Question about Acer Aspire 6920 Notebook PC
Problem with xternal volume control on my acer aspire 6920
I left the computer alone for 30 mins and when i returned all the buttons on the external volume panel were lit up and I was unable to use it.
  • 22 Answers
Without any more info I would reboot your machine.  If you cannot reboot through normal process, hold power button until machine turns off (about 5 seconds), then turn back on.
Posted on Feb 01, 2009
Acer aspire 6920 11.1 v battery work but 14.8 v wont charge why is this
Check model numbers, I had this problem with apple, to of the same laptops two differnt batteries
Apr 03, 2017 | Acer Aspire 6920 Notebook PC
Sound volume frozen on acer
That is a software issue, do a system restore of the computer bringing it back in time before this happened.
Apr 11, 2012 | Acer Aspire 6920 Notebook PC
Hi, Cant boot up my Acer 6920, regular start up or in safe mode. Just takes me to a black screen.
Hi. Try to perfrom power drain to your netbook. Take out the battery then unplugged the power adapter. Press and hold the power button for 30 secs. Put everything back in then turn on the computer. If same problem will happen then you need to contact ACER and have your computer srviced for LCD problem.
Oct 11, 2010 | Acer Aspire 6920 Notebook PC
A green volume control line has appeared overlaid at bottom of screen. control panel to left of keypad no longer works.volume is constantly on full. how do i remove it.
At this point I would suggest you a full factory reset. You can restore the computer back to factory default,to do so, follow the below steps:
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
Jun 26, 2010 | Acer Aspire 6920 Notebook PC
I killed the left click.
Not really, there are two possibilities here.....one is that the sticky residue has jambed the plastic button against the side of the palrest or that the actual button circuit under the plastic button tab has collapsed and will not return to up. In either case, it sounds like the palmrest will have to be removed. It is not overly difficult job to perfrom if you have a proper guide. Below is a link to the service manual for the disassembly. If the circuit board is damaged, it is cheaper to just buy the palmrest on lets say ebay then to try and find just the touchpad board. Palmrests go for about 20-25 bucks. Click on the link below, when it comes up, if the print is too small....hold down the control key and tap the + key, this will make the print large, the file is PDF format and is free to copy, print and use.
http://tim.id.au/laptops/acer/aspire%206920.pdf
Jan 12, 2010 | Acer Aspire 6920 Notebook PC
Volume control frozen
upload a new driver, or install it again
Dec 20, 2009 | Acer Aspire 6920 Notebook PC
Acer Aspire 6920 touch volume not working
aright what you gotta do is open up the "launch manager" which enables all the buttons found on the multimedia area plus else where to work perfectly. this even lets you program which applications you want to have when you press the other buttons
Jul 23, 2009 | Acer Aspire 6920 Notebook PC
Acer Aspire 6920 will not turn on. With or with out hard drive inplace. Pushing power button makes the keyboard lights come on but not the computer screen or hard drive. Pulled hard drive and connected to...
I had same problem with my aspire 6920.Tried power reset didn't work. Tried replacing memory chips,No go . Pulled rest of my hair out,still nothing . Then I checked memory chips again and noticed that the inner chip was not seating correctly due to a design flaw in the retainers. Gave both retainers a gental tweak,reset chips. And most importantly Disconnected CMOS Battery and held power button in for 1 min. Plugged everything back in and Bingo... Fired right up >>>And to the comment about plugging in the HD ....Mine fired up with out it ..
Jun 18, 2009 | Acer Aspire 6920 Notebook PC
Acer aspire 6920
go into control pannel, blue tooth devices look through the fomats and if you have bloue tooth it will show up. set up and go. is it 6920G its there
Jan 10, 2009 | Acer Aspire 6920 Notebook PC
The volume on my acer/ aspire 6920 is working the volume on the left hand its stuck all the way and its all blue please help
*Request to reinstall sound driver after uninstalling previous one from add or remove programs in control panel
thanks
Jul 30, 2008 | Computers & Internet
Acer Aspire 6920 Notebook PC Logo
221 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
