Question about Philips 47PFL7403D 47 in. LCD TV
Small flickering green line on my lcd screen.
I recently bought a Philips 47pfl7403d lcd tv. I have only had it for 2 days and just noticed a small flickering green line near the upper center of the screen. I have a ps3, hd cable, and dvd player all hooked up through hdmi cable. I have noticed it no matter what device is playing, so I am assuming that it is the t.v. Can anyone help? How can I fix it?
  • ripacrombie Mar 03, 2009
    I have the same problem, have you found a fix for this?
  • Anonymous Mar 21, 2014
    My TV has started flickering every few seconds and usually also cuts out the audio. It doesn't matter what input is being used. It often goes to a green or black screen in between flickers and sometimes the control panel comes up on the screen and blinks for no reason.
I had the same problem, and I just updated the tv's drivers to the new 1.15 version. I don't see the green anymore.
Posted on Mar 20, 2009
I can second this. Once I updated the drivers, I no longer seen the green line.
Horizontal green line bottom of screen at switch on, disapears on restart
HI HARD TO SAY WHATS THE PROBLEM AS THEY ARE SO MANY TO CONSIDER...
COULD U UR VIDEO CARD...BEST TO GET IT CHECKT OUT FROM A RAPAIR SHOP
Oct 18, 2013 | Philips 47PFL7403D 47 in. LCD TV
Philips 47pfl7403d/f7 LCD TV When the TV is
first you may check the T-CON board if thats ok then the problem is coming from your set panel .
Sep 01, 2013 | Philips Televison & Video
White horizantal lines on my lcd tv
You could have a bad ribbon connection between the t-con board and LCD panel. Could also be a defective LCD panel or defective t-con. I would recommend you get a diagnoses
Nov 27, 2012 | Philips 47PFL7403D 47 in. LCD TV
I bought philips model no. 47pfl7403d/27 in 2008 .Suddenly last month it started skipping picture but we could hear sound.After few days it started smelling like something is burning and it stopped...
Seal deal w/ ours. I took it apart and the power supply board had the burn marks on it. Just ordered another power supply board (pn: 272217100571) for ~ $100. TV back panel comes off fairly easily to get at boards.
Jun 14, 2011 | Philips 47PFL7403D 47 in. LCD TV
Small green line on right side of screen
This is an easy fix using the Philips remote control that came with your tv. On the center of the remote is a dial that has left right up down controls. Stand in front of the tv and using those controls you can recenter the screen and get rid fo the green line. I had same problem when we hooked up hd satellite reciver to philips 37 plasma
Feb 18, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
With hdmi input there is a green line on the right side of the screen
try the other 2 ports if it stll happens it may be the cable if not then it will be a fault either at the source of the signal or the tv is faulty
Aug 06, 2009 | Philips 47PFL7403D 47 in. LCD TV
Lcd screen damaged by kid hitting on screen by buttter knife
The front main screen polarizer is damaged. Only two options are available for it. 1. Order a replacement panel, which will cost more that what u probably bought the tv for. 2. Buy a new TV.
Apr 04, 2008 | Philips 42MF531D 42 in. LCD Television
Philips Flat Screen Green Lines
The LCD Panel is defective. You will need to replace the LCD Panel. It will probably be cheaper to replace the monitor since the LCD Panel may exceed the monitor cost.
Single lines of single color (red,green, blue) are LCD panel failures.
1 or 2 lines of single color are LCD Panel failures.
Multple color lines could be anything so in this case you start by checking the power circuit.
Nov 28, 2007 | Philips 20 in. TV/VCR/DVD Combo Flat...
Philips 47PFL7403D 47 in. LCD TV Logo
806 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
