Question about Denon Audio Players & Recorders
Denon POA 2800 Amp
The amp heats up considerably on one stage, too hot to touch; and then shuts down (protection I assume). It appears it will need professional repair.
Suggestions / recommended shops in NH /VT
  • 44 Answers
Try these links
Hope this helps!
SEO EXPETS - Increase Search Engine Ranking / Position
Posted on Dec 16, 2007
SOURCE: Denon AVC-A1SE in protection mode
After thorough cleaning of the speaker leads, PC Boards etc, I desoldered all the leads of the main two power transistors of the Left channel that had given problem earlier. Switched on the amp and bingo, it did not go in protection mode which confirmed that the two power transitors were the culprit. After checking the voltages and values of some other vital componenets vis-a-vis remaining left channels, it was confirmed that the circuitry was okay. The power transistors were checked again and found to be okay as well. I then took a chance and resoldered not only these two Left channel power trnasitors but also resoldered all the leads of all the other power transistors as well.
The amp was switched on again and this time also it did not go into protection mode. The amp is working fine. Problem could be either dry solder or short of power transistor leads by stray solder waste strand. There was no need to change any part which was great.
Thanks for help anyway.
Posted on Nov 30, 2008
  • 113 Answers
SOURCE: kicker zr120 amp shutting dowwn protection light coming on
put a 12 volt fan on it
Posted on Jul 04, 2009
  • 8404 Answers
SOURCE: need owener's manual denon poa 5000
You look here at all?
Posted on Sep 27, 2009
  • 1175 Answers
SOURCE: Repair Manual for Denon POA-2400
Posted on Apr 18, 2010
AVR 2800 powers up and shuts off and lite blinks
Generally speaking this means a fault in the power output stage of the amp, which is the part in the pcb where the Output Transistors and the Aluminum Heatsink are, hope this helps.
Oct 19, 2013 | Denon PMA-2000R 2-Channel Amplifier
Why do i have to power on and off my times with my denon receiver before it connects/
That is called the protection mode, Because of a internal problem with the amp, That is causeing it to over heat, End shut down,
Dec 02, 2012 | Denon AVR-1907 Receiver
When i tun on my DENON avc-2800 amplifier it comes up with 'protection'. How do i fix this
Please see the link below for an explanation of Protect mode. Specific to your model, the output transistors are likely to be shorted. This particular model will shutdown the entire unit if any of the channels have a problem. Without actually seeing the unit and taking some internal measurements, I cannot state for sure the parts required for repair. I would expect a parts cost in the $20-$40 range minimum.
Oct 16, 2010 | Denon POA-8300 3-Channel Amplifier
THe word Protection is coming across the screen instead of input or other
Dissconnect the speaker wires. If you still get the protect message you have a bad output stage in one of the amp channels. If the message does not appear you have a shorted speaker wire or a bad speaker. If the amp is bad you could still have a bad speaker or shorted wire that could have caused the amp to fail. Resolve this before reconnecting to the repaired amp or failure will reoccure.
Oct 31, 2009 | Denon DRA-685 Receiver
My denon avr-1906 amp will not turn on correctly. When the standby button is pressed the indication surrounding the button flashes green but when you hear the relay click in for presumably the power amp,...
The amp is shutting down to prevent further damage. This is what is sometimes referred to as protect mode. There is a problem with the final stage of the amplifier. The most common parts that fail are the output transistors. Figure on $15-$40 in parts plus the local labor rate for the total repair cost.
May 30, 2008 | Audio Players & Recorders
My denon avr-a10se stop working. When I start, aftr thr quick intiation the amp shuts itself and the red power light start to blinvk quickly - please help
This unit is in protect mode. This means that a problem was detected in the last stage of the amplifier section and the unit shuts down to prevent further damage. The most common failure parts are the output transistors. These usually run between $5-$15 each. Add in the local labor rate for the total repair cost.
May 20, 2008 | Denon Audio Players & Recorders
I have the denon avr3600, the protection is on, how can i turn it off, thanks
Unfortunately you can not just turn it off. Protection means that a problem was detected in the final output stage and that stage was shut down to prevent further damage to either the amp or the speakers. The typical problem is either the output transistors on one channel or the output amp chip for one of the surround channels. Expect a parts cost of about $25-$40 plus hte local labor rate for repair.
Apr 07, 2008 | Audio Players & Recorders
Power Button Flashing Red
Check to make sure the +/- speaker output wires aren't touching. I've had this problem before with frayed speaker wire strands poking out & intermittently shorting to the other polarity speaker output. This amazing receiver actually continued to play at low volume levels, but if I turned it up it would shut down similar to how you are reporting. I cleaned up the frayed wires & this fixed thr problem. Good luck
Mar 02, 2008 | Denon AVR-2105 Receiver
Receiver shut down only when using phono preamp
You may want to try putting an attenuater in the line with the RCA's to cut the input signal back just a little bit. So you are not driving the amp so hard with your preamp.
Sep 08, 2006 | Denon AVR-2803 Receiver
621 people viewed this question
Top Denon Audio Players & Recorders Experts
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
