Question about Goodman GMS80904BNA Open Flame Mid-Size Heater
Will randomly light for a few minutes then shut off. wont come bk
Wont light all the time have power going to the main pcb but not out of the pcb. high limit switch checks out ok. could it be the pcb of fan motor?
    Novelist:
  • 189 Answers
Yes
Posted on Mar 08, 2009
Plasma tv shuts off randomly
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Apr 04, 2016 | LG 60PN5300 60" Plasma TV 1920x1080, 600...
My rexton 2005 sometimes won't start. but if u lock it up and go bk which could be between 10 mins and 3 hrs.it starts up without a problem and it's random on it times. any idea please
Does it not turn over or it turns over but wont start?
If it will not turn over I would check the ignition switch for loose connection. If it turns over but wont start check the fuel pump relay.
Sep 17, 2014 | 2005 SsangYong Rexton
LG 52SX4D turns off randomly.
My Lg 52"tv turn off and on
Apr 29, 2009 | Televison & Video
Sandisk sansa clip mp3 shuts of and wont turn back on...
You can set the timer under Auto Power Off and Sleep settings to turn off the Sansa
player automatically when it is playing for a certain time.
1. Press Menu button to return to the Main Menu.
2. Move to Power and select it.
3. Select Auto Power Off or Sleep.
-Tha Mp3 Doctor
Nov 06, 2008 | SanDisk Sansa Clip MP3 Player
Flashing yellow
Good Day, davidsonkens;
Try the lamp first; to check try this:
1. (Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 3. (Lamp may light and go out) Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 5. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB (ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010. Good Luck, big IRISH. back.gif
Jun 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
TV turns OFF and ON
No it is not. There is no fransfer of memory for the power module, but there is for the control module (main pcb). RCA also has a problem with 2 connectors that go bad. One on the power pcb and the other on the convergence output pcb. They are white in color. The good ones are black in color. Look for the 2 ribbon cables that connect from the main pcb to the power pcb and see what color the connectors are.
Apr 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power on/off problem
If possible go for a repeareing.
Feb 18, 2008 | Computers & Internet
Timer light blinking
Check C81A2, C81A3, C81B3 and C81B4 (1000 uFD, 16V, 105C) on the DM PCB.
Check C8F19, C8F21, C8F22 and C8F27 (1000 uFD, 16V, 105C) on the FMT PCB.
If any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
Nov 11, 2007 | Mitsubishi WD-62725 62" Rear Projection...
Heating & Cooling Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
