Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
Unable to Set up Netgear Rangemax WPN824 Router. No set up CD
I have a Netgear Rangemax WPN824 Router but no set up CD. I have tried everything but I cannot access the Internet. I have run ipconfig and established the router is talking to the computer. I then open the internet explorer. But when I try and follow the setup wizard it just doesn't work. I have tried to reset the router, re-plug everything. Re-start. Nothing works. Any suggestions? My ISP is TalkTalk. Sometimes when the box pops up to ask for the username and password when I key in admin and password it won't accept it. I am a total novice so some basic instructions would really help. Thank you
  • jillbrockleh Feb 03, 2009
    They have supplied a Username and Password. Also: -
    VPI/VCI - 0,38
    Mode - PPPoA (this option isn't available when I ge to this bit)
    MTU - 1432
    Encapsulation - VC-MUX
    Does this help. It doesn't mean much to me! Thanks
  • spyzampinoy May 11, 2010
    did your ISP talk talk give you Username and password? or  IP address?
  • 854 Answers
Hello spyzampinoy,
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a DSL connection that does not require a login, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection that requires a login, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Apr 12, 2009
Lost netgear cd for installation. can i set up by cell phone using smart wizzard?
No, you need to connect via Ethernet cable to set up the router.
The router manual is here
http://kbserver.netgear.com/pdf/wpn824_ref_manual.pdf
so you can set it up manually
Jan 07, 2014 | NetGear RangeMax WPN824 Wireless Router...
How do i set up my router? model # WPN824
Check this url http://static.highspeedbackbone.net/pdf/netgear-WPN824-manual.pdf.
Oct 26, 2010 | NetGear RangeMax WPN824 Wireless Router...
Netgear WPN824 router
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Jun 24, 2010 | NetGear RangeMax WPN824 Router
I cannnot download the cd for my WPN824 because I I have windows 2007
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 19, 2009 | NetGear RangeMax WPN824 Router
I wait for over the 30 seconds and don't get any response to go to the next step
Are youtrying to set up the router. I think you are running the CD that comes with the router. Well , you can also set up the router manually, without the CD. Click Here for step by step solution
Nov 16, 2009 | NetGear RangeMax WPN824 Router
Trying to install my Netgear Router to my PC and 2 playstations dont have the install CD anymore tho so cant set up easily how do I set it up without the CD MOdel WPN824 V2
You set the router up by using the web browser on your PC. (No CD needed).
The router has its own web server at address 192.168.0.1 or 092.168.1.1 (you don't need the www.)
It will ask for the log in and password which are (if they haven't been changed) admin and password.
Once past that you go top the set-up page and enter the info provided by your ISP (normally in a letter but sometimes it comes by text message to your mobile phone) and generally that is that.
Connect your playstations and the job should be done. (I don't use p[laystations so I don't know if they need anything special.)
Nov 11, 2009 | NetGear RangeMax WPN824 Router
How to hook up a netgear rangemax wireless router WPN824
  • connect it based on the manual
  • Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
    • set first the routers access page
    • type www.routelogin.com
    • type username: admin, password: password
    • on basic settings: select no internet login: set the router mac address to set to computer mac address, apply
    • click: wireless settings under set-up: change: SSID: <your name>, region: US, mode: g&B, channel: 11, no password first, click apply
    • goto xbox system-network- then look for the ssid of your router and connect, if you encounter any problem call xbox live support
Aug 05, 2009 | NetGear RangeMax WPN824 Wireless Router
Weak connection with my xbox 360
The best way to make the wireless connection stable is to do some changes on the wireless settings of the router , like changing its wireless channel to the highest one to avoid any interference on your area.........
Sep 15, 2008 | NetGear RangeMax WPN824 Router
Lost all internet connections through NetGear Router
I'm thinking MAC accept/reject list, check to see if it's active or not.
Aug 26, 2008 | NetGear RangeMax WPN824 Wireless Router...
Installation
Actually dscuva you can configure your router manually you don't need the setup CD anymore
May 07, 2008 | NetGear RangeMax WPN824 Wireless Router...
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
337 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
