Question about Dometic RM2652 Refrigerator
Rm 2652 stays on a while then cuts off and stays off
I have a dometic RM 2652. On electric the heater stays hot for a while and cuts off and won't come back on. Can unplug for a while then plug back up and the heater will stay hot for a while then cut off again.
    Habit-Forming:
  • 20 Answers
If you have the yellow epoxy filled circuit board from around 1993-1996 rather than the green newer one you can see the circuits on (take the black cover at back of fridge off to check) it is most likely just a bad circuit board. Otherwise it is most likely low voltage or a bad ground on the 12volt power coming into the fridge. Also make sure your thermostat(if available) is on maximum during testing.
Posted on Feb 20, 2009
Dometic rm 2652 refrigerator will not cool
if voltage to unit remove thermistor let run if ok replace thermistor if not see if chimney hot if not heater element if doesn't work on LP bad control board
Nov 18, 2013 | Dometic RM2652 Refrigerator
I have a Dometic model RM 2652. when i turn on the refrigerator it trips the GFCI everytime but does not through a breaker just the gfci
Check the amps it's pulling and uprate any fuses. If over current stated on data plate suspect compressor (or heater on absorption type)
Apr 27, 2012 | Dometic RM2652 Refrigerator
I have a Dometic RM 2652 LP gas/electric its hooked up to 120V but no gas. will it cool if so how long will it take to cool and how cold is it suppost to get it
I just saw where they have a recall on this model Dometic Refrigerator RM 2652. If you go to the www.Dometic.com and find the recall info you can type your Model and Serial Number into the boxes and see if your model is one of the ones recalled. Don't know if this link will work but try it first and it will bring you straight to that box I am talking about on their website. Its http://67.238.126.140/recall.php, if not go to the one above and find the recall information. Hope this helps.
Sep 12, 2010 | Dometic RM2652 Refrigerator
RM 2652 will not get cold
Check the 5 amp buss fuse behind the frig.
Apr 04, 2010 | Dometic RM2652 Refrigerator
Dometic rm 2652 fridge works on a/c. i get a check light on lp gas, i can light burner with flame, it stays lit
you may need to change the thermocople this cost about 12 dollars this is what make electricity to epen the gas valve thanks from gilles
Feb 25, 2009 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Problem
Check the flu at the back is clean
Oct 12, 2008 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
246 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
