Question about Gateway 6021GZ (RB6021GZ) PC Notebook
The DVD tray doesn't close properly
I opened the tray up and am not sure what happened but now it won't close properly. It feels like I could shut it but would have to force it. What is the best way to diagnose what's wrong? Will I have to get a new dvd drive or is this one maybe just a little off the tracks or something? Is there an easy way to remove the drive? Thanks for reading!
  • luke_mcwilli Feb 02, 2009
    yeah i ended up getting the manual online, taking the drive out, and removing the obstruction. thanks for the reply
  • 629 Answers
Check the drive and the drive bay for damaged like cracked plastics. Check for screws or obstructions that could prevent the drive from closing properly. Try to remove and reconnect the drive to your system. If issue remains, try another drive, if available, and see if it will close properly with your system. If so, you may have to get a new drive. For the steps in removing and replacing the drive, check the online manual for your system model on the manufacturer web site.
Posted on Feb 02, 2009
  • Rodie Feb 04, 2009
    glad you were able to address it. glad to help
Magnavox ZC320MW8 door stays open
f the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual.
God bless you
Sep 27, 2012 | Magnavox ZC320MW8 DVD Recorder Refurbished
Problem with the is not working properly and cant come out
God bless you
Sep 27, 2012 | Philips DVP-3005 DVD Player
Problem with the dvd tray
God bless you
Sep 27, 2012 | Televison & Video
Tray won't open
by just resetting the software will not work this is a mechanical problem this usually happens on players that is not use for a long time or improper closing of tray..fixing this kind of problem requires opening the cover of the need to lubricate all moving gears and parts by putting enough amount of lubricating have also need to assist the motor manually by helping it to push the tray out just gently pull the tray with your hands during a eject command on the unit clean also the limit switches of the tray make that contact are properly working..good luck!
Apr 06, 2012 | Kenwood DV-605 Multi-disc DVD Player
Philips DVP5140/37 disc tray won't open. Hello! I have tried unplugging from the power source and waiting 10 seconds as their website says to do. I hold down the stop button on the remote 5 seconds...
What could be done is to leave the set Switched ON for many hours even overnight and see how it can change if there is a possible fault on the motherboard, a change of value in electrolytic capacitors.
If there is no result then there is fault in the motherboard and you need to take consensus for an estimate.
Nov 05, 2011 | Philips DVP5140/37 DVD Player
Go Video DV 2150 - DVD door won't open at all. You can hear a mechanism working behind the closed door, but nothing happens and the door remains shut. Any advice??
There is a small belt under the loading tray which would have gone slack ( loose ) and the sound you hear is it slipping on the motor pulley. If you are confident you can remove the mechanism and turn it upside down and access this belt. Dismantle only if you can get the spare belt or your efforts will be in vain.
Sep 13, 2011 | GoVideo Go Video DVD/VCR Combo
Open & close disc doesn't work. It is open not but I can't close it. Looks like both open and close don't work.
There are three possibilities for this trouble with this DVD player. The first one is imprper loading function due to loading motor or loading belt trouble. If loading motor is weak [that is its pulling power has gone low] the tray will not close properly into the mechanism, and will not touch the load sensor switch fitted inside the mechanism. If this happens, the main system control IC will detect improper loading and will turn the tray out again to load it properly. Just try to close it without a disc inside the tray, and check whether it closes well. If it does so, or the trouble repeats, change the loading belt first. In most cases, this will retify this type of trouble.
The second one is, bad 'Sled' motor. sled motor is one, which spins the disc inside the mechanism. After proper loading, if the disc do not spin inside it, again the system control IC will sense it, and will eject the tray. The sled motor also is a replacable part.
The third one is, damaged gear wheel in the loading gear section. to detect and repair any of above trouble, you have to open your DVD player, and take the DVD mechanism out of it, and is somewhat semi-skilled work indeed. Check these first. If you want anymore assistance from me, feel free to get be by fixya. If you are somewhat skilled, and have confidence and can follow the diagrams, send your email address to me by FixYa. I'll send the service manual of your DVD player by return mail. All details and disassemblng procedure are in it. OK
Jun 12, 2011 | Samsung DVD-V4600 DVD Player/VCR
Insert DVD, closes, but opens immediately and the screen just says hello. The unit will not shut off unless I unplug it.
If I remember correctly, this unit has a little rubber belt that drives the DVD tray. When it ages, the rubber hardens and loses traction. Thus, the tray does not close properly, the internal sensor recieves no 'closed' message within a specific time, and the tray opens.
Jun 11, 2011 | Zenith XBR716
Lg rc797t dvd drawer will not close consistently
I have a Compaq Presario desktop running XP Media Center. The DVD tray would open on power up, and kept openinig when pushed shut.
I discovered that the tray would frequently remain closed when I held open the flap (the flap with the open button). A few days after discovering this, I got to add some more tracks to my MP3 player - I only mention this intermediate stage in case it is material in curing the problem, as the next thing that happened was a power failure whilst the PC was on. Since then, the CD/DVD drive has behaved perfectly. I did have a temporary problem with AVG INternet Security being unable to load the necessary DLLs to run correctly in MS Outlook 2003, even complaining of a corrupt installation, but this dissappeared after a proper restart and AVG update.
Compaq users: try holding the flap open when you attempt to close the tray.
Generally: with PC running and all applications closed, switch the power off at the wall socket.
Shaftesbury (UK)
Jan 25, 2009 | Computers & Internet
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Gateway 6021GZ (RB6021GZ) PC Notebook Logo
62 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
