Question about Sony Playstation 3 (PS3) Console
I was playing a game in my Playstation 3, but then the the Playstation turned off by itself, with a red light flashing. I try to turn it on, but then the green light goes to yellow, and then flashing red. That happens every time I try to turn it on. I also have a game, Skate 2, inside.
  • 4 more comments
  • cwaustin85 Feb 07, 2009
    I have just had the same exact problem happen to me just now and I was just using the playstation home when it occured. My system will not even respond; and it's the same way filipe_assay's describes his problem.
  • Anonymous Feb 07, 2009
    I have the same problem.
    I was playing Lord of the Rings: Conquest when suddenly the PS3 shut down.
    I try to on it again and the red light appears. I try the on/off button and instead of the light turning green the console just shuts down. I have tried many times and failed. The disc is still in it.
    HELP!!!
  • MarianneTan Feb 07, 2009
    HELP!!!
  • Smithy22 Feb 07, 2009
    Me too !
    The console switched off with the red light flashing. In the hand book it say's it may be getting too hot so it should be left to cool down. I've done this (overnight) but as soon as I switch it on the green light goes to flashing red within seconds.
  • agentxing194 May 11, 2010
    you could have the controller set to turn off after 10minutes or the
    console set to turn it self off .go to game setting and turn the setting to off
  • jeankldo May 11, 2010
    can u tell me what u wer doing on the game wen ur ps3 turned off?
Nickstar19
  • 417 Answers
SOURCE: my playstation 3 wont start
There is nothing wrong with the PS3. I read in the users manual that when the the green light on the PS3 turns yellow or flashes yellow the PS3 is too hot and you need to turn it off. It has never happened to me because I keep my PS3 in a open area.
When the PS3 gets to hot you need to let it sit and cool for a little while and then you can turn it back on and start playing again. If the PS3 cools for a while and it still doesn't work you need to call Sony.
Posted on Jul 07, 2008
SOURCE: playstation 3 flashing red light
mine too
Posted on Jul 13, 2008
  • 11 Answers
SOURCE: PS3 light turns GREEN, w/ blinkin BLUE, to YELLOW, to flashin RED
it is fried and needs repairs if you break the seal by trying it yourself you void the warrany
Posted on Mar 15, 2009
  • 13 Answers
SOURCE: playstation 3 turns green then yellow then red
The problem is known as a YLOD on the PS3 or Yellow Light of Death. Your PS3 is most probably a 60gb model as they are mostly known for this issue. The PS3 is fitted with a very good cooling system. Unfortunately some of the 60gb models still overheats (either the GPU or CPU). This causes the YLOD and is very similar to the XBox' s Red Ring of Death.
The best is to return the PS3 if still under guarantee. You can attempt to repair it yourself at own risk. There are no statistics on how long the fix lasts. Most of the YLOD consoles I repaired myself are still holding out and it seems the fix is more permanent than the Xbox 360 fix. Here is a link to the guide that must be followed and it works (http://www.youtube.com/watch?v=4_Ic1_TY-GU) The other parts in the series you will find on the same page. There are 7 parts
After the fix a couple of things can be done to prevent future overheating:
Do not keep the PS3 in a confined space.
Keep it away from dust.
To enhance airflow, remove the cover over the HDD when switching it on.
Switch it off when not playing.
Posted on Jun 30, 2009
  • 742 Answers
SOURCE: i have playstation 3 model # CECHH01, a game is
well sounds like your PS3 needs to be reflowed or reballed. I would highly recomend you have a professional do the repair. as fas as having a game stuck inside the machine you can get it out in under 10 seconds by doing this.<br /> <br /> 1) turn off power switch in back of ps3<br /> 2) place finger on eject button and hold there while ps3 is off ( no red light) <br /> 3) while holding finger on the eject button turn power switch on the back of ps3 on , hold finger on eject button untill the disk ejects.<br /> 4) turn power switch off and have unit repaired or replaced. <br /> <br /> if unit is covered by warranty and you send it to sony you must get your disk out of the system as you will NOT get it back if you send it to sony. Most reputable repair shops will return your disk with the system or give it to you before they take the system in for repairs. I ALWAYS give the game disks back before a customer leaves my shop as it leaves me with less to keep track of.
Posted on Aug 23, 2010
PS 3, switched itself off, I now have a flashing red light. Try to power up, 3 beeps and yellow light briefly, then flashing red light.
the best answer is to play online games without any headache. I have been playing all sort of car games and other stuff from so many years without  any problem.
Aug 06, 2011 | Sony Playstation 3 (PS3) Console
We've got a 60G PS3, today whilst my son was playing on it, it hs shut off completely. Cannot be turned back on, displaying a flashing red light. I thought it may have overheated; so we left it for an...
Sorry, but you have the yellow light of death. This is not fixable using ordinary household equipment. Call sony, yellow light normally means catastrophic hardware failure.
Feb 25, 2011 | Sony Playstation 3 (PS3) Console
When i turn on my playstion 3 console it switches back off and shows me a flashing red light and the if i keep trying for about 1 hour it turns on but then when i turn on the game to play it switches...
there are series of problem in ps3 which can be solved without much technical knowledge ........ your problem belong to that so dont worry i will give you the link to download the ps3 repair guide that will help you a lot Click Here
Dec 06, 2010 | Sony Playstation 3 (PS3) Console
The playstation 3 shut off in the middle of play. Now the little red light just keeps blinking. We unplugged it made sure theere was nothing blocking it to cause it to over heat, we plugged it back in and...
If the system turns on but then turns itself off, beeps at you and flashes it's lights at you then you have over heated the system. The GPU chip has probly pulled itself away from the board. This will require you to diassemble the PS3...... u just fix this by using ps3 repair guide....
click here to download
Oct 11, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wont stay on
charge it red light turning of and beeping is meaning its dead
Mar 02, 2010 | Sony Playstation 3 (PS3) Console
Playstation3 dont wanna stay on
if your tv still works there is a good chance that your ps3 just shorted out if you play when there are storms get a circuit breaker
Jun 19, 2009 | Sony Playstation 3 (PS3) Console
Mar 15, 2009 | Sony Playstation 3 40GB System Console
I cannot play games
if it sound like 3 beeps then it goes off that means that the ps3 freezes while opening the game so it switch off itself
Aug 25, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
22 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
