Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
LF code Whirlpool Cabrio during heavy duty cycle only
Keep getting low flow code on this setting only. Any ideas how to fix. Hoses are fine not clogged or kinked.
  • Anonymous Feb 04, 2009
    I constantly try to reset the machine with no luck. All of my loads are heavy duty since we're a big family so I'm not sure if this only applies to heavy loads or all the others as well. It is taking forever to get a load of laundry finished!
  • 6 Answers
SOURCE: Kenmore Oasis HE 2708..LF error code
LF = Long Fill
If the water is on and screens are clean there is a test you can do to check the log valve. There should be a repair manual inside the front panel of the machine. If yo use a screw driver in the front to open the top you should find it on the inside of the front panel. Good Luck
Posted on Dec 15, 2007
  • 4 Answers
SOURCE: Whirlpool duet washer problem
Our machine was giving the HF code at 37 min after over filling with water. I unplugged the machine, popped the top (took the 3 torx screws off the back) pulled the small hose off the pressure switch sensor (round sensor on the upper back right of the machine) and blew it out just by mouth. It obviously cleared some junk. It works fine now. (also unplugged the 6 wires on the sensor, turned it around and blew on that and heard it clicking, so I knew that was ok.) Hope this helps someone.
Posted on Feb 26, 2008
  • 1028 Answers
SOURCE: whirlpool cabrio
check hoses and screens make sure water flow to machine is on all the way and hoses not reversed ..last resort main fill valve has bad coil on one of the valves
Posted on Apr 19, 2008
SearsTechToo
  • 261 Answers
SOURCE: whirlpool/cabrio washer reads error LF and will not fill machine with water.
The serial number has a two letter designation, the first is where it was assembled and the second is the year. A long fill error can be several items, we all need to know first, how full with water, is your supply low on pressure or do you have a drain hose inserted far enough to cause a siphon condition? You should hear a gurgle splash as it drains.
Posted on Sep 13, 2008
rylee_smith
  • 8619 Answers
SOURCE: Whirlpool Cabrio washer is leaking water
Hi
Error code LF means Long Fill. If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed. Press STOP/CANCEL to clear the display.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jun 23, 2009
What does LF stand for on a Whirlpool Washing Machine?
LONG FILL....I usually means the faucets are not turned on fully OR you have a pinch in the hose and it is taking too long to fill (LONG FILL).
Jun 02, 2015 | Whirlpool Washing Machines
My whirlpool cabrio washer shows LF code
Verify inlet water valve is functioning correctly by selecting each temp while machine is running. Usually COLD temps will run just
ever-so-slightly faster than HOT temp and WARM temp will run faster than both temps separately. Rinse cycle is usually COLD water so i'd suspect the COLD side is malfunctioning. Hope this helps. If not let me know.
Jan 23, 2013 | Whirlpool Washing Machines
Whirlpool LF Error code
LF = Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Is water supply connected and turned on?
Are hose screens plugged?
Is water entering the tub? If so check pressure hose connection to machine/motor control.
Oct 19, 2012 | Whirlpool WTW6400SW Cabrio Washer
Cabrio top loader that hums initially when a load starts. i beleve this is during the water in cycle time but not sure. no error codes displayed. Washer works fine otherwise. any ideas???
Yes that sounds right a hum would be at start of cycle if water flow into was restricted in some manner and washer wasnt filling. What your is the hum the water valve makes when is calling for water yet no water from hoses coming to it.
The things to check are for blocked filter screens inside of ends of water valve on back where hoses attach to.
If you have :AQUAFLOW" brand hoses the internal stopper is hose is bad and hose should be replaced using standard hoses
Also for water coming from house pluming where hoses connect to at wall/faucet/spigot
Aug 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a whirlpool Cabrio, what does LF error code mean and how do i fix it??
The LF error is a water supply fault. Both water supplies must be connected and fully opened. The inlet hoses and valves both have strainers that may need cleaning as this could obstruct the water flow and also check that you don't have any water leaks. The unit requires a minimum water pressure to operate so anything that could prevent the unit getting this pressure will cause this fault. Hope this helps you out!
Nov 07, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio: During a white load the machine stops at 38 min
lf means long fill check your fill hoses and make sure the water is comeing out. sounds like a problem with your inlet valve and/or your water from your house is not right.
May 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Lf code on washer.checked hoses and valve both ok unit will run after opening the lid and closing lid and pressing start again. takes 10/15 minutes for a load to start
LF means that it is taking too long to fill. (If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.)
Supply hoses could be kinked or clogged(some have screens in the end).
This could be a supply water pressure/flow problem. Make sure you have good water flow though the hoses to the machine. (Take off and try running into a bucket)
The water fill valve may be failing to open all the way or it could be clogged.
I hope this helps.
Mar 20, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Maytag Bravos top load gives LF code..not working ... any idea?
Have same problem. Service tech said LF code is caused by low water pressure coming into machine. Tech verified water flow looked fine, getting new controller installed tomorrow.
Jul 18, 2009 | Maytag Bravos MTW6600T Top Load Washer
LF code
■ “LF” (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press PAUSE/CANCEL to clear display.
Recalibration is not needed but, you will need to check the above hoses and valves for obstructions and kinks.
Please rate and god bless.
Mar 27, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio
LF means long fill, so if your hoses arnt blocked and you are getting good flow, try looking at your drain pipe, it should only go about 6 inches into the actual drain and zip tie it there. any further it could syphon the water out of your machine.
Apr 16, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
