Question about RCA RTDVD1 System
Need 5-digit code for RCA RTDVD1
I'm trying to program a Comcast remote control to turn on my RCA DTDVD1 player so that I only need a single remote instead of 3. Can't seem to find the proper 5-digit code anywhere and am hoping that someone here will have the answer. TIA
  • 54 Answers
SOURCE: im using the rca rcr312w
  1. These instructions come from the RCA website. The crucial step is to keep pressing the reverse button.
  2. Turn on the component (the tv, dvd, etc).
  3. Hold the TV (or DVD) button and the on/off button at the same time. It will stay lit.
  4. Press the play button every five seconds until the component turns off.
    • Each time the Play button is pressed, the illuminated ON-OFF button blinks ten times and a block of 10 codes is sent to your component. This process continues until all the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited.
  5. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
  6. If the component does not respond, continue to press the REVERSE button EVERY TWO SECONDS UNTIL THE COMPONENT TURNS ON again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks.
    • If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again.
  7. To save the new code, press and release the STOP button.
  8. The illuminated ON-OFF button turns off. You must press the STOP button to save the code.
Posted on Aug 17, 2008
SOURCE: Comcast remote code using RCA universal remote control
After hours of research I managed to find a code that works. It does not control the built in DVD player but just having to power and volume functions is a life saver for me.
The code is 12002.
Enjoy.
Posted on Dec 01, 2008
SOURCE: I need a Universal Remote code for this model.
I got it to work with code 12002. I have the Comcast DVR Remote.
SOURCE: Comcast Remote Control Code
comcast sucks and its tech support are a bunch of idiots. the book that comes with the remote is wrong (and for some reason no one in tech support knows this). the remote requires 5 digit codes and all the codes in the book are 4. typing the number 1 in front of any of the codes in the book, for any device and manufacturer, should fix this problem.
Posted on Dec 07, 2008
  • 73 Answers
SOURCE: My dvd player plays all DVDs in Spanish if the option is avail.
Some how with that remote, you need to get into the setup of the DVD, and change the SAP or Secondary Audio source. It is set to spanish or to #2 #3 or such.
Charles
Posted on Jan 05, 2009
How do I program a dvd player with the new xfinity x1 remote? The instruction manual does not tell us how.
It is my understanding the xfinity remote is designed only to control comcast set top box and TVs. It also can control audio receivers. It is unlikely you can control a DVD player with it.
At best you could try and use the programming instructions on page 5 of the manual and see if it picks up your DVD player. Otherwise it might be better to use the existing remote controller you have and program the Comcast set top box to it. You need to find the codes from the programming instructions of the original remote control and you will also need to know the model number of your comcast box.
Hope this helps.
https://x1.comcast.net/webportal/assets/pdfs/RemotePairingGuide4.26.11.pdf
Sep 12, 2014 | Televison & Video
Need Comcast 5-digit universal remote code for Sony BDP-S3100
Find Your Comcast Remote Control Programming Code
make sure your using those codes with the AUX button. Comcast does not have all remote codes for every electronic made though.
Feb 05, 2014 | Comcast Custom DVR 3 Device Universal...
I need the 5 digit code to program my RCA brc11082 to my Comcast remote
There is no codes [5digits] for this devce with comcsat remote control.
Apr 15, 2012 | Televison & Video
Codes for a universal remote
Roku is a streaming player; it streams many types of data like comedy, TV shows, horror, etc. Many users had admired to use the Roku because of its comfort and easy to use. The Roku Universal Remote code Comcast is used to control your entire device.
    ·Roku Universal Remote is programmed to access different devices like as TV, DVD, and VCR player. It is a more interesting that you can control your entire device in your single remote.
    ·This remote control is used to control the audio and video of any brand of your device.
    ·This code is identifiers for configuration of your device.
    ·There are two code lists they are CL3 and CL4. Check this code list to replace your batteries and cover.
    ·You can execute your device in 2 methods
    1.Auto programming
    ·Use the universal remote to turn on your device.
    ·Then press "Setup Release" till TV button flashes.
    ·Enter the digit and choose the code to setup your device.
    2.Manual Programming
    ·Use Comcast remote, if you want to program then you can use Aux KEY.
    ·Check the instruction for manual and start entering the code. First ensure that you have a Roku account or else get it from the Roku.com/link. For details contact@ +1-844-965-4357.
1-rokuactivationcode-com-roku-universal-remote-code-comcast-blog-433sdnpnckpfjmjifzsr4nnb-5-0.jpg
Jan 12, 2012 | RCA Universal Remote Control
I need a 5 digit code for my Rca L32HD31R LCD tv to connect to comcast. Any help would be appreciated.
Hello
Five digit codes to check with RCA tv with comcast remote control are:
11447, 10047, 10090, 10679, 11047, 11147, 11247, 11347,
Nov 22, 2011 | RCA L32HD31 32 in. LCD HDTV
Need codes for emerson & also insructions to program comcast remote
Hello
Setup codes for Emerson TV with "Comcast On demand Custom-3 Universal remote control are:
0154, 0236, 0463, 0180, 0282,
0178, 0179, 0038, 0177, 0280
The Comcast Custom 3-Device universal
remote control is preprogrammed at
the factory to operate the Cable Box
supplied by your Comcast system, an
RCA TV, and an RCA VCR (in the AUX
mode). To control devices other than
default brands (excluding the Cable
Box), perform the below steps; otherwise
skip this section:
1* Turn on a device (e.g., VCR or DVD
Player) and, if applicable, insert
media, (e.g., video cassette or disc).
NOTE: Please read steps 2 to 6 completely
before proceeding. Highlight or write
down the codes and device you wish to
program before moving on to step 2.
2* On the remote control, press a
device key once (i.e., AUX or TV).
NOTE: Use the AUX key to program
control of an Audio Amplifier or
Receiver, a DVD Player, a Home-
Theater-In-A-Box Device, a PVR (or
DVR), or a VCR.
3* Press and hold Setup until the
selected mode key blinks twice,
then release Setup.
4* Locate the code for your device in
Manufacturer's Codes on the back
of this user guide. Brands are listed
in alphabetical order with the
most popular codes listed first.
5* Enter the first four-digit code for
your device. If you perform this
procedure correctly, the selected
mode key will blink twice.
NOTE: If you enter an invalid code, the
selected mode key will display one long
blink and exit the programming mode.
Repeat steps 2 to 5 with a valid code.
6* Aim the remote control at your
device and press Power once. The
device should turn off. If it does
not respond, repeat steps 2 to 6,
trying each code listed for your
brand until you find one that
Searching For Your Code.
NOTE: If the device does not have a
Power key, press the (Play) key
OK
Aug 22, 2011 | Televison & Video
WHAT IS THE REMOTE CODE FOR A SYLVANIA TV
Hello, you will need the model number for your remote control unit, once you get it, you can go directly to the RCA website and click under accessories, You will get instructions on how to download the code list. www.rca.com ,
Nov 03, 2010 | RCA Universal Remote Control
Need Memorex MVD2045 5-digit remote code
This code worked for me with the Comcast DVR-3 and the Memorex 2042 DVD player: 20831
It may work with the MVD2045 as well.
Jan 17, 2009 | Memorex MVD2042 DVD Player
Charles
Jan 05, 2009 | RCA RTDVD1 System
Dec 04, 2006 | RCA 20F510TD 20 in. TV/DVD Combo
RCA RTDVD1 System Logo
504 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
