Question about RCA Universal Remote Control
How do you program a rcr312w
What buttons do you hit to program this remote after code search to keep code lock in remote
I have a RCA312w remote and a Orion tv ....how do I set the remote to the tv?...
Posted on Feb 02, 2009
Try to turn on via remote or button on set. Only a green flash on front. Nothing else. Can I fix it?
About 435,000 results (0.80 seconds) Search Results
    3 Ways to Program an RCA Universal Remote - wikiHow
    www.wikihow.com > ... > TV and Home Audio > Television
    wikiHow... Universal Remote. Are you tired of juggling three or four different remotes just to control your home theater setup? ... Log in via ... Turn on the device you want to control. ... Press and hold the button on the remote that corresponds with the device.... You will need to try another method in this article to program the remote.
    How to Program an RCA RCR312W Remote: 15 Steps ...
    wikiHowHow to Program an RCA RCR312W Remote. ... Log in via ... Press the PLAY buttonevery five seconds until the component turns off. ... If component does not respond or has limited functionality, codes in a different block list can be tried until you find the code that allows the remote to .... Set Up a Home Theater System.
    Your remote reprogramming woes solved - Rogers RedBoard
    redboard.rogers.com/.../your-remote-reprogram...
    Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... You can always contact us via our Facebook page or tweet us ... Hi my TV is anRCA model # RLDED3258A-B I have tried 73 codes from Universal .... I have tried toset up my tv and home theatre with the Rogers remote but no luck...
    RCA TV: input channel/s-video - ecoustics.com
Jan 19, 2016 | RCA Audio Players & Recorders
Plis help with codes to control rcr312w
The RCA code finder can help: http://rcaaudiovideo.com/remotecodefinder/ . Use the drop down menu to choose the RCR312w and then the type of device you want to program. Then click Search.
For example: RCA TV codes to try are 10000, 11447, 10051, 10093, 10679, 11047, 11147, 11247, 11347, 11781, 12002, 12187
Alternatively, go to http://www.rcaaudiovideo.com/remotes/2-3-devices/?sku=RCR312W and click on the Support/Manuals tab. The manual and the code list are both available. The direct link to the manual is http://audiovox2.info/docs/common/RCR312W/RCR312W_OM.pdf . The code list is here: http://audiovox2.info/docs/common/RCR312W/RCR312W_OTHER_CL.pdf .
I hope this helps.
Jun 10, 2011 | RCA RCR312W Remote Control
I have an RCA RCR312W remote and lost my manual, request the steps needed to program my JVC tv / I have the codes, just need to know the steps to take ... Thank you
HI,
Direct Code Entry:
Find the code your device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
follow the below steps to set remote without codes
Code Search:
1. Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using the remote. If it does not function repeat steps 1 through 6
Thank you
Jan 16, 2011 | RCA RCR311B Remote Control
Need universal remote codes for RCA Remote RCR312W. I am trying to program an Emerson VCR/DVD Player with the Universal RCA Remote (RCR312W) and need the codes to put in or how to do a code search.
1.Go to the url below
http://www.rcaaccessories.com/rcaaccessories/RcaaccessoriesProductDetail.do?ACTION_TYPE_ID=ACTION_TYPE_PRODUCT_DETAIL&ACTION_CATEGORY_IDSTR_CATEGORY_UNIVERSAL_REMOTES&ACTION_PRODUCT_ID=RCR312W
2. Scroll down and select the "Support and Manuals" tab.
3. Click "Owner/User Manual" link
4. Click "Code List for RCR312W" link
Jan 20, 2010 | RCA 3-dev Universal Remote Remote Control
Needs codes for rca remote rcr312w
Goto this site
http://66.77.167.109/rcaaccessories/RcaaccessoriesController.do?ACTION_TYPE_ID=ACTION_TYPE_CATEGORY&ACTION_CATEGORY_ID=STR_CATEGORY_REMOTE_FINDER
Select your remote under ´SKU´ and ´Product Type´ like TV or DVD, and click for ´Search´.
Note
Instructions for how to program the remote control
http://www.wikihow.com/Program-an-RCA-RCR312W-Remote
Aug 21, 2009 | RCA RCR412C Remote Control
Need codes for rca universal remote rcr312w. for apex tv
With your model number at hand, check the RCA website for a later code list. If you are the exception, you might find one.
Most all remotes have a 'search' function that lets you scan through all of the available code sets but this feature will, in most cases, provide only minimal functionality such as Power, Volume and Channel.
In truth, there isn't any such thing as a 'universal' remote, including the 'learning' remotes; I have one of those and it is unable to 'learn' from either of my later sets' remotes. At best, these should be called (honestly) 'multi-brand.'
May 17, 2009 | RCA 3-Device Universal Remote with...
I cant find a code for my tv emerson ewc20d3
The emerson codes are : 0178 , 0179, 0038, 0177, 0280, 0154, 0236, 0463, 0180, 0282. If this doesn't work with your new remote there is always the way that I have done it in the past and that is to use the find the code function on your new remote. It is a pain but can be done and is quite effective. Each remote is slightly different, but for the most part you would hit the set up botton and hold it in until it starts flashing then hit the T.V. Button and then hit the first code it tells you to hit and then hit the power switch if it doesn't turn off your T.V. then you hit the increment button up, (this is different for each remote so it is important to follow the instruction manual on this part) You bassically keep hitting the incriment button until your code comes up and then it will turn off your t.v.! Then your done. Note: It may take up to 400 pushes of the increment button, but it will work.
Dec 14, 2008 | GE JASRM24912 Remote Control
I NEED PROGRAM CODES AND PROCEDURES FOR RCR312W
I can help. I too have an RCR312W remote and it did not work.
I found this code on bobvila.com message board. The code from the RCR311W remote works.
1) turn on unit
2) press and hold componet button on remote (TV, VCR, etc)
until On/Off lights up
3) press and hold On/Off while holding component button. Light will go out. Continue hoding both buttons until light comes back on.
4) release both buttons. On/Off should stay on.
5) Press On/Off repeatedly until unit turns off.
6) Press the Stop key at bottom.
7) light goes off. Remote is programmed!
Oct 17, 2008 | RCA Universal Remote Control
I bought your RCA universal remote that controls 4 devices. The code list does not list my Magnavox DVD/VCR combo (MWD2205). When I went to the website listed on the back of the remote...
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 16, 2008 | RCA Universal Remote Control
Televison & Video Logo
214 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
