Question about Digital Lifestyle FA1B32Z 32 in. LCD Television
36 in. Flat Screen TV with sound but no picture
When I turn the set on the picture comes on there is a kind of hissing/buzzing sound then the picture is gone and All I have is sound.
  • Digital Life... Master
  • 19,396 Answers
Try first unplugging power for ten minutes, if the problem persist, then it is either lamp, ballast board, or DMD board, you will need a tech to fix it.
Posted on Feb 01, 2009
  • Ginko
    Ginko Feb 01, 2009
    If this is an LCD , and you get sound but no picture, check the cable connections, if cable connections are ok, then you need to replace the digital control board.
    President:
  • 2,110 Answers
If you get some pictures the problem is most likely a bad tuner, as when directly connected a video source to the RF (Cable Coax) connector.
Try using an s-video cord instead.
If you never get any picturethe problem is related to the power supply, more precisely, the SMPS output is just a bit high causing the microprocessor to go into protection mode cutting off the horizontal oscillation, but as sound has a different power source from the SMPS, it will work without any problem. You will have to get to a qualified sercive engineer to fix this problem.
  • 10,594 Answers
Let me know exact model and brand of your TV to check its technical info for such problem.
Thanks.
I have a Phillips Fla screen and a few days ago it started making this loud buzzing/hissing sound that somewhat goes away once the TV is on but comes back with a vengeance when we turn the TV back on i...
Most likely if a buzzing or similar sound that is there even with set off--you have a noise coming from a transformer in the standby power supply which is running all the time if the set is plugged in----
Someone would have to open set and listen for it---either a part, a board, or hot glue would have to be used to mute the vibration that is making the sound----one way we locate is with cover off probe with a plastic tool to see where it is.
If you are not able to do this have a tech or a shop "look" for it.
Dec 03, 2012 | Televison & Video
Samsung tv blank screen
It,s shot, Get a new tv,End make shure not to get a samsung,
Nov 03, 2012 | Samsung Televison & Video
Samsung flat screen wont come on, hissing noise then bleep repeated every 10 -15 seconds or so, sounds a bit like a cd whirring and trying to reset followed by bleep. tried turning on/off at...
Please let me know what kind of tv it is(Plasma, Projection(DLP, CRT or LCD rear projection) or LCD tv) so that I can tell you whats the source of the problem. It sounds like its a DLP tv but I would like to be sure
May 30, 2011 | Televison & Video
I turn on my DYNEX LCD-TV model DX-L26-10A and the screen says 'Please Wait" for a few seconds and then I hear the voices for the channel, but there is no picture and there is a buzzing sound coming...
I turn on my DYNEX LCD-TV model DX-L26-10A and the screen says 'Please Wait" for a few seconds and then I hear the voices for the channel, but there is no picture and there is a buzzing sound coming from the back of the unit.
Nov 15, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
My Westinghouse 36 inch TV has picture and sound when I turn it on but when I change channels, the picture disappears and I have only sound. The picture comes back if you turn the TV off and back on but...
Hello, it sounds like your inverter board is goin out on the set, when you change channels if you notice on almost any TV the screen goes dark and the new channel appears, it sounds like you are not getting enough power out of the inverter board to power up the backlight enough to come on. This is why the sound remains because everything else works fine and the sound is connected to the main board.
Nov 22, 2009 | Westinghouse LTV-27w6 27 in. LCD HDTV
My 36' RCA TV JUST QUIT WORKING. TURNED ON POWER
A shorted horizontal output transistor or shorted flyback. If the flyback is shorted replace also its HOT.
Apr 05, 2009 | RCA F36650 36" TV
My polaroid has sound and picture problems
This is a well-known problem with many Polaroid FP displays. Eventually, the picture will simply go black, rendering the TV useless. The solution is a new control board, ~$400.
Feb 27, 2009 | Polaroid FLM-4201 42 in. LCD Television
Fisher tv monitor intermittently turns to snow and loud buzzing
Could it be vertical IC loose connection. It is sometimes connected with correct tuning. Check it for crack or wiggling connection best is to resolder.
Feb 02, 2009 | RCA Alert Guard 20" Flat Screen 20F670T...
Sylvania wont come on
pls check the power supply ckt. the sound might come from the transformer of the power supply ckt. switching regulator maybe is not pulsating.
Feb 21, 2008 | Sharp 27H-S60 TV
Digital Lifestyle FA1B32Z 32 in. LCD Television Logo
19 people viewed this question
Top Digital Lifestyle Televison & Video Experts
paul
paul
Are you a Digital Lifestyle Televison and Video Expert? Answer questions, earn points and help others
