VGA cable. It may be loosely plugged. Plug it tight
Jun 24, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
Buttons on the bottom of the westinghouse monitor
momof3boysn1, Did you try removing the plug from the outlet strip and then plug monitor back in and turn it back on? Usually the button that looks like an asterisk with a small circle dead center will be the brightness control. get back to me if this won't help. I'm louie12fix on fixya or lmistyrel@ aol.com
Apr 05, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
Monitor fades and turns blue
this sounds like a transistor issue concerning the ccfl lamps the power transistors are deteriorating and they will eventually go bad you can have them replaced and that should fix the issue. otherwise I would say have the capacitors that feed the ccfl's may be getting old and need replacement as well, its not something the average customer will want to do but if you have a service center that does electronic repair then that would be bst.
Hope this helps
Jan 30, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
Monitor flashes on when I turn computer on, then screen black
Your monitor power supply or inverter board have gone bad. Its not your computer video card
Apr 17, 2008 | Westinghouse LCM-19v1 Monitor
X223W LCD Monitor, white background too harsh
Try setting the font smoothing to Clear Type.
Feb 06, 2008 | Acer Aspire 3690-2196 Notebook
245BW monitor not working (stranges colors ad aeternam...)
I had the same problems as almost all of these people and the answer seems to be that I uninstall the current Nvidia Drivers and use a previous set. The 169.28 were a real problem for me. Just when I thought it was working I would get the strange wash out and I could not turn it off except with the back power switch, aslo using the DVI turns off all the on screen controls.
Good Luck
Dec 27, 2007 | Samsung SyncMaster 245BW Monitor
Westinghouse lcd monitor 19" - screen turns white
I have the same problem with my LCD tv... The DVI-D (white connector in the back) and the D-SUB (connector on main-board next to the DVI-D) work great for my computer. However, the antenna returns only a white screen no matter what I plug into with it using a coaxial cable. Judging by the modular configuration on the TV (1 main board with LCD monitor attached to it and the 2 computer inputs, and a smalled board on the back with the antenna, component video, S-video, mini-jack out, and composite video.) I think the smaller board which I believe is called a "NR Unit" is what has failed. I took off the back mini-panel of the TV off, which just slides off when you press down 2 tabs. And, I found the small board which is only held down by 5 small screws, and it pops right off. So, if you can find a NR board from westinghouse that works, it's a quick and easy (hopefully inexspensive) replacement. Hope this helped.
Oct 13, 2007 | Westinghouse LCM-19v1 Monitor
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
