Question about Maytag 24 in. MDB9750AW Dishwasher
Arms not spinning---dishes not clean ---Maytag Quiet Series 300
I suspect the impeller may not be moving enough water to properly rotate the spinner arms.
Diagnostic:
I first checked the inlet solenoid to insure hot water was coming in. I added more water by hand in case it was shutting off too soon. I then set each arm to a known positon. Bowls were placed on the top rack to catch water from the top spinner. I closed the door, then opened the door during wash or rinse. The arms would only sometimes be found rotated, and the bowls had little or no water in them.
I removed the bottom spinner assembly to check the impeller, and it is spinning during either cycle. I also ran the units self test, which indicated no problem (of course!). Do I have a bad motor or impeller linkage? Or???
Thanks.
3 Suggested Answers
  • 423 Answers
SOURCE: Wash Arms not spinning --Dishes not clean
Without the model number of your Maytag number, I can not determine if when you order a wash pump motor you also get the impeller.
Sounds like you are on the right path to getting your dishwasher to wash dishes again.
Oh, while you have the dishwasher open, check that the heating element has not failed using a Multimeter.
Good Luck!
Posted on Apr 10, 2009
SOURCE: my maytag mdb8600aws jet clean 2 only cleans dishes in bottom
The seals that the racks "plug" into need replaced. Ours had the same issue and replaced the seals and it works fine now.
Posted on Dec 21, 2009
My maytag quiet series 300 always leaves food residue on most of the dishes on the top rack. Any ideas?
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 11, 2010 | Maytag 24 in. MDB9750AW Dishwasher
GE Triton seems to lack pump pressure to rotate the wash arms.
1)please check the impeller nut is loose.
2) please check the hose connected to the arm any block.
Jan 08, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
The dishes don't come out clean after complete cycle or even after I re did the wash.
Has it always been okay in the past? Do you have the manual, and if so, are you loading it properly. I am not familiar with this particular machine, however there are a few things you can check. Make certain all the spray arms are spinning freely. If there is a "tower" that comes up from the bottom, be certain nothing is blocking the center portion of the bottom rack. Run a load as normal, but stop it after a few minutes. Is there water in the tub and are the dishes wet? If not, determine if the water source is on, and the "fill" solenoid is working. If there is water, and all dishes appear to be getting wet, be certain you are getting a lot of "water action" during the wash. If you listen closely, you should hear a sloshing sound as the machine runs. If not, your not getting enough water circulating. The pump may be clogged, or perhaps there is not enough water coming in. Is your water pressure high enough to fill it completely? I hope I have given you enough things to check in order to lead you to the problem. Let me know.
Oct 31, 2009 | Maytag MDB7100AWB Dishwasher
Maytag Quiet Series 300 dishwasher, dishes come out dirty
A water softner will not make the dishes any cleaner, it just makes it so they don't have water spots on them.
If the dishes are dirty, it is most likely that the nozzles (holes) in arms may be plugged.
Also check to make sure you are getting plenty of water to dishwasher. Make sure all water valves are full turned open.
If the control panel does not work all the time, it is very likely you have either a shorted wire, or a fualty main board which is very common in newer machines.
Jun 01, 2009 | Maytag 24 in. MDB5601AWS Stainless Steel...
LG LDS5811WW Low pressure out of spray arms
On the LG LDF xxxx dishwasher family, the Vario feature uses a motor/check valve to switch between "full power" cleaning from _either_ the lower or the upper spray arms, never at the same time. So, not seeing the upper arm spin during the lower arm spinning is standard operating procedure.
But back to your problem. Step one would be to remove the filter assembly again and make certain that there is nothing (debris, broken glass) blocking the white areas where the check valve rotates to switch between upper/lower spray arms. A blockage there ~could~ cause impotent spraying/cleaning.
If there is no blockage and the impeller remains in good shape, suspect a failing wash pump motor. Try to isolate the noise to that motor.
Watch for error codes on the display and report back what you find, OK?
Good Luck!
May 14, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Not enough water pressure to move upper arms or clean dishes
Recommend you pull the bottom spray arm straight up, then out of the DW.
Remove 9 phillips screws that hold the filter shroud down. Remove the filter and clean/rinse it out.
While the filter it out, grab a flashlight and inspect all over the sump area. Especilly in the area the has the check valve that rotates (Vario motor-driven) to feed the water pressure either to the lower and then the upper arms. Watch out for broken glass! Also, inspect the impeller to see if it is undamaged and spins easily.
Reassemble, then test out.
If problems remain, the the wash pump motor is probably the culprit. Do you get any error messages on the time display?
