Question about Maytag Neptune MAH5500B Front Load Washer
Washer stops after agitation, open and close lid and it continues
Hi guys, have a Whirlpool LLR9245DQO that does fine until it gets to the end of the first agitation cycle, it does a quick start to empty for the next cycle, then stops. When I open and close the lid, twice, it then continues. Sometimes have to do that a few times for it to kick in. Not sure if it is a lid switch or the timer. Any help would be great. Thanks.
  • Sharon Strippoli Feb 04, 2009
    Ok, I will order the lid switch and repair manual and let you know! thanks.
  • Sharon Strippoli Apr 26, 2009
    Finally got around to ordering this part and putting it in this morning. Manual says I needed an Ohmmeter for this job, but just replaced the part, put the body back together and worked like a charm.
    thanks Onthejob5130!
  • 640 Answers
Defective lid switch...
Posted on Feb 01, 2009
  • onthethejob1
    onthethejob1 Feb 04, 2009
    keep me posted onthejob
My washing machine fills up with water but does not continue the wash cycle. Sometimes when you slam the lid the washer will continue the wash cycle to the end. Other times the washer stays filled up...
Sounds like the lid safety switch is either out of adjustment, or needs replacement.
Most washers will fill with the lid open, but no continue a cycle where the drum or agitator spin, unless it senses the lid is closed.
Oct 01, 2013 | Whirlpool Washing Machines
Whirlpool Ultimate Care II Washer will not drain
bad lid switch,open the lid a few inches and close it down,if you do this a few times and don't hear a clicking sound the switch is bad.
http://www.youtube.com/watch?v=PZAbg9uftos
Jun 05, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Recently our LSQ8243H Washer stopped in the middle of the cycle. The first couple of times it happened all we had to do was open and close the lid and everything was fine. Now it stops and we have to...
Hi, I'd like to help diagnose your problem but I may need a bit more information. Based on what you stated, I assume you have a top loading WHR washer with an electromechanical timer... the kind that you turn and it clicks. Anyway, you stated that the washer stopped in the middle of the cycle and that simply opening and closing the lid would fix it for a while. I suspect that your lid safety switch may be cracked and isn't being actuated by the plunger on the lid. If this is the case, the washer would function properly until it reached the point in the cycle where it should spin. Then it would stop at that point in the cycle. This makes sense that opening and closing the lid might "fix" it for a while. Also, if the switch got bad enough that opening / closing the lid didn't work anymore, you could rotate the timer dial just past the spin area and the cycle would continue. Have you noticed the clothes are wetter at the end of the cycle?
Anyway, check the lid switch first and then repost if you rule it out.
Good luck.
Jan 18, 2011 | Whirlpool LSQ8243H
With my old washer I was able to open the lid and it continued agitating. My new one does not allow me to open the lid while it is agitating. Is there a locking mechanism?
Whirlpool / Kenmore washers use a "Lid Switch" as a safety device.
On older models the switch would stop the spin cycle when the lid is raised.
Newer models stop both the Agitate and Spin cycles.
If this is a Sears washer see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Oct 21, 2010 | Kenmore Washing Machines
Whirlpool - Filled with water to wash and stopped. Pushed in and turned to see if I could get something to happen or reset the cycle. Does nothing at all.
if the washer is full of water and will not continue it needs the lid switch replaced : the lid has to be closed so the washer will agitate and spin the lid switch is under the lid on the right or rear left
Apr 25, 2010 | Whirlpool Washing Machines
Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Aug 02, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool washer stops after agitation cycle
Maybe check the belt is it cracked worn or fibers showing if so replace it
Jul 26, 2009 | Whirlpool Washing Machines
Whirlpool ultimate careII spin cycle
sounds as if perhaps a wire is off on the side of the motor assy, l;ook at he wiring harness, sometimes a "chugging " noise occurs form the motor when one of the harnesses is not attached. and yes its normal to wash with the lid open, not to spin however( thats a saftey issue)
Jan 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
Washer won't start spin cycle
sounds like a lid assy issue, can you hear a "clicking" just before the lid is closed, try opening nad closing a few times listening for a distinct "click" if not the machine doesnt think the door is closed and for safety reasons wont spin and drain.
Mar 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag Neptune MAH5500B Front Load Washer Logo
180 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
