Question about NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614)
Need to open port on a netgear
Hi i need to open ports on a netgear wireless router and i dont no how
  • m-mt Feb 23, 2009
    i am trying to open ports to play street fighter1v i can play pro evolution 2009 online but not streetfighter or anybody else please can yoou help me
  • spyzampinoy May 11, 2010
    what is the model of your netgear router?
  • 854 Answers
A. Determining the IP Address and MAC Address of a Computer (street fighter1v):
Note: Please use the computer for which the Ports are to be opened:
For Windows 2000/XP users:
1. Please click on Start and select Run.
2. Type in cmd and click on OK.
3. In the Command Prompt, please type ipconfig/all then press Enter or Return key.
4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. for the computer and for the router).
5. Please note down the IP address and Physical address.
B. Reserving an IP Address:
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing or in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Opening Pre-Defined Ports for Internet Services:
1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced menu.
2. Please select the service type Port Forwarding. The router pre-defined services are listed there.
3. From the Service Name pull down list, select the service that needs to be hosted.
4. Enter the IP address of the computer in the Server IP Address box.
5. Click the Add or Apply button.
6. Repeat all steps to open more ports.
Note: If the name of the Internet service does not appear in the drop down list, you may manually open the ports for that Internet service. Please follow the steps below:
D. Opening Ports for Games, Applications or Custom Ports:
1. Click on Add Custom Service button.
2. Type the service name in the Service Name box and the lower range numbers in the Starting Port box.
3. If the application uses only a single port; type in the same port number in the Ending Port box.
4. If the application uses a range of ports; type in the higher range numbers in the Ending Port box.
5. Type the IP address of the computer in the Server IP Address box. Click Apply button.
6. It will then refresh to the Port Forwarding page, and will show the list of all ports opened in tabulation.
7. Repeat all steps to add more ports for more services.
E. To Edit or Delete a Service Entry:
1. Click on the Radio Button that needs to be Edited /Deleted, under the Port Forwarding page.
2. Modify the information from the Service Name, Starting Port, Ending Port, and the Server IP Address, and then click the Apply button.
Posted on Apr 25, 2009
I am trying to open up port 25565 on my NETGEAR WNDR3300 dual band router. I access my default gateway through an internet browser and forward the port correctly, but when I go to a website to check to...
If you have ports in your router , even it it shows that the port is closed in if the application for which you have forwarded the ports works then no issue with that. If it doesn't work then we need to know who is your internet service provider , because its is a DSL connection which works in the Dynamic configuration then its obvious the port will not be forwarded beacuse of double NAT. Inorder to fix this you have to bridge the DSL modem .
Thanks & Regards,
Jan 06, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
Netgear rp614 wont port forward
my hp previon labtop (vista) does not detect the sognal from the netgear router . How can i solve problem
Jul 16, 2009 | NetGear RP614 Router
How do I port forward my router (netgear dual range -N- wireless)
You log into your netgear and under firewall you add the port exception to the list.
If you need additional help tell me the model of your netgear router.
Dec 18, 2008 | NetGear RangeMax Dual-Band Wireless-N...
Opening of pprts in netgear,
Try going to Port your router model and follow the instructions.Hope this works for you.
Nov 20, 2008 | NetGear WGR614 Wireless Router
Router configuration
Go to:
Just insert the model number, and voilá!
Good luck.
Oct 14, 2008 | NetGear RangeMax Dual-Band Wireless-N...
Nat ports
Go to the port range forwarding page on your router's setup.
It will ask you for the specific port. (88,3074) Enter them in in their own seperate sections. Then select either UDP of TCP for each. Then save the settings and you should be good to go.
Apr 06, 2008 | NetGear WGR614 Router
Problems with netgear wireless router
picolas and nannysboy,
You can setup your router any way you like after accessing it. You don't need software for NetGear. All you have to do to access the control panel is:
  1. Open your browser.
  2. Type in this ip address -
  3. Configure the router as you see fit. It's fairly simple and has built in help guides.
If you cannot connect by wireless, do the above while connected by a LAN cable (looks like a telephone cable, only fatter and wider).
The router should be connected as follows:
  1. WAN port directly to cable/dsl modem.
  2. Any port (1-4) running out to your computer.
Please let me know if this helps. Good luck!
Feb 24, 2008 | NetGear WGR614 Wireless Router
NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614) Logo
297 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
