Question about Rainbow E series Canister Wet/Dry Vacuum
My Husband put a cleaner in the water when turning the vaccum on.
Now it won't come one. The hand held part works and is getting power. The motor is not turning at all with the canister part. Could he have burn the motor up or could it possibly be something else?
Thank you
  • bobbisue52 Feb 23, 2009
    Rainbow does not come on when on/off switch pushed. Power head works, but no suction
  • Rainbow Expert
  • 324 Answers
If nozzle works but the main unit does not then it leaves only few things - motor is "kaput" or some wire got loose somewhere. When motor burns it usually stinks pretty bad.
You have to open it up to see and test. We can do it for you but you'd have to ship it here.Se instructions
Posted on Feb 26, 2009
Hand held vacum suction stopped after 1st use. Was working fine, suction does work if onfloor but won't once turned to tool
go to the web page and see instructional video and maintenance help
http://www.bissell.com/how-to-videos/
God bless you
Jul 19, 2012 | Bissell 2X Proheat 9200 rug cleaner
Vacuum cleaner does not work
most upright vaccums have a reset button at lower rear area of the vaccum. operates similar to gfi plug reset, push button back in usually with small screwdriver. is your debris bag to full? power brush jammed with debris? hose plugged? this will cause motor to over heat and in turn kick out reset button. always unplug power cord before putting fingers in areas where moving parts are!!
Jan 01, 2012 | Bissell Vacuums
Shark SV736R motorized brush won't rotate
The 2 metal pins of the motorized brush are not in contact with the vacuum cleaner. or the Motorized brush is clogged up. You have mentioned that it is cleaned, but still give a thorough inspection. For the metal pins, firmly insert the motorized brush into the air-intake nozzle. This will connect the motorized nozzle to the unit power supply.
Oct 21, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
We just bought our dyson 2 weeks ago but when i was vaccum our carpet my husband necktie caught and **** by the vaccum and stop working! my husband suspected that it broke the motor of the vaccum. it is 5...
Sorry to hear you're having difficulties with your DC24. Your cleaner is equipped with a safety device which shuts off the brushbar if it gets tangled with a rug fringe, shoelace etc. After making sure the brushbar is free of threads, hair or other obstructions, you'll be able to reset the cleaner and get the brushbar running again. The easiest way to do this is to follow the steps shown in our online support guide:
http://www.dyson.co.uk/support/help.asp?article=1502&product=DC24-ALLFLOORS
Use something like the eraser-end of a pencil to depress the reset button, and make sure you push it in firmly until you hear an audible 'click'.
Please note, the brushbar will never rotate when the cleaner is standing in the upright position, or if you've turned it off using the silver brush control switch located next to the red on/off switch.
By following these steps, you should be able to resolve your issue without further assistance. However, if you've tried this and are still concerned, it's probably best if you get in touch with us directly. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to run through some troubleshooting over the phone with you recommend the best course of action.
Kind regards,
Jack
Dyson Online Customer Support
Sep 02, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
Hello, I have a Hoover 3200 Turbo Power vaccum. while the motor appears to be working fine the vaccum no longer picks up the dirt. I turned the vaccum upside down and the belt appears to be broken. would a...
take the vacuum head off the end of the tube , turn the machine and place your hand over the end of the tube
if it sucks your hand onto the tube , the machine is working as a vacuum machine
then check fro a blockage in the elbow section near the head
if there is no vacuum , junk it and get a new one
Jun 30, 2017 | Hoover Vacuums
The motor will not turn on. One minute it was
Called the phone number posted on the vaccum cleaner itself and my husband received technical support directly from Dyson. Problem solved at no cost to us. Vaccum is working fine.
Jun 03, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Rotating brushes will not turn
If belts are ok then possibly needs new front brush motor replaced.
Nov 05, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Rainbow E series Canister Wet/Dry Vacuum Logo
91 people viewed this question
Top Rainbow Vacuums Experts
Chris Nomland
Chris Nomland
JoeVacs
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
