Question about Kenmore 24032\24036 Top Load Washer
My Kenmore washer makes a whining noise while pumping water
My Kenmore washer makes a whining noise while pumping out the water, although still cycles fine at this point.
  • jim treitman Jan 15, 2013
    My Kenmore Elite Calypso top load washer started throwing a "LD" code. I took it apart and found lots of goodies in the pump. Cleaned it out and reassembled. Now it makes a whining sound when it empties. Otherwise, it seems to be working.,Any ideads?
  • 370 Answers
This is caused by the pump. Replace or clean out the pump.
Posted on Feb 02, 2009
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
I have a kenmore elite h3 washer - Bad Water Pump?
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects(located, and mounted on the actual pump)
If the above does not correct the problem replace the pump
Nov 02, 2009 | Kenmore Elite 45986 Front Load Washer
The whining noise is usually caused by the pump. Try replacing the pump. Or cleaning it out.
Feb 01, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore quiet pak III dishwasher has a whining noise
Most of these dishwashers have separate circulation and drain pumps and there is a good chance that there is an issue with the circulation pump impeller issue under the lower wash arm. The bottom panels under the door can be removed to check it out.
Chris Z ---
Jan 25, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore makes whining noise as it tries to spin
The drive coupling has probably broken. Usually happens when you overload the machine. Easy fix. READ MORE
Jan 21, 2009 | Kenmore 24902 Top Load Washer
Kenmore 80 series washer make high pitched whining noise
cold water screen in hose was half plugged causing it to either shut off the spin cylce due to lack of water or increase the spinning speed.
Hope this solves the problem.
Dec 10, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Washer
if whines when filling not pump but fill valve try adj faucet toward off slowly this may reduce noise also be sure all screens are clear ..replacement not necessary if you don't mind noise if noise in pump out remove hoses to pump on bottom remove 2 clips holding pump on remove pump and clean
Jul 31, 2008 | Washing Machines
Whirlpool Calypso washer
Sorry Paige, just got back from vacation. For a whining noise, I will give you the solution that you can perform yourself without specialized tools.
Often there is a whining noise associated with pump (it turns a different direction depending on the point in the cycle. Let's check for a restricted (would still let water drain) or frozen pump.
Pull the washer forward and then tilt the top back so the washer is leaning against the wall about a 45 degree angle (when you get the right angle the washer will balance against the wall by itself without you having to hold it. Now remove the 3 5/16 screws from the front of the bottom panel. On the right hand side, follow the 2 short black hoses. They connect to your pump.
On a old style pump, there are two clips you can snap off and the pump will drop down. New style pump, there are 4 #20 torx screws that have to come out. HOWEVER, there is always water inside these hoses. Make sure you have an area that water can easily be contained, a LOT of towels, or just disconnect it and take it outside. First try taking the black drain hose on the back and lowering it from the hole in the wall into a container at ground height. This can start a siphon that will get most of the water out. This works really well if you have a wet/dry shopvac to attach to the end of it. If this doesn't work, then you will have to disconnect the black hoses at the pump to let the water out. If the pump has no debris and can move freely, then it's time for a service person. These washers use specialized tools to work on some parts ofthem.
Jul 26, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washer making noise in spin cycle
Is this unit new? I had a frigidaire that would really get to going on the spin cycle. Got the clothes really dry and sounded like a jet engine if no clothes were in it. Is it a whisling sound or screeching sound...The sound could be coming from the water pump. It may have something in it that is dragging. Some you can take the bottom off of and clean them out..
Feb 10, 2008 | Washing Machines
Whining noise, only in rinse and spin cycle, sounds awful.
Check the pump to make sure there isn't something stuck in it.
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore 24032\24036 Top Load Washer Logo
182 people viewed this question
Sal De
 Brian Main
Brian Main
