Question about Dell W2606C 26 in. HD-Ready LCD Television
No Sound, Speakers Don't Work
Help! 7 hours until kick off and my speakers have no sound whatsover. Dell HDTV.
    New Friend:
  • 90 Answers
Audio board is burnt out and needs replaced. open unit, and trace speaer wires to the small audio bd. remove board, flip over. if burnt, thats the problem. must replace.
Posted on Apr 07, 2009
Sundenly my speakers don't have a sound technition checked for 2 hours and can't find whats wrong
depending on the operating system open sound in control panel and select the speakers if they are shown and right click and set to default, ensure the check box for "all devices currently playing sound is ticked" if this isnt working try pluging the speaker into an ipod to ensure theve not popped.
Jan 29, 2013 | Dell A215 Computer Speakers
Not sound on pc matherboard g33mo2 from dell
There was a problem with the internal speakers with this model.
Firstly, try a pair of external speakers plugged into the sound port, if these work , the issue lies with the internal ones.
If there is no sound through the external speakers, check that you have the sound driver installed, that the volume is set using the FN and F keys and that the sound icon on the desktop bar does not have a x through it indicating it is disabled.
You can download an updated sound driver from the Dell site, although i think Windows 7 comes with its own sound driver for this.
If the problem points to the internal speakers, you have a few choices:
Return the laptop to Dell under warranty (if it is under warranty)
Try to obtain a set of internal speakers and replace these
Takr the laptop to a computer shop and get them to check the internal speakers and repair if necessary
Dec 30, 2010 | Dell Vostro 1510 Laptop
Speaker wires are pluged in on my dell inspiron 530 but not working help
    • 1 Make sure that your computer and speakers are plugged in, have power and are turned on. If the speakers are plugged in but don't appear to have any power, plug them into a different outlet. Some speakers are self powered and use a USB cable to supply power. Make sure that the USB cable of your speakers is connected securely to the USB port of your computer.
    • 2 Retest the sound. If you still don't have any sound, make sure the cable connecting the speakers to the computer (known as a 1/8-inch TRS cable) is plugged into the green audio output jack on the PC.
    • 3 If you're using self-powered USB speakers, remove the USB cable and plug it into a different USB port. If you're using outlet-powered speakers and have a working set handy, replace the suspected non-working speakers with the working pair to test.
    • 4 Navigate to the Microsoft Fix It troubleshooter (windows.Microsoft.com/en-US/windows/help/no-sound-in-windows) to automatically detect and fix sound playback or hardware problems. If that doesn't work, proceed with the next step.
    • 5 If you have an add-on sound card and none of the hardware or software fixes helps, you may have to replace the sound card. If you use on-board sound, it will probably pay to purchase an inexpensive sound card rather than a new motherboard. Check the system BIOS to determine whether you have inadvertently disabled your on-board sound.
    • 6 Navigate to the "Start" menu and select the "Control Panel" and "Sounds and Audio Devices." Then click the "Volume" tab. If everything is grayed out, proceed to Step 7. If the "Mute" box is checked, uncheck it. In "Device Volume," make sure that your volume level is set to a comfortable volume level for your speakers.
    • 7 Click the "Sounds" tab. Under "Sound Scheme," determine whether "No Sounds" is selected. If it is, click "Sound Schemes." A drop-down list will appear. Select "Windows Default" as the scheme. To test your sound now, click on a sound listed below the "Program Events" window. The sounds will be indicated by a small "Speaker" icon located next to them. Left-click the sound once, then click the "Play" button. If you still don't hear sound, proceed with the next step.
    • 8 Click the "Audio" tab. Under the "Sound Playback" option, make sure your sound card is selected as the default playback device. Usually, only one device appears here, unless you have multiple playback devices installed.
    • 9 If everything is grayed out, you either do not have a playback device installed or your drivers are corrupted and need to be replaced. Drivers help hardware and software function together. Fix this by reinstalling the appropriate drivers. Do this by navigating to the "Start" menu and right-clicking "Computer." Then select "Properties" from the drop-down menu. Click the "Hardware" tab and then click the "Device Manager" button. The Device Manager will open.
    • 10 Look for either a red X or a yellow question mark listed under "Sound, Video, and Game Controllers." If a red X appears, right-click the device with the X and select "Enable" from the pop-up menu. Test your sound at this point. If a yellow question mark appears, right-click the device, click "Properties" from the pop-up menu, and then click the "Driver" tab on the window that appears. Next, click the "Roll Back Driver" button to roll back to the previous drivers that were functioning correctly. Restart your computer when prompted.
    • 11 As a last resort, you can uninstall and reinstall the device. To do this, right-click the device and select "Uninstall" from the pop-up menu. Restart your computer. Windows will automatically detect and install your audio device upon boot-up. If you still don't hear any sound from your computer speakers, contact a qualified computer technician.
Nov 14, 2010 | Dell Inspiron 530s Desktop Computer
My Dell AS501 does not produces sound. I have
make sure the power is hooked to the back of the monitor, and that the speakers are hooked into it. make sure it is switched on and volume is at 50% or higher. if it still doesnt work, try hooking an mp3 player to the speaker jack. if they work, its the computer. if it doesnt work, replace the speakers.
Dec 12, 2009 | Dell AS500 Sound Bar Computer Speakers
I have an Dell Dimension E510 running windows XP. I have 5.1 surround sound speakers that were working fine until recently. Only 2 speakers work; left and right. None of the others have sound. I have...
Reinstall the software for the sound system, this should redetect the speakers properly as 5.1 surround sound speakers.
If you do this and it still doesn't work then the speakers are bad and your sound system would need to be replaced.
Dec 01, 2009 | Dell Dimension E510 PC Desktop
2 Dell 5650 have no sound
the surround sound speakers plug into the rear of the computer with three plugs. an adapter comes with it to plug those three into one green plug. if you plug that green plug in, the rear and center speakers should work, although i don't know if the surround sound will work correctly but you should get sound
Apr 03, 2009 | Dell 5650 Computer Speakers
Sound is working but internal speaker is not working
Connecting headphones to the system will disabled the internal speakers until the headphone jack is disconnected, at which such time the internal speakers should function again.
If you disconnect the headphones and the internal speakers are not re-activated, then there may be damaged to the microswitch in the jack. (Try rebooting after the headphones are disconnected too)
Mar 01, 2009 | Dell Latitude D410 Notebook
No sound from Creative Labs Speakers- Please help
to localised your problem, try to plug your speakers to other sound source like mp3 player ,stereo system. if still no sound coming from it,your problem is within the speaker system. perhaps the audio power amplifier ic inside, need to be replaced.
Oct 12, 2008 | Logitech X-530 Computer Speakers
Sound Won't Work on Dell Computer
Go to Control Panel and go to sound and audio devices. It should have the name of the speakers you are using. If it doesnt then the speakers might not work on that PC. Get a new set of speakers, and try again. It should work on the new ones. If it doesnt, get it checked at PC World or a PC repair store to get it checked, as the problem will be internal in the PC. Hope it works.
Sep 15, 2008 | Dell Computers & Internet
Speaker Sound Issue with 2 of the 4 speakers
Try this, I work in the sound production busines. Your audio CDs are not designed for Quad listening, they are stereo. If you put a game in you will hear all 4 speakers.
Aug 24, 2007 | Dell WL6000 Computer Speakers
Dell W2606C 26 in. HD-Ready LCD Television Logo
113 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
