Question about Logitech V20 Computer Speakers
Logitech G20 speapers won't work
My new Logitech V20 speakers worked for a very short time after I set it up. Thereafter I keep getting the response that USB device not recognized.
What can I do?
5 Suggested Answers
SOURCE: No sound
Make sure you've got your V20's set as the default sound playback device.
Control Panel -->
Sounds and Audio Devices -->
Tab 'Audio'; select 'Logitech USB Speaker' in the dropdown list in the first item on the tab.
just a thought...
Posted on Jan 01, 2008
Benimur
  • 6966 Answers
SOURCE: my logitech R-20 speakers.
Hi again,
Appreciate your reply and the additional information and as initially stated nothing is wrong with the speakers (Logitech R-20)
When you installed a new hard drive and reinstalled Windows, most but not all the necessary drivers were loaded which we can assume included the sound device. Though Windows recognized that there is a multimedia audio controller, it has no knowledge of what type and therefore would not know which drivers are needed. What is needed therefore, is determine what is your specific multimedia audio controller, let Windows know about it and proceed to install appropriate drivers.
The easiest way to do this would be with the use of the recovery CD and/or drivers CD that came with your PC or motherboard. If you have such a CD, pop it in your CD tray and read the contents. One folder should say something like Audio, Multimedia or sound. Explore that folder and look for any setup.exe or allow Windows to auto install. The latter is done by opening your Device Manager, right click on the yellow marking and click Update driver. When asked for the location of drivers, browse/point to where you saw the Audio, Multimedia or sound folder is (in the CD).
If no CD came with the computer, you need to determine what specific motherboard you have. If you are somewhere in Australia, perhaps you can try Concorde Computers for the necessary identification and possible driver download. You can also get their contact information here.
If for some reason that would not work for you, you can get you PC's motherboard model on the initial powerup. The display would show something like Asus XYZ, Gigabyte ABC or Intel 123. Using that motherboard model number, you can proceed to the MB manufacturer's website and download appropriate drivers or post back here that we can further assist you.
Cheers.
Posted on Jan 21, 2008
  • 38 Answers
SOURCE: Subwoofers not working on Logitech R-20 speakers; worked until recently
There must be a control on subwoofer, like a volume control. Turn it and check it. Also check the connections.
Posted on Jul 17, 2008
bronk50
  • 27725 Answers
SOURCE: Logitech LS21 speakers connected to
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Posted on Feb 16, 2011
Lights are on but no sound
my lights are on but no sound and i go to my volume button and it says no audio device
Aug 26, 2009 | Logitech V20 Computer Speakers
No sound from rear speakers of Bose V20
Are you useing a digital coaxil cable? or optical cable?(you will need one of these connections to get 5.1 surround!) the white /red rca jacks will not do the 5.1 surround! (back speakers)
Please rate response!
Jan 07, 2009 | Bose Lifestyle 12 System
USB Audio Device Drive Load Failure
Driver probably needs update. I had this problem using my usb speakers until updating driver to newest version.
Dec 21, 2008 | Logitech V20 Computer Speakers
Logitech usb headset A-0374A does not play
probably need to set the Logitech headset as your default device in Control Panel-Sound. XP or Vista updates may reset the audio-video default devices
Nov 19, 2008 | Audio Players & Recorders
USB speakers will not work with Linux OS
http://www.pclinuxos.com/index.php?option=com_smf&Itemid=26&topic=51721.0
may shed some light
Oct 30, 2008 | Audio Players & Recorders
Logitech V20 speakers in internet explorer
I have the same speakers, I have never had a problem with Vista, have you tried to restart your machine after you installed (Plug n Play) the speakers?
Jul 09, 2008 | Logitech V20 Computer Speakers
No sound from logitech speakers, they worked 2 songs and then stop working i ve got control whit buttons on top of speaker but no sound please help
FOR MACS... Last February(08) I bought the V20 Logitech speakers for my Apple iBook laptop. I got them to work. Hadn't used them for about a year and had forgotten how to get the sound to emerge. I went to System Preferences. Clicked on Sound. I had plugged in the USB. Didn't show up. Unplugged it and plugged in again and there it was! I clicked on it and the sound came through immediately. So wait to plug in the speakers until you have opened Sound. (And Pandora (superb Internet radio station) is playing flawlessly.) I am not familiar with PCs. Sorry.
Jun 14, 2008 | Logitech V20 Computer Speakers
No sound
check in your device manager that you have installed the driver successfully.
1st go to control panel
2nd click on system
3rd click on properties
4th...on device manager and select it and see the status!
Dec 08, 2007 | Logitech V20 Computer Speakers
Webcam
your creative live webcam probably have no problems it just have some complicated process when installing that cam...
your logitech webcam have no problem either if you can make it work with the cam your sound problem maybe just in your sound settings... if that logitech cam is what i think it is it has a built in microphone...
double click the speaker icon in your bottom right most taskbar (close to the time)
the volume control will popped out click on the microphone advance button then on advance control for mic windows uncheck the mic boost...
the mic probably getting a loop static from your speaker...
rate me if this help........
Nov 28, 2007 | Samsung V20 XTC 1800 Notebook
Logitech V20 Computer Speakers Logo
1,048 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