Good Luck!
Apr 05, 2009 | LG LDF6810ST Stainless Steel Built-in...
Good Luck!
Feb 01, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Loud noise maytag dishwasher quiet series 100
Hi All,
I have had a Maytag Quite Series 300 for some years now and have done basttle with it on may occasions. I now consider myself somewhat of a veteran, although by no means a repair expert!
Grinding Noise: From either a clogged/blocked impeller or not enough water getting to the impeller.
For a clogged impeller, it is fairly easy to disassemble the washer to get at the impeller to remove any debris or blockages.
For not enough water it can be a number of things. First of all, you will notice that the noise lessens if you add a jug or two of extra water. This is because if the water level is too low, the pump impeller will get some air mixed with the water & this is LOUD! Now for the causes:
Float – If the float gets stuck in the wrong position (debris or water deposits), it will not fill enough.
Float Set Wrong – Seems thats some of these dishwashers have the float set a little too low to let the dishwasher perform without grinding. A few pennies attached to the float with a rubber band seems to help here. Don't go too far or you'll flood your kitchen!
Timer – Some folks have mentioned that dishwashers that fill on a timer will not fill enough in the allotted time, if the water pressure is low. While this is true, I have looked over the electrical & parts diagrams for the QS300 and I do not see a timer listed anywhere. Also, the wiring diagram appears to show that this dishwasher only uses the float to achieve the correct water volume. I could be mistaken here.
Note that in VERY hard water areas (like mine – TDS of 850 hardness or 49 Grains), the plastic fins on the cover of the impeller get very choked up with water salts and this can impede flow, leading to a low-water symptom, when in fact, there is plenty of water.
Dishes Not Cleaning:
Poor Water Flow – See above, all the above items will negatively impact dish cleaning.
Poor Q uality Detergent – After trying them all – Yes, all – Do not use cheap detergent. Buy the brand names: Cascade or Electrasol work well. I have found that by far, the little packs work the best. We found that the liquid works second best and the dry stuff really isn't up to the task at all, no matter which brand.
Spray Wands Catching – We found that our lower spray wand was catching on the bottom of lower dish tray, so I very slightly bent down the legs that the wheels mount to in order to lift the dish tray/basket a little and give the wand a little more room. This worked well.
Spray Wand Nut Too Tight – The factory seems to send the dishwasher out with the nut on the bottom spray wand tightened a little too far. Loosening this a little bit lets the bottom wand rotate much more easily.
Top Spray Wand Not Meeting Receptacle – The top spray wand is attached to a pipe that mates with a port (well, one of two ports, depending on if you have the top rack in the “Upper or “Lower” position). The pipe seems to have a tendency of missing the port. A well placed elastic band will help here. Note that on our dishwasher, by the time the first elastic band wore out, the pipe had been permanently moved to the correct position by the gentle pressure.
Tines/Dish Holders On Top Rack Falling Over – The tines (metal spikes) that hold dishes on the top rack fold down by design. Issue here is that they do it sometimes during the wash, causing the dishes to fall over and block the spray. A few well placed rubber bands help here as well.
Water Salt Buildup – If you live in a very hard water area, you can still get clean dishes from yor dishwasher. We do and we have VERY hard water. Buy a gallon of vinegar once a month. Pour this into a clean dishwasher. Turn it on so that it runs for 2 minutes to circulate the vinegar. Open the door & let stand over night. Close door & finish cycle. This will cut down significantly on the hard water salt buildup in the washer.
It's A Maytag – Sorry folks, it's true. I have learned (after purchasing the dishwasher) that Maytag has run into financial difficulty in recent years and has reduced build quality to save money. If you got suckered into buying one of these, you will very likely never buy one again. My opinion is “Do not by Maytag.”
Hope this helps someone!
Dec 31, 2008 | Maytag 24 in. MDB9750AW Dishwasher
Maytag quiet series 300 dishwasher
try using less soap and make sure the dishwasher is filling with enough water.
Mar 02, 2008 | Dishwashers
Water not going through spray arms
1.does motor run? no. replace motor. 2.open door and leave the bottom rack inside dw.spin the spray arm underneath the bottom rack by hand. it should spin freely without binding. if it doesnt spin freely take out the bottom rack and try again. if it does spin freely then your bottom rack is laying on your sprayarm preventing it from rotating. 3.you could also not be getting enough water into your dw.
Mar 21, 2007 | Frigidaire 24 in. FDB421RF Built-in...
Maytag 24 in. MDB9750AW Dishwasher Logo
975 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
