Question about Conair Weight Watchers WW-87 Body Fat Glass Scale
Weight Watchers scale WW11D
When I step on the scale it displays RON
  • Anonymous Feb 19, 2009
    Same problem: shows only "ron" even after changing the battery.
Posted on Jan 26, 2011
I have the same problem
Posted on Oct 13, 2009
Just replaced battery - trying to reset the scale to 0.0
PDF]Instructions for use of ThinnerĀ® Bathroom Scales
www.conairscales.com/catalog.php?product_id=428&ib=en
Scales for the way you liveĀ® ... Tap on the scale and wait until "0.0" appears; press Set button, ... button to change the goal weight if necessary, once the ... NOTE: 1. When the scale traps zero error, "Err" will show. Please try again. 2.
How to Set a Digital Health O Meter Scale to 0.0 - Livestrong ...
www.livestrong.com > Weight Management
Aug 12, 2015 - The scale may not register at 0.0 when starting out... ... The Differences Between Balance Beam Scales & Electronic Scales ... 10 High-Tech Health Tools toTry This Year; Are You in Need of a Digital Detox? How to Start Doing Parkour. References. Healthometer.com: FAQs; "Health o meter User Manual" .
Jan 05, 2016 | Health & Beauty
Er: 1: 11 appears anytime anyone tries to weigh themselves.
I do not know this particular scale, but you might try this solution that works with many electronic scales. To activate the scale, lightly tap the scale, placing enough weight on the scale to initiate the electronic process. (A foot tap will do.) Wait for the display to show 0000 (or whatever the ready state display of your unit is), and THEN step on the scale.
Mar 03, 2011 | Seca 780 Robust Digital Column Scale /...
I replaced the 9 volt battery on my Soehnle scale and the display on the front reads 8888888 and stays that way, never going to 00. Please advise.
mcdevito75 here, You can try to disconnect the battery, then step on the scale then step off, Now re-install the battery and see how it works. If same contact scale manufacturer.
Jun 29, 2010 | Soehnle Linea Quattrotronic Digital...
Nothing will display on the read out
The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jan 03, 2010 | Taylor Dgtl Body Fat Scale
HealthSmart bathroom scale displays "Err"
Put scale in round file can. Buy another cheap scale.
Oct 03, 2009 | Dmm Elscale Healthsmart Glass Electronic...
Weight Watchers bathroom scale, Model WW60X
I got it! Press "set". You should see "start goal" in the bottom right. Press the user # you want to save as and press "set" again. The display will blink then display "0.0". Step on the scale to get your current weight. Once it's read you current weight, press "set". A goal weight will display. Press "User 1" to make your goal weight go up and "User 2" to make it go down. Press "set" when the display shows your goal weight. That's it. Now all you have to do is press your user # and wait for "0.0" to display before stepping on the scale.
Apr 24, 2009 | Conair WW60 Weightwatchers Scale
The "ron" on the display
If we are talking about a conair weight watrchers sclae i contacted manufacturer as this is quite the little eppidemic I have 3 of you with same problem. here is the response:
Dear Consumer,
Thank you for your email.
Simply mail us your defective product or part with a detailed letter stating your name,mailing address, model , serial number, a brief description of the problem , a photocopy of your receipt and a cheque made out to Conair Canada for Conair products($5.00) or Cuisinart Canada for Cuisinart products ($10.00) for return shipping. Your product will be serviced and or inspected for possible warranty repair or replacement.
Please note that all replacements will take from 3-6 weeks and will not be replaced immediately. They must go through are technical department for testing.
Please also be advised that we do not have a reimbursement or refund policy.
CONAIR/CUISINART CONSUMER PRODUCTS
100 Conair Pkwy
Woodbridge ON
L4H 0L2
Tel: 1-800-472-7606
Sorry for any inconvenience this may cause.
Regards,
Consumer Service Representative-CP
Apr 09, 2009 | Health & Beauty
Why does my scale only display RON when I step on it?
I contacted conair about this problem below is the response.
100 Conair Pkwy
Woodbridge ON
L4H 0L2
Tel: 1-800-472-7606
Regards,
Mar 22, 2009 | Conair Weight Watchers Glass Digital Body...
Conair Weight Watchers WW-87 Body Fat Glass Scale Logo
1,517 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
