Question about RCA D52W19 52" Rear Projection Television
Green led flashes 3 times and goes out no pix or audio
Need a cross reference number for the horizontal output xsistor on an rca D52W19B/ITC222 chassisschematic shows #(TL010) 264682 but cant cross it in nte cross ref book thank you for asst
  • RCA Master
  • 8,617 Answers
The transistor is the 2SC5588 but the 3 blink error is for the flyback replace the 259296 flyback and the CP150 and that should solve the issue you can get the original parts here.with free instructions with pictures.
http://servicemanuals.vstore.ca/
Posted on Feb 02, 2009
The tv won't come on...when you turn it on the green light on top comes on...blinks twice and then goes off
Hello
There is some short circuit in the horizontal output section inside your RCA tv. The blinking of ztandbylight twice denotes it. it may be due to a short in the horizontal output transistor, or defective LOT [Line Output Transformer]. Remove the horizontal aoutput transistor, by resoldering it out. It can be located very near to the above said LOT, screwed on to a metal heatsink. It is a three terminal device usually black in colour. After resoldering it out, switch on your TV, and see whether the standby LED blinks or not. If not, replace it with a new one, and switch the TV for a short time, say 3 seconds or so, and switch it off, unplug it from mains supply, and feel the heat of the transistor replaced. If it overheats, LOT said above is defective, and should be replaced with same type and number. OK.
Jan 05, 2011 | RCA F32450 32" TV
RCA D52W20 Light blinks 3 times, Replaced Flyback, Caps
I have the schematic, did the same thing and still have the problem. Any help?
Aug 12, 2009 | Televison & Video
Rca tv broke
Need the actual model number to help you as it sounds like the ITC222 or ITC222A flyback error.
May 27, 2009 | Televison & Video
Cross Reference part
The original transistor for the Horizontal output is a 2SC5588 you can get an original at the following link.
Feb 01, 2009 | RCA D52W19 52" Rear Projection Television
RCA D52W20B BEEPS AND SHUTS OFF
my first instinct when i hear this at the shop is a shorted horizontal output transistor. and with that usally a flyback also. If you know any electronics you can replace. Replacing these components are not for a novice. i would first check the transistor to be sure
Dec 28, 2008 | RCA HD52W58 52" TV
D52w19b rca
If the power led flshes 3 times then goes out when pressing power. it means the flyback is bad. You can get one at the following link with free online tech support to help you install it. You need flyback 259296 for your model. Here is the link.
Jul 22, 2008 | Televison & Video
NO PICTUR JUST A BEEP SOUND
Shorted Horizontal output transistor caused by bad horiz
transformer....parts to replace = Asti 2078 ( 257805 ) xformer
and 237470 RCA xistor..............................T.
Mar 03, 2008 | RCA F36450 36" TV
Rca d52w19
You can change the HV splitter first,then change the flyback
transformer, if necessary.......Do be careful with part number
of transformer....check the drawing number on it ......10756 =
259296.......10799 = 265409......as examples..........
I can check on that for you based on your info................T.
Feb 09, 2008 | RCA D52W19 52" Rear Projection Television
My TV turns off then turns it self back on 3-5 minutes later. We are told it is the small signal board?
rca? d61w130 itc222 ..does the unit flash green led.
itc222 shut down if the processor detects a problem. can be many different things. horizontal output is first thing to check. any sounds, chirps, smell... did it ever work
Dec 19, 2007 | RCA D61W130 61" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
311 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
