Question about Delta & Leland Lavatory Faucet
Water Temp not hot in shower
I have a Delta Leland faucet in the shower, the water temp is not hot enough. Can you please tell me how to remove the faucet so I can adjust the temp guard.
    Problem Solver:
  • 19 Answers
You need an allen key to remove the handle once the handle is removed than you need to turn the grey plastic temp guide counter clockwise as far as possible
Posted on Feb 02, 2009
Water not hot enough. How do you adjust the temp?
Hot water temperature is controlled at your water heating source.
Sep 01, 2010 | Delta & Single Handle Shower Faucet
I'm not getting enough hot water from my delta 14 multi shower faucet. How do I set the temp?
Go to the link below then click on download. This will bring up a pdf file for the Delta 14 series. Scroll down to page 5 for instructions from Delta on how to adjust the temperature after removing the handle.
http://www.deltafaucet.com/customersupport/documentation/T14430-LHP%20H74%20A74.html?document=mi&documentIndex=0
Jun 03, 2010 | Delta & Single Handle Shower Faucet
Only warm water from the tub/shower
You can cap the lines at the tub faucet to rule out tub faucet. It maybe mixing there.
Faucet may be bad also the safety stop will alow you to change water temp it can be tricky to adjust water temp.
May 02, 2010 | Moen 1 Handle Lever Shower Faucet With...
Water in bathroom sink is hot, but not hot in shower. Have a Delta Victorian 1 handle temp. faucet in shower. It is turned all the way over as hot as it will go, and still not hot enough. Had new parts put...
Remove handle and it has a dail in faucet that can be removed and repostioned, just remember where you started. maybe take out and replace it a 1/4 turn counter clock wise that should open range of hot water.
put handle back on turn on and see what you have if not hot enough take back out and move it a lttle more and replace and try again.
main thing just remember starting point before you moved it.
Mar 04, 2010 | Plumbing
Water steams out of shower head when tub faucet is on
check the tub faucet the pull lever maybe slightly faulty causing back pressure in line and pushing water up to shower head --u may have debris in tub line causing partial blockage -or u have alot of water pressure coming in and it is to much for the lines to handle and it is pushing up to shower head
Feb 26, 2010 | Delta & Leland Lavatory Faucet
No hot water
you have to take the handle off
there should be an insert that you can adjust by pulling out and turning
May 28, 2009 | Delta & Single Handle Shower Faucet
Delta shower faucet
Please read here first:
http://www.plbg.com/forum/read.php?1,342033
You may need to call 1-800-345-DELTA (3358) or email them at customerservice@deltafaucet.com.
Mar 15, 2009 | Delta Plumbing
Moen posi-temp for shower pressure
Is this only happening in your shower? Or through the hole house? Maybe you shower head has a flow restrictor in it. Try removing it!
Jan 31, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Delta & Leland Lavatory Faucet  Logo
476 people viewed this question
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
