Question about Philips GOGEAR SA6045 MP3 Player
My mp3 hang and its not playing anymore.I try to make it lowbat and charge again.i thought it will play but instead it hang the same problem occur.
  • billy1701 May 10, 2009
    it wont turn on
  • 8,596 Answers
Get the updated version of the Philips Device Manager and click the "Update" tab - the firmware upgrade Doctorshould resolve your issue.
-Tha Mp3 Doctor
Posted on Feb 14, 2009
Why will my sweex clipz mp3 player not turn on?
Perhaps you thought you were hanging the battery, but the battery already died. So to won't give any power. Try to switch it on while charging and then unplug it. When it switches on, you know the switch is still working. When it dies as soon as you unplug it, your battery must be replaced. (or buy a new MP3 player)
Jan 27, 2015 | SWEEX Clipz MP303 2 GB Flash MP3 Player -...
Keeps restarting itself
Sadly, some batteries will wear-out within a certain amount of months, and some may go even greater lengths until they will require replacement. This is one thing many people may not know when they are charging their device: Devices that use internal rechargeable batteries also use extra memory to know the charge limit point. So if you charge your the battery the device must know when to stop so the battery wont over heat and be damaged. This memory used to charge your battery can also be confused and malfunction, so that the device wont get proper power supply from the battery. This malfunction will usually occur when you plug in your device and use it at the same time or if you charge your device at random moments instead of letting it get to it's lowest power point then charging it again. I suggest that you let the device die fully, then let it rest for a few days, then while you charge it, have it off instead of on, that way the charge wont interfere with the screen info and let it charge as long as it is said to take on the manual that came with the device. If this fails, try 2 more times,if no luck after, have the company change your battery, dont try to change it yourself if it's bulit in, because some batteries require soldering a similar technique to welding something together, you can do this your self if trained, but you may also void a warranty if you have one with the device. If you'd like anymore info on your device leave a message for us at Game-Shabang official on Facebook, thank you
Oct 25, 2013 | Audio Players & Recorders
Dvd player dv692h hangs after 1hr of play
Hello
Check the CD for any defect. Hold it against light and see whether there is any tiny spots. If the CD is faulty this kindl of fault can occur. OK.
Jan 09, 2012 | Televison & Video
My mp3 isn't turning on even thought it is fully charged but plays music when plugged into USB
There is a Problem with the Mp3 Battery its not Charging get it Replaced!
Dec 29, 2011 | Audio Players & Recorders
Hi my aquabeat is showing as removable disk j instead of speedo multi media disk i can't add music please help thaks karen
I have the same issue. I tried to reset it, but unsuccessfully.
It does charge, but windows is not recognizing it anymore and I can't play the tracks.
Jul 24, 2011 | Speedo 7410061 MP3 Player
The ipod is just been hanged and it is not responding to any keys
when the ipod was hanged i was waitintg for half an hour then i just pressed the play/pause button it started to deactivate from the lock then again i pressed the play/pause button it switched off then i charged and i started using ............. anyway i am very happy that you tried to help me through ur premium assistance plan..............can i ask a favor ...........that is can i become a fix ya.com member or an expert!!!!!!!!!!!!!!!11
Dec 31, 2008 | Apple iPod nano
Frmtread error
how can it solved?? My old mp3's work perfect, now i made a new mp3 cd on the 700 MB space, but it doesnt work anymore.. i get ERROR 23 on my display.. what to do??
Jul 02, 2008 | Pioneer DEH-P3500 CD Player
Oops...still have problem playing MP3.
you need to reflash the phone and that memory card made need changing.
May 25, 2008 | Nokia 6233 Cellular Phone
Samsung YP-U3 won't charge anymore
it is possible that either your cable is bad or the battery is dead. but first try hitting the reset button on the back-(it is a tiny hole on the back, towards the bottom) - use a small paperclip
Mar 13, 2008 | Samsung YP-U3 MP3 Player
Machine hang
Have your tried reinstalling the drivers?
Mostly, hangs occur when the video card gets hot. Make sure it is properly ventilated, try and clean some dust up a little too as it impedes the air flow. Try cooling the system if you have a room air conditioner or just open up the case while playing and see if it hangs again...
Dec 09, 2007 | XFX GeForce 6200 Graphic Card
Philips GOGEAR SA6045 MP3 Player Logo
483 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
