I just purchased new LX 6810-01. Where do i find detailed owner's manual? Are the external SATA bays hot swapable?
  • 4,654 Answers
Gateway will give all your answers. Here is their link below. I'm wanting that LX 6810-01! Hope this has helped,
Thanks Sea Breeze
http://www.gateway.com/systems/product/529668232.php
Posted on Feb 01, 2009
Where can i view a leisure bayhot tub manual?
You can find a copy of the Leisure Bay hot tub owners manual on The Cover Guy website. We also have a guide for error codes and information relating to Leisure Bay hot tubs. Leisure Bay Spas Hot Tubs Information
Jun 11, 2014 | Qca Spas Dream Series Dream Master Hot Tub...
How to intall sata 2nd dr
if your notebook faciltates a bay area to install the second SATA drive, then identify the bay door, open it (located under or other side of b=notebook). Otherwise you will have to buy external SATA enclosure using USB connection to the notebook
please advise notebook model and type number
Jan 03, 2012 | Computers & Internet
I'm trying to install a Western Digital Serial ATA Hard Drive into the external hard drive enclosure. There are no instructions as to what cables need to be attached and to where
USB external hard drive cases are supplied with SATA and power connectors attached to the circuit board in the case. If you canot connect it to the SATA hard drive then you may have the wrong drive case, your case may be a IDE or SCSI type.
Jul 07, 2011 | NexxTech 1 Bay USB 2.0 External Drive...
I see no evidence of a place in which to insert a cd to copy/burn in my new inspiron 580
According to dells, admittedly unhelpful store. The optical drive is an optional extra... Unfortunately this isn't of much use to you, if there's really no drive in the machine you'll ahve to either try and return it, or purchase one.
If you decided to purchase one you could go for an internal or external drive. An internal one would be slightly cheaper, however you'd have to install it yourself.
There are some pretty cheap options on ebuyer.
http://www.ebuyer.com/search?page=1&store=33&cat=27
Best of Luck
Jun 11, 2011 | Dell Inspiron 580 PC Desktop
How to install GH22nS50 Rewriter into my computer
These are the steps for installing your optical drive:
1. Remove both side covers on your PC case. 2. Locate a free 5.25 in bay on your desktop computer. This is usually located near the front/top part of a PC ATX case. 3. Remove the front/external cover for your chosen drive bay. This cover is usually not screwed in. You just have to pry it open. 4. Screw in the optical drive to the drive bay. You need 4 screws, 2 on each side. 5. Power connection : Locate a SATA power connector from your power supply and plug this into your new optical drive. The SATA power connector looks like this rjbautista.jpg
6. Data Connection - Locate the SATA ports on your motherboard which looks like this rjbautista_0.jpg
You need to plug in a SATA cable from your motherboard to your new optical drive
SATA power and data ports on the back of the optical drive
7. That's it! Your new optical drive should now work. it's plug n Play so you don't need to install any drivers for this device.
Mar 21, 2011 | LG RETAILSUPER MULTI DVD REWRITER DVD-RAM...
Bought internal harddrive and don't know where 7-pin SATA port is on motherboard, or Sata power connector is from PC.
hi, sorry to tell you this but that model of dell desktop does not have sata ports or sata power connectors and has no spare drive bays to mount the hard drive either , you would be best to try and return the drive and purchase an external hard drive and connect it to your PC via the usb socket .
Hope this helps
Apr 24, 2010 | Dell Dimension B110 PC Desktop
How do I replace a 73Gb disk in a RAID 5 config - DELL PE 4600
That depends on your configuration.
If the drive you want to change is installed in the peripheral bay, you have to turn the machine off before you can pull that drive out. Also: Hot-plug drive installation is not supported for systems without an integrated RAID controller or host adapter expansion card!
Look for more details on how to change a drive here.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Mar 08, 2010 | Dell PowerEdge 4600 Server
Laptop cannot find new sata disk
Can you provide me the details of the laptop. Also; are to trying to install Windows XP OS on your notebook.
If you are trying to install Windows XP on your notebook; then we need to disable the SATA on the notebook by using the external USB based floppy drive or using the nlite application burning the XP OS disc with a set of SATA drivers to install and recognize the hard drive.
Mar 03, 2010 | Computers & Internet
My dvd drive is not opening when I try to burn a cd. I own a new CF-52 Tough book.
do you mean when you push the botton to open the drive? is there something in it? can you perform an eject via My computer? also there is a spot where you can stick a pin to manually open the drive..... if might be the drive is lose? is it swapable? i would try removing it from the drive bay and putting it back in.. obviously while the computer is turned off.
Apr 30, 2008 | Computers & Internet
Computers & Internet Logo
188 people viewed this question
David Payne
David Payne
