Question about Creda IWD12 Front Load Washer / Dryer
Creda dryer belt
Hi i have had a creda dryer t520vw belt break 1866mm. I ordered a replacement part which came but is 1860mm. i have squuezed it on the motor but the rear of the hub has lowered slightly and it will knock against the motor housing if turning. How can i solve the problem please?
  • 547 Answers
Release tentsion from belt pulley
Posted on Feb 12, 2009
How to put belt on hotpoint dryer
Dryer Belt Replacement - YouTube
? 6:23
https://www.youtube.com/watch?v=dFB4vnmADh0
Jun 20, 2011 - Uploaded by Repairs101
How to do-it-yourself instructional on changing the drive belt on an electric ... She wanted to know about replacing the drive beltin her clothes dryer. ..... How to replace tumble dryer beltHotpoint, Indesit, Ariston, Creda, Proline ...
How to replace tumble dryer belt Hotpoint, Indesit, Ariston ...
? 9:36
https://www.youtube.com/watch?v=kNJGHyEPiJA
Jan 30, 2014 - Uploaded by how-2-repair.com
How to replace tumble dryer belt Hotpoint, Indesit, Ariston, Creda, .... to get right and the grooves correspond to the drive, so really obvious..
Dryer Drive Belt (part #WE12M29) - How To Replace ...
? 5:14
https://www.youtube.com/watch?v=ZXSJlWcZPiY
Oct 25, 2013 - Uploaded by AppliancePartsPros
Buy the new Dryer Drive Belt WE12M29 ... to replace the Dryer Drive Belt WE12M29 on GE, Hotpoint, RCA, Sears, and Kenmore dryers.
Jan 01, 2016 | Hotpoint Dryers
How to fit belt on Creda Reversair 37643 Tumble dryer
New belt is very tight, so you have to use more strength. Put it on motor and all other on "drum". Spin it easily and slowly but with strength until its done.
Be carefully, use gloves.
Apr 13, 2013 | Indesit Hotpoint Creda Tumble Dryer Belt...
Creda T601CW 6Kg Advance Condenser Dryer The belt
Creda I don't know from. Sorry
Nov 20, 2011 | Dryers
My Creda dryer will heat but the drum won't turn. How do I fix this?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Feb 14, 2011 | Dryers
My creda reverseair tumberledryer won';t work. my
Hi
If you can hear the motor running and have also checked the belt tension and they are O.K., then the only thing I can think of is the Motor pulley, where the belt sits on.
Check that out and make sure it is not loose on the motor shaft, so that the motor turns but the pulley slips.
Regards
Ash
Nov 09, 2009 | Creda IWD12 Front Load Washer / Dryer
How do I replace the belt on my Creda T620CW tumble drier
most credas you need a stretch tool to stretch the belt from drum to motor if there is no jockey pulleys good luck.
Sep 14, 2009 | Dryers
Fitted new element to creda dryer model no T520vw BUT STILL no heat
Could be a bad thermostat or bad timer.
Hope this helps.
Aug 14, 2009 | Dryers
How to fit a belt to a creda tumble dryer
open case
loop belt around bits
close case
more particularly
Unplug dryer
pull dryer away from wall
remove 1 screw each side at back of top plate
slide top plate backwards and lift off
undo 1 screw each side of front kickplate
tlit front panel up
unplug door switch
set front panel aside
careful of control panel its V.fragile
(I lay the dryer on its back)
pull out old belt and bits of belt
loop new belt round drum at wear marks
pull tensioner to end of travel against spring
loop belt round motor pulley & both tensioner wheels(most creda) 1 wheel (old)
relax tensioner
rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
creda uses hotpoint parts
Oct 30, 2008 | Dryers
Tumble dryer Creda Smplicity T320VW
I am an authorized servicer for Creda and I can explain how to remove the front panel to change the belt. Email me at starztruck4u@aol.com if you still need help.
Mar 18, 2008 | Dryers
Creda IWD12 Front Load Washer / Dryer Logo
210 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
