Question about RCA HD56W66 56" HDTV
My RCA TV Mode # HD56W66 is green and red.....how do I get it adjusted.
  • 1 more comment
  • donsaradale Mar 15, 2009
    We were watching tv and suddenly, the picture split into three distinct colors, red, blue, and green. It looks like a 3d movie. How can I fix this without spending $400 dollars (minimum quoted price) to "probably" have it fixed?
  • Anonymous Mar 27, 2009
    I have the same problem. 3-D images.
  • jessiedakota Mar 29, 2009
    I have the same problem. If you find th solution before I do, please advise.
Get a QUALIFIED TECHNICIAN!!!!!! or BUY A NEW TV!!!! ********
Posted on Apr 16, 2009
Where is the bulb located on a hd56w66 tv
If you have a HD56W66 it is not a DLP set it is a rear projection Tv set . id does not have a bulb it has three picture tubes one in red blue and green
Oct 20, 2014 | RCA Televison & Video
RCA HD56W66- Where to get replacement tube.
You can get the replacement Green CRT from www.tvrepairworld.com they guarantee the Projection CRTs
Feb 23, 2012 | RCA HD56W66 56" HDTV
My screen looks like its 3D.
Your tv has a problem with the convergence, adjust it using the original remote go to the setting's menu then go to the convergence section. Adjust the convergence color red and blue the green color is your guide you cannot move this green color, then you should move the red and the blue in all direction left to right, up and down. If you cannot move the red and the blue far enough the convergence IC is defective it must be replace in order to align this convergence. Feel free to send feed back good day and best regards.
Aug 14, 2011 | RCA HD56W66 56" HDTV
The picture comes on and the three colors are red top green middle and blue bottom part of screen
Ur tv have a convergence problems,it dead.U must know how to do soldering to fix convergence problems.Must replaced 2 STK convergence ICS,and some or all it resistors to get the convergence automaticly to reset it self or need a little adjustment require.Tries Websites Tv repair World.com,Tv repairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Mar 24, 2010 | RCA HD56W66 56" HDTV
Rca hd56w66 no power not even the green light power board looks good suggestions to find the problem?
Check the fuse. Its located on the right side looking in the rear of the TV its the small board where the power cord plugs into. The fuse is on that board.
Jan 01, 2010 | RCA HD56W66 56" HDTV
Tv turns on then right back off no pic or sound
It is in shutdown mode. You have an "overvoltage" (regulation) problem or their is a short in one of the many components causing it to be in "over current" mode. Could be as simple as a bad solder connection. This will take someone with some knowledge of the circuits and test equipment to diagnose.
Jun 25, 2009 | RCA HD56W66 56" HDTV
RCA HD56W66 convergence
Please do us a favor and rate this by cliking the thumps up icon located here >>>>>>
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 16, 2009 | RCA HD56W66 56" HDTV
RED GREEN BLUE CONVERGENCE IS OUT.
if you have a rca hd56w66 chasis itc222 you may have the common fl231 fuse problem. I see this everday at the shop. to determine if you may have this problem. i have written a little article on this subject. Consult tips and tricks section under my profile. Going into maintence mode might have reset some settings.
Nov 24, 2008 | RCA HD56W66 56" HDTV
Covergence problem
press and hold menu then push power then volume.
Aug 17, 2007 | RCA HD56W66 56" HDTV
RCA HD56W66 56" HDTV Logo
93 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
