Question about Samsung T220HD LCD Monitor
Dark vertical stripe on monitor
Dark (but you can see through it) vertical stripe about 1.5 inches wide and full lenth down the SyncMaster T220 monitor. Showed up about 2 months after purchase.
  • Anonymous Mar 11, 2009
    Works wonderfully, but the screen shows a dark stripe that i can still see through that's about 2 inches wide, the entire length of the screen. It's a vertical stripe, by the way...
  • 54 Answers
You screen "LCD" is broken , need new lcd panel. Very expensive
Posted on Feb 01, 2009
My hp vs 15 displays vertical color stripes that alternate different colors wether its hooked up tp computer or not what is wrong, is it junk
It may sound strange but be absolutely sure the cable is plugged into the monitor. Adapter on the computer. The serial adapter on the back looks just like video. Video actually has a faintly noticeable monitor icon rigtht next to it. Plugging into a serial can eventually blow out your monitor. Also, a.badcable can do the same thing. And if you have messed up the monitor's settings you will see the same
Apr 13, 2012 | HP vs15 15"LCD Flat Panel Monitor
My Monitor, which had never been used but been in storage for about 1 year, has a 2 inch translucent vertical pink stripe down the left hand side. Rest of image is perfect. Any idea how to make this go...
Check the RGB settings from the monitor panel.... Plus try moving the neck of the monitor left and right a couple of times.... Sometimes, the picture tube displays illegitimate pictures with some twisted cables or so...
Jan 09, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
The auto-darken feature(monitor goes dark on dark
In your monitor panel you'll find 4 buttons. Press the menu button and get into Magic Bright. There you can choose the one that best suits you. You can even set to Dynamic contract where the monitor adjusts the brightness according to the elements on the screen
Jun 20, 2009 | Computers & Internet
Connect Digital and Analog cables at the same time.Any use?
does not help. keep dvi connector (white one) on computer and in the back of monitor.
and surely it will not take away those vertical stripes.
those vert stripes... hmm... your monitor might have a problem which you can't fix by your own.
Feb 22, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dark Grey Vertical Bar
1. try connecting laptop to an external monitor and check if this vertical dark gray bar appears. if yes it means video is the problem. you need to boot in safe mode then uninstall the video driver. boot to notmal mode then download and install the latest video driver. if still same problem then replace video card. if video is built in with motherboard you need to replace motherboard.
2. when the vertical dark gray bar did not appear in the external monitor then it means issue is with the LCD panel. Do this turn off laptop. press and hold D key then press Power button at the same time or Press and hold on the Fn key then Power button check if the test will run. Color displays full screen when you keep pressing on N key when the colors appears check the vertical dark gray bar if still exist in the test, this means LCD panel and LCD cable needs to be replaced.
Oct 31, 2008 | Computers & Internet
There is a 4 inch wide back vertical strup down the diplay screen
It is probably be a faulty LCD crystal, or a bad internal connection where the electronics meet the LCD. I would think it could happen if the monitor is jarred or dropped, I guess it could occur also if the monitor was brought in from the cold weather and condensation occurred inside?
Unless you have access to a trained LCD technician, your only option is return the monitor for exchange or repair, or buy a new one.
Apr 03, 2008 | Westinghouse LCM-19v1 Monitor
Dark Vertical Stripe on Right Edge of Screen
I experienced the same approx. 1/2" vertical stripe on a Viewsonic vx1945 and ATI Radeon x1050 video adapter on Vista Business SP1, but the stripe appeared along the left edge of the screen, instead of right edge. I then temporarily decreased the monitor resolution, and the stripe went away. I then increased the monitor resolution back to its original setting, and the stripe did not re-appear. So, that was the 'fix' in my situation, hope this helps.
Dec 11, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
SyncMaster 920n Monitor 1 1/2" greeen colour vertical bar
Samsung products does not require u to produce a bill during warranty, ur product info will be registered in the database of the customer care center. So you can go in and get ur claim with the warranty. And the about the green lines, it could be that something is wrong with your graphics adapter.
Oct 12, 2007 | Samsung SyncMaster 920N 19" LCD Monitor
Black Out
Hi Detrix, Check with www.lcdrepair.net if you want a repair. Something is wrong with your LCD controller and or GUI interface circuit or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. These circuits take the Signal from the computer and controls the 2.5 million pixels on the LCD screen. Dsut can cause major problems with handling all that data. Give it a shot, what do you have to loose, its not dangerous if the monitor is unplugged.
Oct 09, 2007 | Samsung SyncMaster 193P 19" LCD Monitor
Samsung T220HD LCD Monitor Logo
394 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
