Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
52" Rca model#D52W20 Perimeter is blurred, almost bowed. Not very clear.
  • RCA Master
  • 3,459 Answers
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
52
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need52" Rca model#D52W20 Perimeter is - 69189a5.png See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Posted on Jun 06, 2010
D52W20 chassis ATC221 picture is fuzzy,blurred,unreadable.I do have a"convergence" option on the menu.have not done anything to the fuse fl231 yet.Will it help if replaced?The convergence does...
Yes - that may help if its done correctly...Sites like www.TvRepairKits.com have the parts and also parts with instructions to do it right the first time.
Aug 21, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tip
Tv picture has a bow in it and letters are doubled my 52" rca just started the...
I ALSO HAVE A 52 INCH RCA (2 YEARS OLD) I HAVE TRIED ALL OF THE TIPS THAT HAVE BEEN DISCUSSED. LUCKILY I PURCHASED THE EXTENDED WARRANTY ON THIS UNIT.. AFTER A MONTH OF OVER THE PHONE TROUBLE SHOOTING FROM WARRANTY REPAIR CENTER THIS INCLUDED REMOVING THE BATTERIES IN CASE THE REMOTE WAS BAD. THEY FINALLY CAME AFTER IT YESTERDAY. THE PICKUP BOYS SAID THAT THEY ARE HAVING A LOT OF TROUBLE WITH THESE UNITS DOING THIS SAME THING. THEY ALSO SAID THAT SOME WERE BEING REPLACED WITH NEW ONES. NOT SURE IF RCA OR WARRANTY IS REPLACING (MINE WAS PURCHASED FROM BESTBUY WITH BEST BUY WARRANTY). IF ANYONE HAS SPOKEN TO ANYONE ABOUT A REPLACEMENT PLEASE RESPOND. I THINK IF THERE ARE SOME UNITS BEING REPLACED WITH NEW ONES WE ARE MORE THAN LIKELY GETTING THE SAME DEFECTIVE UNITS (WHICH WILL MORE THAN LIKELY WORK UNTIL OUT OF WARRANTY). I WISH THEY WOULD JUST GIVE REFUNDS OR CERTIFICATES TOWARDS NEW DIFFERENT UNITS MAYBE IF THERE WERE ENOUGH COMPLAINTS THIS MIGHT BE CONSIDERED.
on Jun 22, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
I need a convergence kit for a rca 52 inch rear projection tv
what type of problem with convergence? no convergence at all? pitcure bowing? this in the setup menu do you have the convergence option? a convergence ki in a standad porojection has stk ic/s this model does not .you might have the fl231 fuse problem.. generally its board replacement. then the problem becomes alighnment.
Aug 23, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a rca model#d56w20 and the screen is bowing
You probly have a covergence power supply issue. The board is not available the last time I
tried to get one. If it has a stkXXX_XXX type regulator IC it is easily repaiable. I would suggest
a professional tech to repair it though
Jun 16, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Colors seperating and Screen bowing
The convergence circuit is not working. There are bad solder connections on the sweep board and a small fuse is open. this is not easily done yourself unless you have a technical background but an RCA tech can fix this easily.
Mar 25, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Double words and blurred picture,
Is the picture bowed in too. first consult "the fl231 problem" article under the tip and tricks section under my profile. THis MAY be the problem. Otherwise you have a convergence issue. convergence is controled by three cuicit boards in this set. Setting the convergence on this set is tricky. try autoconvergence see how far it gets. let me know and i help you trouble shoot further
Nov 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Model #D52W20
Its either the convergence power supply or the convergence board that you need to replace. Go to this site and leave them an email with your model number and what the symptom is they will be able to tell you for sure.
http://servicemanuals.vstore.ca/
May 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" TV AUTO CONVERGENCE WON'T COMPLETE
Sounds like your convergence chip has gone bad. Usually costs about $300-$400 to fix. I would call a local TV repair shop and let them give you a free estimate.
Jan 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w2052 d523c10df itc222
The issue is the Deflection board. The Fl1231 is open. The Deflection board needs replaced
Nov 11, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
117 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
