Question about Ariston Technologies AW125NA 13 lbs. Load Capacity Washer
Dial keeps spinning
The dial on the machine just spins round constantly and so does the drum i have lost the instruction manual what can i do?
  • 28 Answers
Det program selector spins around when a fault is noticed. It can indicate many types of erroes. But most common is blocked pump.
Posted on Jul 27, 2009
    Problem Solver:
  • 5 Answers
I have an Ariston Margherita AL128 and the same problem happened. The dial keeps on turning and the operation does not finish at all. After skimming through the manual, it occurred to me that it could be the pump that's causing not to drain or spin anymore. Dislodge the white covering infront (just located at the bottom). Once opened, unscrew the black button at the right hand side. Once open, check for blockages like coins, loose items, even lint. This worked for me and saved me $$$!!!! Now my Ariston is back to its superb performance. Do read the manual once in a while, it does help! I lost mine but was able to download a copy from the net.
Posted on Feb 07, 2009
My washing machine has just decided to stop before spinning and the dial continues to click round and round and round... Its still full of water...... What do i do?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 05, 2011 | Indesit Washing Machines
I have a new machine beko wm 5120 W and tried to re-spin some items after they had been through a wash cycle...i turned the dial to spin, chose my spin speed and pressed start...the machine went through a...
No idea why but it happens to us to. You need to cancel the wash, switch off and leave a few mins then retry, not that it may work.
Now the spin cycle has stopped on ours too plus the spin is not actually working, drum is just going round and round slowly! We've had it just over a year so the guarantee has finished too :-(
Oct 31, 2010 | Washing Machines
Candy grand o not spinning when loaded
Kindly replace the motor to solve your problem
May 17, 2010 | Washing Machines
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
My Candy automatic washing machine will not spin
Try the drive belt from motor to the drum it could have stretched a little? The noise you can hear could be the heating element catching the inner drum or something like a wire from a bra came loose in a wash and is trapped between the drums ?
Nov 05, 2017 | Candy Washing Machines
Kenmors 110 keep spining
The tranny should either spin or agitate not both
Nov 02, 2008 | Kenmore 24032\24036 Top Load Washer
Dial clicks round
Open the rear panel and look for a broken or worn belt. If this is the problem you can replace it easily. Good luck !
Jun 15, 2006 | Ariston Technologies AWD121WH
Washing Machines Logo
328 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
