Check fuses, & relay , relay may have fuse also. when you turn key on, the fuel pump will whine for a couple seconds, have an assistant turn key to on position, donot start, while you listen for whining noise @ tank. if you hear the noise, pump works, if nosound, replace pump. but make sure its not jusj a fuse, or relay first.
will the ignition keep the fuel pump from working Dodge B 3500 2001 Van
yes, thats how power gets to pump, yes ? good grounding is required for fuel pump to work, all electrical systems must have 2 things, 1- positve & 1 -negative connection , full circle to & from battery, if ground wire from pump or switch is bad or broken or corroded, it will not produce power !
