There's a Frigidaire heating and cooling unit in the attic, and the thermostat is a White Rodgers (programmable). Air is blowing, but it is not HOT, though the thermostat is set at a high temperature. I have turned the switch to OFF, but the fan continues to blow. There is another compartment (as the heater lies on its side) that indicates that it's to only be open for servicing. I'm think that there is some sort of RESET button needed. Recently, new insulation was added to the attic. With higher outdoor temperatures is it possible that the it's too hot up there and the continuous running stems from an overheated unit? Step in San Francisco I had my unit installed in May of 2003. Ever since it"s been in there has been a problem. There is a fan that keeps running on the handler. The person that installed it moved away directly after he put it in. All I know about it is that it has " High Efficiency" on the top". It has one of the taller compressers and the other info is against the house. I have had several repair people out , but no one seems to be able to spot the problem. The last company has been out three times to no avail. Now it will not heat at all. Daphene Leggett Lakeland, Florida
    President:
  • 1,214 Answers
Is this gas or electric heat?
I can help you with all of it, but I need to know where we are working from.
As for the blower running, it's either caused by the Auto-Manual switch being put in Manual, or, there is a time delay for heat shutdown. When the thermostat is satisfied, the blower runs long enough to purge residual heat out of the furnace and ductwork.
Reply back and I will help you out on this.
Posted on Feb 01, 2009
  • 19,396 Answers
I do not think the problem is overheating, to test if this is overheating, test the unit stand alone.
Test all the connections to thermostat, it sounds more like a badly connected thermostat.
Air conditioning not working. Have White-Rodgers thermostat 1F79111, I think. Replaced batteries. Now have flashing signal like an asterisk. What does it mean?
Blinking snowflake means it's on time delay for cooling to come on (usually 5 minute time delay to prevent compressor short cycling). Solid snowflake means cooling is on
Aug 03, 2016 | White-Rodgers (Protech) White Rodgers...
How do I replace an old White Rodgers thermostat with new honeywell TH5220
The Orange wire for the reversing valve and used with a Heat Pump
If you have a heat pump, then yes. If you have a gas furnace then no. If you have a HP and the reversing valve is not connected, then you might just be using the emergency electric heat strips. :-o
Jul 21, 2014 | Honeywell Th5220d1003 Non-programmable...
I have a white rodgers thermostat 1F80-361 and my air conditioner blows out cool air for about an hour then it stips and blows out a air like temperture. The current temperature always says 80 and above...
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from White- Rodger's. Base on your description you have a system problem not a thermostat issue. You need to contact your installer to check you cool equipment.
Aug 04, 2012 | Heating & Cooling
Hi. I am not getting any heat. I have a White-Rodgers manual mercury thermostat model 1F56-501 and natural gas heat with GOODMAN packaged gas/electric model PGB024050-1 Before I call a service rep, I...
Hello,Good job with description.Something is keeping the condenser off(saftey).Do you have an emergency heat setting on the therm.It will run electric heat strips only until service can check it out.Very rare that the disconnect switch (black box) is it.Need electrical meter to prove it out.
Dec 01, 2010 | Goodman Heating & Cooling
We have the white and rodgers thermostat model 1F81-261. The problem is that the ac unit will not work. We have reset and changed the batteries and set the point 4 degrees less than the actual room...
Set System Switch to Cool and lower setpoint below room temperature.
Verify thermostat and system wires are securely attached.
Diagonistic: Set System Switch to Cool and lower the setpoint below the room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. If the thermostat does not click, try the reset operation ( . If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a service person to verify the heating system is operating correctly.
Reset the thermostat by pressing , UP,DOWN and TIME at the same time.
Jun 28, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Replacing WHITE-RODGERS manual thermostat with 3 wires ( red, white, blue and installing Honeywell electronic thermostat RTH110B, how do I connect it? The heating is not central, baseboard heating.
I have only seen one Honeywell thermostat that would work with a 3-wire heating system.
I would replace it with a White-Rodgers 1F80-0471. They are about $100, but they are a good thermostat, and they work well with the 3-wire zone valves.
Most other thermostats have the "Y" terminal that you need, but do not control the zone valve correctly.
Helping Hands Services
- Fairbanks, Alaska -
Jan 30, 2010 | Honeywell Electronic Programmable...
There's a Frigidaire heating and cooling unit in the attic, and the thermostat is a White Rodgers (programmable). Air is blowing, but it is not HOT, though the thermostat is set at a high temperature....
Unless you have and oil fired furnace, there is not a "reset" button. Most likely, the problem will need to be investigated and addressed by a qualified service technician due to the general complexity of HVAC equipment and a plethera of different possible individual problems that could cause your issue.
Jun 19, 2008 | Heating & Cooling
Thermostat
What were each wire connected to on the white rodgers? The connectors on the white rodgers should have markings. Tell me this and I can tell you how to wire your new stat. This hunter will not work with multi stage heat pumps..so I need to know what was connected to what on the white rodgers to know what type of unit. Thanks Kevin
Dec 20, 2007 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
