Question about Janome D'cor Excel 5018
Straight-Stitch Throat Plate
I cannot find a straight-stitch throat plate for my Viking #1+ sewing machine.
  • 3 Answers
SOURCE: Changing stitches
You probably have not adjusted you stitch width and length.
Also a manual for this machine is currently being sold on Ebay for $4+. Probably would be a good investment for you.
Posted on Mar 29, 2008
SOURCE: Janome Memory Craft 9500 Troubleshooting
The solution that I found last night was the thread tension. I have never touched the dial, only had it set on 'auto." When I started playing with it, I realized the top thread should be really easy to pull through the machine and it wasn't. I started turning the dial (to 3 or 4) and the thread slid through the machine perfectly. No more birds nest! I really thought it was bobbin initially because of the horrible sound it was making.
Posted on Jun 05, 2008
SewTechWayne
  • 186 Answers
SOURCE: The Reverse stitch button
The feed mechanism needs to be oiled. Take off the bottom cover and look for any place where two parts move against each other. Some binds can be very difficult to remove. Try spraying everything with a light weight oil (I like Tri-Flow) and let them soak over night. Then manually try to move the feed dogs with your hand. Hopefully it will break loose.
Posted on Jan 30, 2009
SOURCE: Cannot get a straight stitch
Please check the top tension as well and rethread. I had this problem and after doing the above, everything worked perfectly. Thanks.
Posted on Mar 15, 2009
Zenqi
  • 208 Answers
SOURCE: The bobbin thread is bunching on the under side of
Make sure that you use the F foot when using decorative stitches.
The stitch balance my be off. Remove the accessory bin and you will see a large plastic screw with a + and a - and an arrow. Using a coin, turn the arrow to the center and test. Turn the arrow towards the + to stretch the pattern out.
If this doesn't work, it must me calibrated internally and requires an experience hand.
Posted on Jul 11, 2009
Did Elna Carina SU 66 originally come with a straight stitch foot and throat plate?
No, the Carina came with a standard zig zag plate and 5 feet I think from memory, the teflon coated foot , the embroidery foot, buttonhole foot, zipper foot and darning foot.
Nov 16, 2016 | Elna Sewing Machines
My needle is hitting the plate when I try to make a buttonhole
Sue: According to http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CCAQFjAA&url=http%3A%2F%2Fwww.consew.com%2FFiles%2F112347%2FInstructionManuals%2FCN2230R.pdf&ei=ZGtVVaa7OYKRyQTGo4GoBA&usg=AFQjCNG-1xhxBFtfhJZJn7y5QZ_0E1r48w&bvm=bv.93564037,d.aWw : "The Throat Plate is not held firmly in place. Its screws are not tightened securely. The Throat Plate shifts around and is being hit by the Needle. Solution: Locate the Throat Plate correctly and tighten firmly the throat plate screws."
May 14, 2015 | Sewing Machines
Needle breaking
it's very possible that when the needle hit the hoop that it caused the needle bar to jump time
I would suggest that the machine be taken to a sewing machine shop to be checked to see for sure if it is the timing or something else since the needle is also hitting the throat plate
May 29, 2012 | Sewing Machines
I"m trying to fasten letters I cut from regular
How about using a tear away stabilizer or tissure wrapping paper? Sometimes the fleece is just to cushy for the machine. I would put some on the throat plate, and between the fabric and fleece, then tear it off. Good luck, I hope that helps.
Dec 27, 2010 | Brother XL3750 Mechanical Sewing Machine
Thread jams
Hi! I've had this happen to me many times and it is so very frustrating! First, take the bobbin out and also the bobbin assembly and clean the entire area of all lint, fuzz, little bits of thread....get it as clean as you can. Take out the upper thread too. Clean and oil. Change the needle. Make sure you're using the appropriate size and type of needle and thread for the fabric. Take off the needle plate and look for any nicks or scratches. If you've got them, you can get emery cloth from a good hardware store (often in the plumbing department) and polish them out (or mostly out).
Rethread the machine, carefully following the instruction manual. Use your basic, normal settings. Using a scrap of the fabric you're trying to gather, sew a seam and see if everything works ok. You may need to hold the top and bobbin thread firmly behind the needle as you sew the first few stitches (I find this little trick helps a lot to prevent birdsnests).
To gather, sew three parallel lines of long, basting stitches (you really don't need a special foot or special settings other than to make the stitch a long one). Don't backstitch, reverse, or lockstitch either end, and leave the thread long when you cut it. Pull the three bobbin threads and the fabric with gather nicely along them.
Something to keep in mind--if you're trying to gather very sheer fabric on a zigzag machine, you may need to replace the throat plate with the zigzag hole for a throat plate with a single, small hole for a straight stitch. I've run into this situation before, and ended up using one of my antique straight-stitch only machines to do the gathering.
If you don't have a throat plate with the single hole, you might try some light weight interfacing to give some density to the sheet fabric.
Hope this helps!
Jan 31, 2010 | Euro-Pro Sewing Machines
Quilting seam allowance
When you turn your machine on it automatically sets up for a straight stitch with the needle centered. Just guide the right edge of your fabric along the line marked 15 on the throat plate and you'll have very close to a 5/8" seam. If you need more precision you can adjust your needle position to the left or the right by using the stitch width and mirror setting buttons.
Jun 23, 2008 | Husqvarna Rose
Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I had a similar problem a couple of years ago. I finally figured out that I had the straight stitch needle plate (the one with the single hole), rather than the zig zag needle plate (the one with the curved hole). When I changed plates, it worked fine.
May 08, 2008 | Sewing Machines
Sewing Machines Logo
138 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
